Topic: position shift of sheets
Hello everyone,
there are sometimes strange position shifts in the sheet position on the monitor.
If you print it out in a PDF, it will work well.
sheet_01 correct position
sheet_02 slight shift
sheet_03 strong shift
sheet_04 correct position
Is there a solution to align all the sheets to the left?
Many Thanks
Vbxler
2 (edited by lowVoltage 2022-06-18 23:10:35)
Re: position shift of sheets
Vbxler,
The problem appears to perhaps be the zoom factor..
Please try:
MENU > Display > Fit In View
or,
CNTRL + 9
Hello lowVoltage,
with ctrl+9 the view of page 2+3 does not change.
I've attached an example. On my Linux computer
page 2+3 is displayed differently than 1+4.
I think this behavior comes only when using copy+paste of a content.
But the pages remain permanently shifted.
4 (edited by lowVoltage 2022-06-20 01:56:04)
Vbxler,
a) I opened your project.
b) the same problem occurs: folio 3 is shifted greatly to the right.
This is true even after I invoke CNTRL + 9.
c) I created a new (fifth) folio, 5/5.
I then copy-pasted the content of folio 3/5 into folio 5/5.
The identical problem appears then in 5/5.
So this seems to confirm that there is something strange about the specific content of folio 3/5.
If I encountered this problem in a typical CAD software (such as AutoCAD), I would suspect a 'stray' drawing entity located outside the drawing border area, causing a zoom/extents to zoom out far enough to encompass the stray entity.
QelectroTech is not CAD however, and I do not have a guess what may cause this problem.
I hope this may help in a small way.
I regret that I have no answer.
(I am using QeT ver 0.80 in Ubuntu Linux)
thanks for the reply, it's not such a serious problem.
Maybe someone can take a look and find out what the problem is.
It will be interesting to learn the answer.
lowVoltage wrote:
Vbxler,
You have PPA for 0.9-dev and is work very well than old 0.8 release.
@scorpio810,
Success!
I now have installed ver 0.9, with much sincere thanks, and my warmest regards.
I can see the improved quality immediately.
Best wishes to you and all the QelectroTech team!
It's a well old known bug, I already take look to fix it but was not easy (at time I check it, may be more easy now I got better skill) and also I prefer spend my time to implement big feature (actually terminal strip generator).
Vbxler can you fill a bug report ?
