I do not know that module!
Take a look at the Mesa 7i77 in collection-tree:
There is a base-module with four terminals for Power-Supply and six separate modules with eight terminals each for TB7 and TB8.
You can only connect conductors to terminals of an element: no terminal -> no possibility to connect a conductor.
If you want to connect something to other parts than Power-Supply or TB7/TB8, you need to rework the existing elements or have to create new ones!
If you create new modules, please make sure, that the terminals are at positions that fit to the grid of 10x10 points, so that automatic connection can be done, when pulling the element to the folio. (The existing modules need to be reworked to match the grid!)
Addendum:
The elements in QET 0.100-dev have terminals at positions without decimals. Try to use those.
