Topic: Problem opening file
Hello Qet users and developers friends. I need help to know what I can do to decrease the opening time of the attached file.
Actually my notebook is not very powerful but I do not believe it is lack of power.
Thank you very much in advance
Re: Problem opening file
I did the test with version 0.7 of qet. It opened very fast, but crashes when making changes.
It also didn’t open all the wiring before I built it in a newer version.
Help me please.
3 (edited by De-Backer 2020-12-10 23:14:23)
this is a fantastic file for stressing qelectrotech
more info will follow
save and load file is single thread => the long duration
the problem is that all classes in QET can write to the file, the file is then written at disc speed
if this is the problem, it is not resolved in 123
Summary
The process qelectrotech (with pid 18480) is using approximately 1.2 GB of memory.
It is using 1.1 GB privately, 35.2 MB for pixmaps, and a further 75.7 MB that is, or could be, shared with other programs.
Dividing up the shared memory between all the processes sharing that memory we get a reduced shared memory usage of 19.7 MB. Adding that to the private and pixmap usage, we get the above mentioned total memory footprint of 1.2 GB.
Library Usage
The memory usage of a process is found by adding up the memory usage of each of its libraries, plus the process's own heap, stack and any other mappings, plus the stack of its 25 threads.
startup qet
21:23:09.848 Info: Start-up
21:23:09.875 Info: debugging enabled: false
21:23:09.875 Info: Qt library version: 5.15.1
21:23:09.875 Info: Qt library location default prefix: "/home/simon/Qt/5.15.1/gcc_64"
21:23:09.876 Info: Qt library location documentation: "/home/simon/Qt/5.15.1/gcc_64/doc"
21:23:09.876 Info: Qt library location headers: "/home/simon/Qt/5.15.1/gcc_64/include"
21:23:09.876 Info: Qt library location libraries: "/home/simon/Qt/5.15.1/gcc_64/lib"
21:23:09.876 Info: Qt library location executables: "/home/simon/Qt/5.15.1/gcc_64/libexec"
21:23:09.876 Info: Qt library location Qt binaries: "/home/simon/Qt/5.15.1/gcc_64/bin"
21:23:09.876 Info: Qt library location Qt plugins: "/home/simon/Qt/5.15.1/gcc_64/plugins"
21:23:09.876 Info: Qt library location installed QML extensions: "/home/simon/Qt/5.15.1/gcc_64/imports"
21:23:09.876 Info: Qt library location installed QML extensions: "/home/simon/Qt/5.15.1/gcc_64/qml"
21:23:09.876 Info: Qt library location dependent Qt data: "/home/simon/Qt/5.15.1/gcc_64"
21:23:09.876 Info: Qt library location independent Qt data: "/home/simon/Qt/5.15.1/gcc_64"
21:23:09.876 Info: Qt library location translation: "/home/simon/Qt/5.15.1/gcc_64/translations"
21:23:09.876 Info: Qt library location examples: "/home/simon/Qt/5.15.1/gcc_64/examples"
21:23:09.876 Info: Qt library location Qt testcases: "/home/simon/Qt/5.15.1/gcc_64/tests"
21:23:09.876 Info: Qt library location Qt settings: "/etc/xdg"
21:23:09.876 Info: "GitRevision ed938c82cd15e9c319e1a0ca481a0ebafd7049bc"
21:23:09.876 Info: "QElectroTech V 0.80-rc"
21:23:09.876 Info: "Compilatie: GCC Clang 11.0.0"
21:23:09.876 Info: "Built with Qt 5.15.1 - Date : Dec 10 2020 : 21:17:48"
21:23:09.876 Info: "Run with Qt 5.15.1 using 16 thread(s)"
21:23:09.876 Info: "CPU : model name\t: AMD Ryzen 7 3700X 8-Core Processor\n"
21:23:09.876 Info: "RAM Total : 32026 MB"
21:23:09.876 Info: "RAM Available : 20150 MB"
21:23:09.876 Info: "GPU : "
21:23:09.876 Info: "GPU RAM : @ToDo"
21:23:09.876 Info: "OS : linux  - x86_64 - Version : openSUSE Tumbleweed - Kernel : 5.9.12-1-default"
21:23:09.876 Info: *** Qt screens ***
21:23:09.876 Info: "( 1 : 3840 x 2160 )"
21:23:10.160 Info: Elements collection reload
21:23:10.648 Info: Elements collection finished to be loaded
load file
21:23:15.250 Debug: is QRegularExpression ok? (../../qet/sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString &))
21:23:15.253 Debug: is QRegularExpression ok? (../../qet/sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString &))
21:28:15.432 Debug: Diagram::fromXml() : Le chargement des parametres d'un element a echoue (../../qet/sources/diagram.cpp:1329, bool Diagram::fromXml(QDomElement &, QPointF, bool, DiagramContent *))
save file
21:33:17.972 Debug: Export XML de 115 schemas (../../qet/sources/qetproject.cpp:888, QDomDocument QETProject::toXml())
21:33:18.125 Debug: "exporting diagram \"Capa\"" [ Diagram(0x259ba90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.129 Debug: "exporting diagram \"Painel Geral QD-0023\"" [ Diagram(0x202aaa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.155 Debug: "exporting diagram \"PE-1106 Alimentação\"" [ Diagram(0x1480e350) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.174 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X6)\"" [ Diagram(0x1f00ea0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.178 Debug: "exporting diagram \"PE-1106 Distribuição 24Vcc\"" [ Diagram(0x1f69920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.195 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X3 e X4)\"" [ Diagram(0x1ed33a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.214 Debug: "exporting diagram \"PE-1106 Distribuição 24Vac\"" [ Diagram(0x18f9360) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.224 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X7 e X8)\"" [ Diagram(0x18a4980) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.235 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 01\"" [ Diagram(0x15ae1990) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.255 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 02\"" [ Diagram(0x15b84610) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.277 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 03\"" [ Diagram(0x15f38880) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.297 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 04\"" [ Diagram(0x1638afa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.306 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 05\"" [ Diagram(0x1636fd00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.324 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 06\"" [ Diagram(0x20acac0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.338 Debug: "exporting diagram \"PE-1106 Cartão 07\"" [ Diagram(0x16faefb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.341 Debug: "exporting diagram \"PE-1106 Bornes Disponíveis\"" [ Diagram(0x16fb1d70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.356 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/1)\"" [ Diagram(0x17114b30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.384 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/2)\"" [ Diagram(0x17a63780) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.413 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/1)\"" [ Diagram(0x17a53020) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.442 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/2)\"" [ Diagram(0x185da150) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.443 Debug: "exporting diagram \"PE-1100 Motor do Bland\"" [ Diagram(0x185d6ce0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.457 Debug: "exporting diagram \"PE-1100 Potência dos Vibradores\"" [ Diagram(0x187bcd10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.466 Debug: "exporting diagram \"PE-1100 Comando dos Vibradores\"" [ Diagram(0x18524d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.474 Debug: "exporting diagram \"PE-1100 Pulverizador Bland\"" [ Diagram(0x180fb0b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.482 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (01)\"" [ Diagram(0x18b0c260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.502 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (02)\"" [ Diagram(0x18f4a250) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.513 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (03)\"" [ Diagram(0x19117aa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.524 Debug: "exporting diagram \"PE-1100 Régua de bornes (X9)\"" [ Diagram(0x192ae920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.532 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/1)\"" [ Diagram(0x1934aa60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.555 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/2)\"" [ Diagram(0x19c6f330) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.576 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/3)\"" [ Diagram(0x18ddfc20) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.582 Debug: "exporting diagram \"QC do Bland Botoeiras\"" [ Diagram(0x1883a6c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.598 Debug: "exporting diagram \"QC do Bland Solenóides\"" [ Diagram(0x1a1adbd0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.608 Debug: "exporting diagram \"QC do Bland Sensores e Sinaleiros\"" [ Diagram(0x18832d00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.622 Debug: "exporting diagram \"QC do Bland Bornes Disponíveis\"" [ Diagram(0x1a8f1f90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.623 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/1)\"" [ Diagram(0x1a9f6730) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.645 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/2)\"" [ Diagram(0x1a9d8b00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.651 Debug: "exporting diagram \"PE-1105 Rosca Elevador\"" [ Diagram(0x1a9f8150) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.664 Debug: "exporting diagram \"PE-1105 Elevador\"" [ Diagram(0x1b127e10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.676 Debug: "exporting diagram \"PE-1105 Rosca Esteira\"" [ Diagram(0x1b4854f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.686 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Potência)\"" [ Diagram(0x1b6cbfa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.696 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Comando)\"" [ Diagram(0x1b4335a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.709 Debug: "exporting diagram \"PE-1105 Vibradores\"" [ Diagram(0x1b068e80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.718 Debug: "exporting diagram \"PE-1105 Sinaleiros e Moega\"" [ Diagram(0x1bf89340) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.721 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X11)\"" [ Diagram(0x1bed00e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.735 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X12)\"" [ Diagram(0x1be87200) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.749 Debug: "exporting diagram \"QC Vibradores moega do Bland\"" [ Diagram(0x1c80bda0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.758 Debug: "exporting diagram \"PE-1104 Misturadores\"" [ Diagram(0x1b045cc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.772 Debug: "exporting diagram \"PE-1104 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1ccbd680) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.785 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Moinho\"" [ Diagram(0x1ccc0010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.797 Debug: "exporting diagram \"PE-1104 Moinho\"" [ Diagram(0x1d1ae310) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.809 Debug: "exporting diagram \"PE-1104 Exaustor\"" [ Diagram(0x1d0488c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.819 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Empacotadora\"" [ Diagram(0x1d80c910) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.830 Debug: "exporting diagram \"PE-1104 Vibradores\"" [ Diagram(0x1d77dcd0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.838 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X13)\"" [ Diagram(0x1d632c40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.855 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X14)\"" [ Diagram(0x1df6de30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.874 Debug: "exporting diagram \"PE-1104 Comando Manual\"" [ Diagram(0x1e166930) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.877 Debug: "exporting diagram \"QC Linha 04 Balança\"" [ Diagram(0x1d0165b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.884 Debug: "exporting diagram \"QC Linha 04 Comando\"" [ Diagram(0x1e7cdad0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.896 Debug: "exporting diagram \"QC Linha 04 Régua de Bornes (X24)\"" [ Diagram(0x1e9d9af0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.910 Debug: "exporting diagram \"PE-1103 Misturadores\"" [ Diagram(0x1e7a3ea0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.921 Debug: "exporting diagram \"PE-1103 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1ee50df0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.934 Debug: "exporting diagram \"PE-1103 Vávula e Rosca do Moinho\"" [ Diagram(0x1f238cc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.947 Debug: "exporting diagram \"PE-1103 Moinho\"" [ Diagram(0x1f4323c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.959 Debug: "exporting diagram \"PE-1103 Exaustor\"" [ Diagram(0x1f8ce230) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.970 Debug: "exporting diagram \"PE-1103 Vávula e Rosca da Empacotadora\"" [ Diagram(0x1fbbf610) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.980 Debug: "exporting diagram \"PE-1103 Vibradores\"" [ Diagram(0x1f859930) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:18.989 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X15)\"" [ Diagram(0x14ded080) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.007 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X16)\"" [ Diagram(0x203590a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.026 Debug: "exporting diagram \"PE-1103 Comando Manual\"" [ Diagram(0x209c86b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.029 Debug: "exporting diagram \"QC Linha 03 Balança\"" [ Diagram(0x203599e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.036 Debug: "exporting diagram \"QC Linha 03 Comando\"" [ Diagram(0x20a951c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.048 Debug: "exporting diagram \"QC Linha 03 Régua de Bornes (X25)\"" [ Diagram(0x20a3b6b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.062 Debug: "exporting diagram \"PE-1102 Misturadores\"" [ Diagram(0x20af3a40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.074 Debug: "exporting diagram \"PE-1102 Vávula e Rosca do Moinho\"" [ Diagram(0x212a7d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.087 Debug: "exporting diagram \"PE-1102 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x20381080) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.100 Debug: "exporting diagram \"PE-1102 Moinho\"" [ Diagram(0x2038c260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.112 Debug: "exporting diagram \"PE-1102 Exaustor\"" [ Diagram(0x21cf7500) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.122 Debug: "exporting diagram \"PE-1102 Vávula e Rosca da Empacotadora\"" [ Diagram(0x21efe7b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.132 Debug: "exporting diagram \"PE-1102 Vibradores\"" [ Diagram(0x220f3660) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.142 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X17)\"" [ Diagram(0x223c6010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.159 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X18)\"" [ Diagram(0x2271a950) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.179 Debug: "exporting diagram \"PE-1102 Comando Manual\"" [ Diagram(0x21c887a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.182 Debug: "exporting diagram \"QC Linha 02 Balança\"" [ Diagram(0x226ccc30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.189 Debug: "exporting diagram \"QC Linha 02 Comando\"" [ Diagram(0x22e1ab00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.199 Debug: "exporting diagram \"QC Linha 02 Régua de Bornes (X26)\"" [ Diagram(0x23002e60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.212 Debug: "exporting diagram \"PE-1101 Misturadores\"" [ Diagram(0x23557760) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.223 Debug: "exporting diagram \"PE-1101 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x226f2000) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.236 Debug: "exporting diagram \"PE-1101 Vávula e Rosca do Moinho\"" [ Diagram(0x238524e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.248 