1 (edited by mezga 2021-03-29 21:42:07)
Topic: elements connectors slip apart
Hello
Can anyone help with the following problem?
There is exactly one problem with the symbols falling apart in QelectroTech. The terminals have moved.
They are fine when opened in the editor.
But not just the ones I created, but the built-in elements as well.
The text sizes have changed, moved out of position.
Also in the previously saved project.
Restarting the computer did not help.
A lot of my work has been damaged this way.
What can I do? What can cause this?
The version is as follows:
I have attached pictures.
I use the first v07 and then upgrade to v08 later.
The above attachment is incorrect, please delete the moderator.
Re: elements connectors slip apart
What your OS?
what have you changed, QET version?
3 (edited by mezga 2021-03-29 21:41:21)
Thanks your answer.
Kiadás    Windows 10 Pro
Verzió    20H2
Telepítés dátuma    2021. 01. 14.
Operációs rendszer buildszáma    19042.867
Minőség    Windows Feature Experience Pack 120.2212.551.0
V07 upgrade to V08
Because they disintegrated the elements and I thought that would solve the problem.
There are many fixes in the new version.
Your problem arose following the change from version 0.7 to 0.8?
Version 0.8 is downloaded here on our servers?
You could share your project here?
5 (edited by mezga 2021-03-30 08:03:44)
The problem did not occur immediately.
After upgrading I worked on the project, everything seemed fine.
I deleted a page, the program closed automatically by itself.
Then the error began.
From here:
https://download.qelectrotech.org/qet/t … 1/Windows/
pls help, how to attach or send the qet file nomicons/smile)
Edit you previous post and you saw an attachment file.
7 (edited by mezga 2021-03-30 08:52:05)
I try, the file too large : 4 Mb
Compress to zip.
Important information:
the same project works on another machine (WIN10 ) with the same version.
Run you project on Debian with last 0.9-dev.
I' think is good, no?
Maybe you have changed fonts type or size on QET config or an Win10 update.. on this machine.
12 (edited by mezga 2021-03-30 11:51:39)
I not try V09.
I have only Windows machines.
I think not change the fonts.
I change in settings the grid size . All = 1.
Maybe this is problem?
I not remember win update  on the last weeks.
All elements connectors slips.
2021-03-30_11h29_09.png, 3.93 kb, 336 x 286
I you see my PDF your project run well on 0.9-dev but also on 0.8 version.
I understand well you have this problem only one Win 10 machine? and this project run well on another Win10 machine, yes?
14 (edited by mezga 2021-03-30 16:08:16)
Exactly.
In the another machine QE version.
QE_ver.PNG, 6.43 kb, 644 x 150
Verzió    20H2
https://www.windowslatest.com/2020/11/2 … indows-10/
You think, the upgrade solve my problem?
I tried on my Win10 20H2 laptop
"Version : Windows 10 Version 2009 - Kernel : 10.0.19042" "
project render well but I saw a lot off messages on log
16:21:28.216 Info: "GitRevision 0f8f26e1774537bb4cbc9a2f36cb7e62dd763c07"
16:21:28.230 Info: "QElectroTech V 0.90-DEV"
16:21:28.241 Info: "Compilation : GCC 9.3.0"
16:21:28.249 Info: "Built with Qt 5.15.2 - Date : Mar 23 2021 : 14:04:02"
16:21:28.267 Info: "Run with Qt 5.15.2 using 8 thread(s)"
16:21:28.278 Info: "CPU : NAME                                      \r\r\nINTEL(R) CORE(TM) I7-8550U CPU @ 1.80GHZ  \r\r\n\r\r\n"
16:21:28.299 Info: "RAM Total : 16199 MB"
16:21:28.315 Info: "RAM Available : 11303 MB"
16:21:28.324 Info: "GPU : VideoProcessor                \r\r\nIntel(R) UHD Graphics Family  \r\r\n\r\r\n"
16:21:28.343 Info: "GPU RAM : RAM Total : AdapterRAM  \r\r\n1073741824  \r\r\n\r\r\n B"
16:21:28.358 Info: "OS : winnt  - x86_64 - Version : Windows 10 Version 2009 - Kernel : 10.0.19042"
16:21:28.373 Info: *** Qt screens ***
16:21:28.386 Info: "( 1 : 3840 x 2160 )"
16:22:10.631 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.665 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.697 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.734 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.826 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.852 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.888 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.916 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.956 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:10.999 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.032 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.069 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.104 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.142 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.175 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.223 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.248 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.292 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.322 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.355 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.400 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.445 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.477 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.517 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.554 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.590 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
16:22:11.626 Debug: TerminalData::typeFromString, argument string is invalid failsafe type 'TerminalData::Generic' is returned (../sources/properties/terminaldata.cpp:192, static TerminalData::Type TerminalData::typeFromString(const QString&))
What does it mean now?
What can I do?
Unfortunately, I don't understand this part.
I am a simple user.
Maybe you have a Win10 problem.. on your machine .. ?!
Tried with Appimage 0.8 on debian, render is great.
You restore a  great luxurious motorhome diy project?
Thanks is an impressive project. nomicons/wink
20 (edited by mezga 2021-03-30 20:27:20)
I'm talking to my system administrator about Windows.
More ideas? How Satbil is V09?
I'm sorry, I only shared it to solve the problem.
This project is non pupblic!! please delete the images from the posts.
Thanks
Hi Gabor ,
I deleted all files because is private.
For private resolve use joshua and me 'emails, not public forum. ;-)
The v0.9 is stable now, but is a devel branch and we want if we want break a lot. :p
But when  I see is breaking a lot I don't push nightly's builds.
I check not all commits ..
https://git.tuxfamily.org/qet/qet.git/c … 65ad507c3e
Project properties dialog launch a little more faster (especially on windows)
Instead of build machine_info class which take time, only to get the max
width and height of screens, call  of methods
Machine_info::i_max_screen_width() and
Machine_info::i_max_screen_height() are now static and compute only
this.
The project properties dialog is now faster because don't wait the end
build of machine_info.
https://git.tuxfamily.org/qet/qet.git/c … 073a46ca64
Make MachineInfo a singleton class
Because on windows MachineInfo take a little time to init, we make it to
a singleton.
MachineInfo is build the first time in main.cpp.
Now all other places where we use MachineInfo (aboutqetdialog and
configdialog) gui don't hang anymore in waiting to MachineInfo finish to
build.
https://git.tuxfamily.org/qet/qet.git/c … d6631a08e0
Use QStringLiteral and QLatin1String.
According to the Qt documentation
(https://doc.qt.io/qt-5/qstring.html#QStringLiteral)
(https://woboq.com/blog/qstringliteral.html), use QStringLiteral and
QLatin1String is better on some conditions (faster).
This commit change the code related to the loading of a project (in
qetproject class), let see if loading time is improved.
Dear Scorpio,
Thank you for your understanding.
If i use the v09  and send log file to you, that help find the problem?
You have the same log on 0.8.
