Topic: color of the selected tab/folio
is there a way to change the color of the selected folio?
if not can you change the color because the difference in color between selected and not selected folio is not so well visible
QElectroTech → EN : Help, suggestions, discussions, ... → color of the selected tab/folio
By default QElectroTech use the system style.
If you want to setup a custom color you need to see this :
https://doc.qt.io/qt-5/stylesheet.html
https://qelectrotech.org/forum/viewtopic.php?id=1466
https://qelectrotech.org/forum/viewtopic.php?id=1549
Generated in 0.033 seconds (34% PHP - 66% DB) with 10 queries