Debug: "exporting diagram \"PE-1101 Moinho\"" [ Diagram(0x23c585a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.260 Debug: "exporting diagram \"PE-1101 Exaustor\"" [ Diagram(0x23eae920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.271 Debug: "exporting diagram \"PE-1101 Vávula e Rosca da Empacotadora\"" [ Diagram(0x2426ba70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.281 Debug: "exporting diagram \"PE-1101 Vibradores\"" [ Diagram(0x23c5c580) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.288 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X19)\"" [ Diagram(0x24650530) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.305 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X20)\"" [ Diagram(0x2493f6f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.325 Debug: "exporting diagram \"PE-1101 Comando Manual\"" [ Diagram(0x250c5050) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.328 Debug: "exporting diagram \"QC Linha 01 Balança\"" [ Diagram(0x24cfe5e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.334 Debug: "exporting diagram \"QC Linha 01 Comando\"" [ Diagram(0x2514d3b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.344 Debug: "exporting diagram \"QC Linha 01 Régua de Bornes (X27)\"" [ Diagram(0x25006c90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.357 Debug: "exporting diagram \"\"" [ Diagram(0x250f70b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x255b76f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x2585ca30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x255c6fa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x25475590) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x255c28f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x2577e5e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x2578e800) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x2579b070) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x2579a440) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x2578eec0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x257848e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.358 Debug: "exporting diagram \"\"" [ Diagram(0x25797380) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.359 Debug: "exporting diagram \"\"" [ Diagram(0x25787a80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.359 Debug: "exporting diagram \"\"" [ Diagram(0x2578adb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:33:19.359 Debug: "exporting diagram \"\"" [ Diagram(0x25786db0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
and save file
21:33:56.544 Info: Elements collection finished to be loaded
21:34:18.382 Debug: Leave mouse over (../../qet/sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent *))
21:35:06.006 Debug: Leave mouse over (../../qet/sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent *))
21:35:18.391 Debug: Export XML de 115 schemas (../../qet/sources/qetproject.cpp:888, QDomDocument QETProject::toXml())
21:35:18.392 Debug: "exporting diagram \"Capa\"" [ Diagram(0x259ba90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.392 Debug: "exporting diagram \"Painel Geral QD-0023\"" [ Diagram(0x202aaa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.418 Debug: "exporting diagram \"PE-1106 Alimentação\"" [ Diagram(0x1480e350) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.448 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X6)\"" [ Diagram(0x1f00ea0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.455 Debug: "exporting diagram \"PE-1106 Distribuição 24Vcc\"" [ Diagram(0x1f69920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.479 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X3 e X4)\"" [ Diagram(0x1ed33a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.496 Debug: "exporting diagram \"PE-1106 Distribuição 24Vac\"" [ Diagram(0x18f9360) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.505 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X7 e X8)\"" [ Diagram(0x18a4980) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.516 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 01\"" [ Diagram(0x15ae1990) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.535 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 02\"" [ Diagram(0x15b84610) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.556 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 03\"" [ Diagram(0x15f38880) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.575 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 04\"" [ Diagram(0x1638afa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.584 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 05\"" [ Diagram(0x1636fd00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.603 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 06\"" [ Diagram(0x20acac0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.616 Debug: "exporting diagram \"PE-1106 Cartão 07\"" [ Diagram(0x16faefb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.618 Debug: "exporting diagram \"PE-1106 Bornes Disponíveis\"" [ Diagram(0x16fb1d70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.632 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/1)\"" [ Diagram(0x17114b30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.659 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/2)\"" [ Diagram(0x17a63780) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.685 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/1)\"" [ Diagram(0x17a53020) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.712 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/2)\"" [ Diagram(0x185da150) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.713 Debug: "exporting diagram \"PE-1100 Motor do Bland\"" [ Diagram(0x185d6ce0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.725 Debug: "exporting diagram \"PE-1100 Potência dos Vibradores\"" [ Diagram(0x187bcd10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.733 Debug: "exporting diagram \"PE-1100 Comando dos Vibradores\"" [ Diagram(0x18524d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.741 Debug: "exporting diagram \"PE-1100 Pulverizador Bland\"" [ Diagram(0x180fb0b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.748 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (01)\"" [ Diagram(0x18b0c260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.767 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (02)\"" [ Diagram(0x18f4a250) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.777 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (03)\"" [ Diagram(0x19117aa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.787 Debug: "exporting diagram \"PE-1100 Régua de bornes (X9)\"" [ Diagram(0x192ae920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.793 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/1)\"" [ Diagram(0x1934aa60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.813 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/2)\"" [ Diagram(0x19c6f330) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.834 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/3)\"" [ Diagram(0x18ddfc20) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.839 Debug: "exporting diagram \"QC do Bland Botoeiras\"" [ Diagram(0x1883a6c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.854 Debug: "exporting diagram \"QC do Bland Solenóides\"" [ Diagram(0x1a1adbd0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.863 Debug: "exporting diagram \"QC do Bland Sensores e Sinaleiros\"" [ Diagram(0x18832d00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.876 Debug: "exporting diagram \"QC do Bland Bornes Disponíveis\"" [ Diagram(0x1a8f1f90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.877 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/1)\"" [ Diagram(0x1a9f6730) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.898 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/2)\"" [ Diagram(0x1a9d8b00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.904 Debug: "exporting diagram \"PE-1105 Rosca Elevador\"" [ Diagram(0x1a9f8150) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.915 Debug: "exporting