Topic: Wire labeling and listing
I see in the 0.1 version that wire list can be exported.
We need a more advanced list, where each wire is listed with the ID of two end connection. Like if one end of wire V1 is connected to A1 of K1 relay, other end is to A2 of K2 then it is listed something like:
V1 - K1.A1 K2.A2
Based on this list we produce the labels to be attached to the end of the wires requested by the client.
Is it possible to do that?
Re: Wire labeling and listing
See: https://qelectrotech.org/forum/viewtopic.php?id=2764
Thank you, after reading the posts in the referred topics it seems to me that preparing the list is not an issue if the wire is not going to an other folio. If it does, then some programming is required, which is not availabe as a ready-to-use solution yet. Is it correct?
Yes not yet.
https://download.qelectrotech.org/qet/forum_img_2/1_schema.png
If you use numbers for your wires, it should be quicker.
By electrical convention, it is forbidden for the two ends of a wire to be named differently.
V1 - K1.A1 K2.A2
We prohibit it in the code on diagram,but you have free to write an function for that for wires labelling printers..
I understand, Unless the people wiring the electrical cabinets are unqualified.
How did you generate this list?
xmlstarlet sel -T -t -m /project/diagram/conductors/conductor -s A:N:- "@num" -v "concat(@num,';',@conductor_color,';',@function,';',@tension_protocol,';',@conductor_section,';',@element1_label,';',@terminalname1,';',@element1_name,';',@element1_linked,';',@element2_label,';',@element2_name,';',@element2_linked,';',@terminalname2,';')" -n  sansnom2.qet >list_num777.csv
Attachment icon list_num777.csv 567 b, 216 downloads since 2024-07-22
https://xmlstar.sourceforge.net/download.php
Humm in this file in XML I want to search attributes "comment" and maybe other like location, etc
</element>
            <element type="embed://import/10_electric/10_allpole/310_relays_contactors_contacts/01_coils/bobine3.elmt" freezeLabel="false" prefix="" uuid="{3b02493a-0cc1-4596-8d05-b04f4e0c5aed}" orientation="0" y="350" z="10" x="500">
                <terminals>
                    <terminal id="12" orientation="0" y="-16" x="0"/>
                    <terminal id="13" orientation="2" y="16" x="0"/>
                </terminals>
                <inputs/>
                <links_uuids>
                    <link_uuid uuid="{086f7776-ce74-4ce4-990e-c9dd4d1bf64a}"/>
                    <link_uuid uuid="{d73712d9-b8a3-4755-aaa7-f2d287dd8f41}"/>
                </links_uuids>
                <elementInformations>
                    <elementInformation show="1" name="comment">marche pompe 1</elementInformation>
                    <elementInformation show="1" name="label">ka1</elementInformation>
                    <elementInformation show="1" name="location">localisation</elementInformation>
                </elementInformations>
                <dynamic_texts>
                    <dynamic_elmt_text keep_visual_rotation="false" Valignment="AlignTop" rotation="0" uuid="{18710f6f-f869-4095-9d52-546d1aa1873b}" text_from="UserText" Halignment="AlignLeft" y="11.3333" font="Sans Serif,4,-1,5,25,0,0,0,0,0" x="2" frame="false" text_width="-1">
                        <text>A2</text>
                    </dynamic_elmt_text>
                    <dynamic_elmt_text keep_visual_rotation="false" Valignment="AlignTop" rotation="0" uuid="{7b284f9c-3044-441b-9eda-f083b33e4a6f}" text_from="UserText" Halignment="AlignLeft" y="-24.6667" font="Sans Serif,4,-1,5,25,0,0,0,0,0" x="2" frame="false" text_width="-1">
                        <text>A1</text>
                    <dynamic_elmt_text keep_visual_rotation="false" Valignment="AlignTop" rotation="0" uuid="{1b8862ad-2a23-4db0-a878-415ab778840e}" text_from="ElementInfo" Halignment="AlignLeft" y="-9.1667" font="Sans Serif,9,-1,5,50,0,0,0,0,0" x="25" frame="false" text_width="-1">
                        <text>ka1</text>
                        <info_name>label</info_name>
                </dynamic_texts>
I'm pulling my hair out and I don't need it ! ...with xmlstarlet if anyone has any ideas?
xmlstarlet sel -T -t -m /project/diagram/conductors/conductor -s A:N:- "@num" -v "concat(@num,';',@conductor_color,';',@function,';',@tension_protocol,';',@conductor_section,';',@element1_label,';',@terminalname1,';',@element1_name,';',@element1_linked,';',element1_linked/elementInformations/elementInformation[@name='comment']/@value,';' ,@element1_label,';',@element2_label,';',@element2_name,';',element2_linked/elementInformations/elementInformation[@name='comment']/@value,';',@element2_linked,';',@terminalname2,';')" -n  sansnom2.qet >list_num77.csv
Maybe I'm going the wrong way with xmlstarlet and should try xmllilnt?
