1 (edited by David_PhD 2026-03-12 17:24:33)
Topic: Cooldrive and module 4 relays Arduino
I would like to share a couple of items I have designed for QElectroTech. One is something commonly used and recognizable, a 4-relay module for Arduino.
The other is something less well known. It is a board called CoolDrive designed by NResearch. It is designed to extend the life of its own valves. It is something I have not found anywhere else and would be a plus if it were included in your open source program.
Re: Cooldrive and module 4 relays Arduino
Hello David,
please share them, just edit your post to see file upload.
Like this?
https://qelectrotech.org/forum/viewtopi … 661#p13661
3 (edited by David_PhD 2026-03-13 09:36:39)
Hello David,
please share them, just edit your post to see file upload.]
Like this?
Sure, I'm not used to forums and didn't know I also had to click on “add file.” Okay, I've uploaded both files and a zip file with both of them.
Yes, it's the link you sent me, which is 8, but I made the 4 relay module which had been missing.