diagram \"PE-1105 Elevador\"" [ Diagram(0x1b127e10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.926 Debug: "exporting diagram \"PE-1105 Rosca Esteira\"" [ Diagram(0x1b4854f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.935 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Potência)\"" [ Diagram(0x1b6cbfa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.944 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Comando)\"" [ Diagram(0x1b4335a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.956 Debug: "exporting diagram \"PE-1105 Vibradores\"" [ Diagram(0x1b068e80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.965 Debug: "exporting diagram \"PE-1105 Sinaleiros e Moega\"" [ Diagram(0x1bf89340) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.968 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X11)\"" [ Diagram(0x1bed00e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.981 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X12)\"" [ Diagram(0x1be87200) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:18.994 Debug: "exporting diagram \"QC Vibradores moega do Bland\"" [ Diagram(0x1c80bda0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.003 Debug: "exporting diagram \"PE-1104 Misturadores\"" [ Diagram(0x1b045cc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.015 Debug: "exporting diagram \"PE-1104 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1ccbd680) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.027 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Moinho\"" [ Diagram(0x1ccc0010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.038 Debug: "exporting diagram \"PE-1104 Moinho\"" [ Diagram(0x1d1ae310) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.049 Debug: "exporting diagram \"PE-1104 Exaustor\"" [ Diagram(0x1d0488c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.059 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Empacotadora\"" [ Diagram(0x1d80c910) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.069 Debug: "exporting diagram \"PE-1104 Vibradores\"" [ Diagram(0x1d77dcd0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.077 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X13)\"" [ Diagram(0x1d632c40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.094 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X14)\"" [ Diagram(0x1df6de30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.112 Debug: "exporting diagram \"PE-1104 Comando Manual\"" [ Diagram(0x1e166930) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.115 Debug: "exporting diagram \"QC Linha 04 Balança\"" [ Diagram(0x1d0165b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.122 Debug: "exporting diagram \"QC Linha 04 Comando\"" [ Diagram(0x1e7cdad0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.132 Debug: "exporting diagram \"QC Linha 04 Régua de Bornes (X24)\"" [ Diagram(0x1e9d9af0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.144 Debug: "exporting diagram \"PE-1103 Misturadores\"" [ Diagram(0x1e7a3ea0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.155 Debug: "exporting diagram \"PE-1103 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1ee50df0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.167 Debug: "exporting diagram \"PE-1103 Vávula e Rosca do Moinho\"" [ Diagram(0x1f238cc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.179 Debug: "exporting diagram \"PE-1103 Moinho\"" [ Diagram(0x1f4323c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.190 Debug: "exporting diagram \"PE-1103 Exaustor\"" [ Diagram(0x1f8ce230) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.200 Debug: "exporting diagram \"PE-1103 Vávula e Rosca da Empacotadora\"" [ Diagram(0x1fbbf610) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.210 Debug: "exporting diagram \"PE-1103 Vibradores\"" [ Diagram(0x1f859930) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.218 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X15)\"" [ Diagram(0x14ded080) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.235 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X16)\"" [ Diagram(0x203590a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.253 Debug: "exporting diagram \"PE-1103 Comando Manual\"" [ Diagram(0x209c86b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.256 Debug: "exporting diagram \"QC Linha 03 Balança\"" [ Diagram(0x203599e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.262 Debug: "exporting diagram \"QC Linha 03 Comando\"" [ Diagram(0x20a951c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.272 Debug: "exporting diagram \"QC Linha 03 Régua de Bornes (X25)\"" [ Diagram(0x20a3b6b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.284 Debug: "exporting diagram \"PE-1102 Misturadores\"" [ Diagram(0x20af3a40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.295 Debug: "exporting diagram \"PE-1102 Vávula e Rosca do Moinho\"" [ Diagram(0x212a7d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.306 Debug: "exporting diagram \"PE-1102 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x20381080) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.318 Debug: "exporting diagram \"PE-1102 Moinho\"" [ Diagram(0x2038c260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.329 Debug: "exporting diagram \"PE-1102 Exaustor\"" [ Diagram(0x21cf7500) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.339 Debug: "exporting diagram \"PE-1102 Vávula e Rosca da Empacotadora\"" [ Diagram(0x21efe7b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.348 Debug: "exporting diagram \"PE-1102 Vibradores\"" [ Diagram(0x220f3660) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.357 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X17)\"" [ Diagram(0x223c6010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.376 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X18)\"" [ Diagram(0x2271a950) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.397 Debug: "exporting diagram \"PE-1102 Comando Manual\"" [ Diagram(0x21c887a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.400 Debug: "exporting diagram \"QC Linha 02 Balança\"" [ Diagram(0x226ccc30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.407 Debug: "exporting diagram \"QC Linha 02 Comando\"" [ Diagram(0x22e1ab00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.418 Debug: "exporting diagram \"QC Linha 02 Régua de Bornes (X26)\"" [ Diagram(0x23002e60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.431 Debug: "exporting diagram \"PE-1101 Misturadores\"" [ Diagram(0x23557760) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.443 Debug: "exporting diagram \"PE-1101 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x226f2000) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.456 Debug: "exporting diagram \"PE-1101 Vávula e Rosca do Moinho\"" [ Diagram(0x238524e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.469 Debug: "exporting diagram \"PE-1101 Moinho\"" [ Diagram(0x23c585a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.482 Debug: "exporting diagram \"PE-1101 Exaustor\"" [ Diagram(0x23eae920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.493 Debug: "exporting diagram \"PE-1101 Vávula e Rosca da Empacotadora\"" [ Diagram(0x2426ba70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.507 Debug: "exporting diagram \"PE-1101 Vibradores\"" [ Diagram(0x23c5c580) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.513 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X19)\"" [ Diagram(0x24650530) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.528 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X20)\"" [ Diagram(0x2493f6f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.545 Debug: "exporting diagram \"PE-1101 Comando Manual\"" [ Diagram(0x250c5050) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.548 Debug: "exporting diagram \"QC Linha 01 Balança\"" [ Diagram(0x24cfe5e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.554 Debug: "exporting diagram \"QC Linha 01 Comando\"" [ Diagram(0x2514d3b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.564 Debug: "exporting diagram \"QC Linha 01 Régua de Bornes (X27)\"" [ Diagram(0x25006c90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.576 Debug: "exporting diagram \"\"" [ Diagram(0x250f70b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.576 Debug: "exporting diagram \"\"" [ Diagram(0x255b76f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2585ca30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x255c6fa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x25475590) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x255c28f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2577e5e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2578e800) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2579b070) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2579a440) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2578eec0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x257848e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x25797380) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x25787a80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.577 Debug: "exporting diagram \"\"" [ Diagram(0x2578adb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:19.578 Debug: "exporting diagram \"\"" [ Diagram(0x25786db0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:36.285 Debug: Leave mouse over (../../qet/sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent *))
21:35:36.293 Debug: Leave mouse over (../../qet/sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent *))
21:35:36.341 Debug: Leave mouse over (../../qet/sources/qetgraphicsitem/conductortextitem.cpp:254, virtual void ConductorTextItem::hoverLeaveEvent(QGraphicsSceneHoverEvent *))
21:35:55.504 Debug: Export XML de 115 schemas (../../qet/sources/qetproject.cpp:888, QDomDocument QETProject::toXml())
21:35:55.504 Debug: "exporting diagram \"Capa\"" [ Diagram(0x259ba90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.504 Debug: "exporting diagram \"Painel Geral QD-0023\"" [ Diagram(0x202aaa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.519 Debug: "exporting diagram \"PE-1106 Alimentação\"" [ Diagram(0x1480e350) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.536 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X6)\"" [ Diagram(0x1f00ea0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.541 Debug: "exporting diagram \"PE-1106 Distribuição 24Vcc\"" [ Diagram(0x1f69920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.559 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X3 e X4)\"" [ Diagram(0x1ed33a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.578 Debug: "exporting diagram \"PE-1106 Distribuição 24Vac\"" [ Diagram(0x18f9360) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.588 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X7 e X8)\"" [ Diagram(0x18a4980) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.600 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 01\"" [ Diagram(0x15ae1990) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.621 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 02\"" [ Diagram(0x15b84610) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.643 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 03\"" [ Diagram(0x15f38880) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.665 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 04\"" [ Diagram(0x1638afa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.675 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 05\"" [ Diagram(0x1636fd00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.694 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 06\"" [ Diagram(0x20acac0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.708 Debug: "exporting diagram \"PE-1106 Cartão 07\"" [ Diagram(0x16faefb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.711 Debug: "exporting diagram \"PE-1106 Bornes Disponíveis\"" [ Diagram(0x16fb1d70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.726 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/1)\"" [ Diagram(0x17114b30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.755 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/2)\"" [ Diagram(0x17a63780) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.783 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/1)\"" [ Diagram(0x17a53020) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.811 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/2)\"" [ Diagram(0x185da150) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.812 Debug: "exporting diagram \"PE-1100 Motor do Bland\"" [ Diagram(0x185d6ce0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.824 Debug: "exporting diagram \"PE-1100 Potência dos Vibradores\"" [ Diagram(0x187bcd10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.833 Debug: "exporting diagram \"PE-1100 Comando dos Vibradores\"" [ Diagram(0x18524d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.842 Debug: "exporting diagram \"PE-1100 Pulverizador Bland\"" [ Diagram(0x180fb0b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.849 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (01)\"" [ Diagram(0x18b0c260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.869 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (02)\"" [ Diagram(0x18f4a250) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.880 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (03)\"" [ Diagram(0x19117aa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.891 Debug: "exporting diagram \"PE-1100 Régua de bornes (X9)\"" [ Diagram(0x192ae920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.899 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/1)\"" [ Diagram(0x1934aa60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.921 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/2)\"" [ Diagram(0x19c6f330) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.943 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/3)\"" [ Diagram(0x18ddfc20) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.949 Debug: "exporting diagram \"QC do Bland Botoeiras\"" [ Diagram(0x1883a6c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.965 Debug: "exporting diagram \"QC do Bland Solenóides\"" [ Diagram(0x1a1adbd0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.974 Debug: "exporting diagram \"QC do Bland Sensores e Sinaleiros\"" [ Diagram(0x18832d00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.988 Debug: "exporting diagram \"QC do Bland Bornes Disponíveis\"" [ Diagram(0x1a8f1f90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:55.990 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/1)\"" [ Diagram(0x1a9f6730) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.012 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/2)\"" [ Diagram(0x1a9d8b00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.018 Debug: "exporting diagram \"PE-1105 Rosca Elevador\"" [ Diagram(0x1a9f8150) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.031 Debug: "exporting diagram \"PE-1105 Elevador\"" [ Diagram(0x1b127e10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.043 Debug: "exporting diagram \"PE-1105 Rosca Esteira\"" [ Diagram(0x1b4854f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.052 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Potência)\"" [ Diagram(0x1b6cbfa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.062 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Comando)\"" [ Diagram(0x1b4335a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.075 Debug: "exporting diagram \"PE-1105 Vibradores\"" [ Diagram(0x1b068e80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.085 Debug: "exporting diagram \"PE-1105 Sinaleiros e Moega\"" [ Diagram(0x1bf89340) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.088 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X11)\"" [ Diagram(0x1bed00e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.102 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X12)\"" [ Diagram(0x1be87200) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.116 Debug: "exporting diagram \"QC Vibradores moega do Bland\"" [ Diagram(0x1c80bda0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.126 Debug: "exporting diagram \"PE-1104 Misturadores\"" [ Diagram(0x1b045cc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.139 Debug: "exporting diagram \"PE-1104 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1ccbd680) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.152 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Moinho\"" [ Diagram(0x1ccc0010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.165 Debug: "exporting diagram \"PE-1104 Moinho\"" [ Diagram(0x1d1ae310) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.177 Debug: "exporting diagram \"PE-1104 Exaustor\"" [ Diagram(0x1d0488c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.187 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Empacotadora\"" [ Diagram(0x1d80c910) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.198 Debug: "exporting diagram \"PE-1104 Vibradores\"" [ Diagram(0x1d77dcd0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.206 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X13)\"" [ Diagram(0x1d632c40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.224 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X14)\"" [ Diagram(0x1df6de30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.243 Debug: "exporting diagram \"PE-1104 Comando Manual\"" [ Diagram(0x1e166930) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.246 Debug: "exporting diagram \"QC Linha 04 Balança\"" [ Diagram(0x1d0165b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.252 Debug: "exporting diagram \"QC Linha 04 Comando\"" [ Diagram(0x1e7cdad0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.264 Debug: "exporting diagram \"QC Linha 04 Régua de Bornes (X24)\"" [ Diagram(0x1e9d9af0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.277 Debug: "exporting diagram \"PE-1103 Misturadores\"" [ Diagram(0x1e7a3ea0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.289 Debug: "exporting diagram \"PE-1103 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1ee50df0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.307 Debug: "exporting diagram \"PE-1103 Vávula e Rosca do Moinho\"" [ Diagram(0x1f238cc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.329 Debug: "exporting diagram \"PE-1103 Moinho\"" [ Diagram(0x1f4323c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.348 Debug: "exporting diagram \"PE-1103 Exaustor\"" [ Diagram(0x1f8ce230) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.368 Debug: "exporting diagram \"PE-1103 Vávula e Rosca da Empacotadora\"" [ Diagram(0x1fbbf610) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.387 Debug: "exporting diagram \"PE-1103 Vibradores\"" [ Diagram(0x1f859930) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.398 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X15)\"" [ Diagram(0x14ded080) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.419 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X16)\"" [ Diagram(0x203590a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.440 Debug: "exporting diagram \"PE-1103 Comando Manual\"" [ Diagram(0x209c86b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.443 Debug: "exporting diagram \"QC Linha 03 Balança\"" [ Diagram(0x203599e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.451 Debug: "exporting diagram \"QC Linha 03 Comando\"" [ Diagram(0x20a951c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.462 Debug: "exporting diagram \"QC Linha 03 Régua de Bornes (X25)\"" [ Diagram(0x20a3b6b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.477 Debug: "exporting diagram \"PE-1102 Misturadores\"" [ Diagram(0x20af3a40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.496 Debug: "exporting diagram \"PE-1102 Vávula e Rosca do Moinho\"" [ Diagram(0x212a7d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.508 Debug: "exporting diagram \"PE-1102 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x20381080) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.521 Debug: "exporting diagram \"PE-1102 Moinho\"" [ Diagram(0x2038c260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.537 Debug: "exporting diagram \"PE-1102 Exaustor\"" [ Diagram(0x21cf7500) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.547 Debug: "exporting diagram \"PE-1102 Vávula e Rosca da Empacotadora\"" [ Diagram(0x21efe7b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.557 Debug: "exporting diagram \"PE-1102 Vibradores\"" [ Diagram(0x220f3660) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.566 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X17)\"" [ Diagram(0x223c6010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.583 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X18)\"" [ Diagram(0x2271a950) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.601 Debug: "exporting diagram \"PE-1102 Comando Manual\"" [ Diagram(0x21c887a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.604 Debug: "exporting diagram \"QC Linha 02 Balança\"" [ Diagram(0x226ccc30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.610 Debug: "exporting diagram \"QC Linha 02 Comando\"" [ Diagram(0x22e1ab00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.620 Debug: "exporting diagram \"QC Linha 02 Régua de Bornes (X26)\"" [ Diagram(0x23002e60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.632 Debug: "exporting diagram \"PE-1101 Misturadores\"" [ Diagram(0x23557760) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.643 Debug: "exporting diagram \"PE-1101 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x226f2000) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.659 Debug: "exporting diagram \"PE-1101 Vávula e Rosca do Moinho\"" [ Diagram(0x238524e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.680 Debug: "exporting diagram \"PE-1101 Moinho\"" [ Diagram(0x23c585a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.696 Debug: "exporting diagram \"PE-1101 Exaustor\"" [ Diagram(0x23eae920) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.706 Debug: "exporting diagram \"PE-1101 Vávula e Rosca da Empacotadora\"" [ Diagram(0x2426ba70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.717 Debug: "exporting diagram \"PE-1101 Vibradores\"" [ Diagram(0x23c5c580) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.723 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X19)\"" [ Diagram(0x24650530) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.737 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X20)\"" [ Diagram(0x2493f6f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.755 Debug: "exporting diagram \"PE-1101 Comando Manual\"" [ Diagram(0x250c5050) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.758 Debug: "exporting diagram \"QC Linha 01 Balança\"" [ Diagram(0x24cfe5e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.764 Debug: "exporting diagram \"QC Linha 01 Comando\"" [ Diagram(0x2514d3b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.774 Debug: "exporting diagram \"QC Linha 01 Régua de Bornes (X27)\"" [ Diagram(0x25006c90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.786 Debug: "exporting diagram \"\"" [ Diagram(0x250f70b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x255b76f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x2585ca30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x255c6fa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x25475590) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x255c28f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x2577e5e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x2578e800) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x2579b070) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x2579a440) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x2578eec0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x257848e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x25797380) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.787 Debug: "exporting diagram \"\"" [ Diagram(0x25787a80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.788 Debug: "exporting diagram \"\"" [ Diagram(0x2578adb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
21:35:56.788 Debug: "exporting diagram \"\"" [ Diagram(0x25786db0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
testing QT Performance Analyzer wait.......
