1 (edited by q.e.d. 2021-02-14 14:00:01)
Topic: Having a hard time utilizing formulas
(And the docs do not look like an ally on that matter).
0.8-r7117 AppImg here
https://download.qelectrotech.org/qet/m … imple.html
% {F}:
% {f}:
% {M}:
% {LM}:
etc. etc.
Errm. Nope.
a) there is a space between % and the curly bracket which probably does not belong there.
b) the curly bracket also does not belong there. I think. Sometimes, if a formula works at all, it's without these curly brackets
c) Then again, sometimes that variable does not work in a formula with, without space and/or brackets ???
ad "Specific Variables"
I don't understand these at all. What are they for, how do they work - do they work at all?
Do I use %Annotation, %annotation, %{Annotation}, %{annotation} or how is the term "variable" meant here - because none of these work.
Re: Having a hard time utilizing formulas
Is this that you want?
Hmm. I see. So the "label formula", which remains empty in your example and which I did try because "formula": what is that used for?
label_comptxt.png, 67.24 kb, 1368 x 405
https://download.qelectrotech.org/qet/m … ering.html
