Topic: Need analog terminal connection item as busbar
Hello all,
Is there some terminal block to use like busbar? Is there a possibility to change some parameters of simple terminal block to separate "potentials"?
I just need to separate some signals (potentials) after terminal blocks, like GND and remote panel GND. If I just closing menu of electric potential selection when connecting conductors without button OK, conductor is still with own name but from this place does not have potential as it was before.
BTW there is some very small bug in this menu of electric potential selection: If I use English language, there is some texts still in French I think.
Compilation : GCC 13.3.0
Built with Qt 5.15.16 - x86_64 - Date : May 22 2025 : 09:15:56
Run with Qt 5.15.16 using 12 thread(s)
Re: Need analog terminal connection item as busbar
please search busbar on the forum!
https://qelectrotech.org/forum/viewtopi … 268#p20268
Thank you for the reply but unfortunately I did not found any useful answer by search. In your mentioned thread I see only mechanical or real look like symbols for terminal blocks, not schematic symbols.
I would like to have terminal block style item working as busbar. Busbar element from thin threadhttps://qelectrotech.org/forum/viewtopic.php?id=1356 is too big and too bulky.
Or is there any better solution for separating some wires from different panels? Like GND and remote GND, Neutral and remote Neutral
draws a new symbol with the ‘simple’ property type to break equipotentiality!
Thank you very much, this is exactly what I needed. I created new terminal block with different color, filling
