Topic: How do I create a busbar
A busbar is a basic requirement for an electrical distribution system. A distribution boards typically have a busbar onto which all the circuit breakers and isolators are connected. The attached image show a single line diagram with two horizontal busbars.
It should be possible to connect many elements to a busbar i.e. the basbar should be able to accept many connections. The concept is similar to a terminal block but the connections are normally not numbered.
Is this possible to create a busbar in QElectroTech?
Single-line-diagram.png, 53.51 kb, 850 x 764
Re: How do I create a busbar
See this examples : conductor in single wire mode:
https://download.qelectrotech.org/qet/screens/images/ships_electrical1.jpg
https://download.qelectrotech.org/qet/screens/images/ships_electrical2.jpg
Thanks Scorpio. Your examples are exactly what I am looking for. What element did you use to create the busbars?
Perhaps this element :
busbar
  In some cases, a quickly solution is to trace over your conductor a basic shape line with a thick line to represent busbars.
Thanks