Re: Problem opening file
it is difficult to show, but the first pages are the longest
the photo shows the transition
If you open file with text editor you saw many blank ...
it is the making of the elements
this is from 1 sheet
Screenshot_20201210_222346.png, 24.89 kb, 598 x 193
element name="transformateur_courant1.elmt.elmt
this is a fantastic file for stressing qelectrotech
Yes same here on my Threadripper workstation is very slow to launch and saw many freeze when you move through the tabs..
https://download.qelectrotech.org/qet/forum_img_2/qet_freeze.png
10 (edited by De-Backer 2020-12-11 00:14:40)
I'll have Kate clean up the file
4 466 827 error
can I send the bill for the cpu use nomicons/tongue
<informations>Author: The QElectroTech team License: see http://qelectrotech.org/wiki/doc/elements_license</informations>
was
https://download.qelectrotech.org/qet/f … Moagem.zip
test new file:
23:16:59.573 Info: Start-up
23:16:59.604 Info: debugging enabled: false
23:16:59.604 Info: Qt library version: 5.15.1
23:16:59.604 Info: Qt library location default prefix: "/home/simon/Qt/5.15.1/gcc_64"
23:16:59.604 Info: Qt library location documentation: "/home/simon/Qt/5.15.1/gcc_64/doc"
23:16:59.604 Info: Qt library location headers: "/home/simon/Qt/5.15.1/gcc_64/include"
23:16:59.604 Info: Qt library location libraries: "/home/simon/Qt/5.15.1/gcc_64/lib"
23:16:59.604 Info: Qt library location executables: "/home/simon/Qt/5.15.1/gcc_64/libexec"
23:16:59.604 Info: Qt library location Qt binaries: "/home/simon/Qt/5.15.1/gcc_64/bin"
23:16:59.605 Info: Qt library location Qt plugins: "/home/simon/Qt/5.15.1/gcc_64/plugins"
23:16:59.605 Info: Qt library location installed QML extensions: "/home/simon/Qt/5.15.1/gcc_64/imports"
23:16:59.605 Info: Qt library location installed QML extensions: "/home/simon/Qt/5.15.1/gcc_64/qml"
23:16:59.605 Info: Qt library location dependent Qt data: "/home/simon/Qt/5.15.1/gcc_64"
23:16:59.605 Info: Qt library location independent Qt data: "/home/simon/Qt/5.15.1/gcc_64"
23:16:59.605 Info: Qt library location translation: "/home/simon/Qt/5.15.1/gcc_64/translations"
23:16:59.605 Info: Qt library location examples: "/home/simon/Qt/5.15.1/gcc_64/examples"
23:16:59.605 Info: Qt library location Qt testcases: "/home/simon/Qt/5.15.1/gcc_64/tests"
23:16:59.605 Info: Qt library location Qt settings: "/etc/xdg"
23:16:59.605 Info: "GitRevision ed938c82cd15e9c319e1a0ca481a0ebafd7049bc"
23:16:59.605 Info: "QElectroTech V 0.80-rc"
23:16:59.605 Info: "Compilatie: GCC Clang 11.0.0"
23:16:59.605 Info: "Built with Qt 5.15.1 - Date : Dec 10 2020 : 21:17:48"
23:16:59.605 Info: "Run with Qt 5.15.1 using 16 thread(s)"
23:16:59.605 Info: "CPU : model name\t: AMD Ryzen 7 3700X 8-Core Processor\n"
23:16:59.605 Info: "RAM Total : 32026 MB"
23:16:59.605 Info: "RAM Available : 17515 MB"
23:16:59.605 Info: "GPU : "
23:16:59.605 Info: "GPU RAM : @ToDo"
23:16:59.605 Info: "OS : linux  - x86_64 - Version : openSUSE Tumbleweed - Kernel : 5.9.12-1-default"
23:16:59.605 Info: *** Qt screens ***
23:16:59.605 Info: "( 1 : 3840 x 2160 )"
23:16:59.880 Info: Elements collection reload
23:17:00.439 Info: Elements collection finished to be loaded
23:17:08.755 Debug: is QRegularExpression ok? (../../qet/sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString &))
23:17:08.759 Debug: is QRegularExpression ok? (../../qet/sources/titleblocktemplate.cpp:437, void TitleBlockTemplate::parseColumns(const QString &))
23:17:12.182 Debug: Diagram::fromXml() : Le chargement des parametres d'un element a echoue (../../qet/sources/diagram.cpp:1329, bool Diagram::fromXml(QDomElement &, QPointF, bool, DiagramContent *))
23:17:27.159 Debug: Export XML de 115 schemas (../../qet/sources/qetproject.cpp:888, QDomDocument QETProject::toXml())
23:17:27.305 Debug: "exporting diagram \"Capa\"" [ Diagram(0x22877a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.309 Debug: "exporting diagram \"Painel Geral QD-0023\"" [ Diagram(0x20d3720) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.335 Debug: "exporting diagram \"PE-1106 Alimentação\"" [ Diagram(0x2006660) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.354 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X6)\"" [ Diagram(0x1464e200) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.358 Debug: "exporting diagram \"PE-1106 Distribuição 24Vcc\"" [ Diagram(0x14545480) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.375 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X3 e X4)\"" [ Diagram(0x14409770) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.397 Debug: "exporting diagram \"PE-1106 Distribuição 24Vac\"" [ Diagram(0x20d50a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.407 Debug: "exporting diagram \"PE-1106 Régua de Bornes (X7 e X8)\"" [ Diagram(0x150c50e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.418 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 01\"" [ Diagram(0x1e5b890) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.438 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 02\"" [ Diagram(0x154f8c00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.460 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 03\"" [ Diagram(0x1950820) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.481 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 04\"" [ Diagram(0x15e05490) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.489 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 05\"" [ Diagram(0x16107020) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.508 Debug: "exporting diagram \"PE-1106 Interfaces Cartão 06\"" [ Diagram(0x164d6470) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.521 Debug: "exporting diagram \"PE-1106 Cartão 07\"" [ Diagram(0x1632af10) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.524 Debug: "exporting diagram \"PE-1106 Bornes Disponíveis\"" [ Diagram(0x16a06e60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.539 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/1)\"" [ Diagram(0x161397d0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.568 Debug: "exporting diagram \"PE-1106 Régua de bornes (X22/2)\"" [ Diagram(0x172b1e00) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.597 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/1)\"" [ Diagram(0x1a5d750) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.625 Debug: "exporting diagram \"PE-1106 Régua de bornes (X32/2)\"" [ Diagram(0x17df40c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.626 Debug: "exporting diagram \"PE-1100 Motor do Bland\"" [ Diagram(0x17e05330) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.639 Debug: "exporting diagram \"PE-1100 Potência dos Vibradores\"" [ Diagram(0x180f6820) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.648 Debug: "exporting diagram \"PE-1100 Comando dos Vibradores\"" [ Diagram(0x16a47f80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.657 Debug: "exporting diagram \"PE-1100 Pulverizador Bland\"" [ Diagram(0x184ee840) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.664 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (01)\"" [ Diagram(0x186b3960) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.684 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (02)\"" [ Diagram(0x187a4b20) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.696 Debug: "exporting diagram \"PE-1100 Passagem do QC Bland (03)\"" [ Diagram(0x18accee0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.706 Debug: "exporting diagram \"PE-1100 Régua de bornes (X9)\"" [ Diagram(0x18e3a1e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.714 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/1)\"" [ Diagram(0x172733a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.736 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/2)\"" [ Diagram(0x19527840) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.758 Debug: "exporting diagram \"PE-1100 Régua de Bornes (X10/3)\"" [ Diagram(0x19b46b70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.764 Debug: "exporting diagram \"QC do Bland Botoeiras\"" [ Diagram(0x19ab40e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.780 Debug: "exporting diagram \"QC do Bland Solenóides\"" [ Diagram(0x19c0e710) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.790 Debug: "exporting diagram \"QC do Bland Sensores e Sinaleiros\"" [ Diagram(0x19ec1640) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.808 Debug: "exporting diagram \"QC do Bland Bornes Disponíveis\"" [ Diagram(0x1a336300) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.810 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/1)\"" [ Diagram(0x1a444ab0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.836 Debug: "exporting diagram \"QC do Bland Régua de Bornes (X5/2)\"" [ Diagram(0x19f84b60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.842 Debug: "exporting diagram \"PE-1105 Rosca Elevador\"" [ Diagram(0x1a446800) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.855 Debug: "exporting diagram \"PE-1105 Elevador\"" [ Diagram(0x1ab73aa0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.868 Debug: "exporting diagram \"PE-1105 Rosca Esteira\"" [ Diagram(0x1aef2f60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.879 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Potência)\"" [ Diagram(0x1add0840) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.889 Debug: "exporting diagram \"PE-1105 Esteira de Alimentação (Comando)\"" [ Diagram(0x1ad8c4b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.907 Debug: "exporting diagram \"PE-1105 Vibradores\"" [ Diagram(0x1b6bfc70) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.915 Debug: "exporting diagram \"PE-1105 Sinaleiros e Moega\"" [ Diagram(0x1b86ba90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.919 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X11)\"" [ Diagram(0x1abd6450) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.933 Debug: "exporting diagram \"PE-1105 Régua de Bornes Bornes (X12)\"" [ Diagram(0x1bf5f680) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.947 Debug: "exporting diagram \"QC Vibradores moega do Bland\"" [ Diagram(0x1c25d620) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.957 Debug: "exporting diagram \"PE-1104 Misturadores\"" [ Diagram(0x1c2452c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.970 Debug: "exporting diagram \"PE-1104 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1c70db40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.983 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Moinho\"" [ Diagram(0x1c70ed20) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:27.996 Debug: "exporting diagram \"PE-1104 Moinho\"" [ Diagram(0x1cd664b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.009 Debug: "exporting diagram \"PE-1104 Exaustor\"" [ Diagram(0x1cfa8940) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.019 Debug: "exporting diagram \"PE-1104 Vávula e Rosca do Empacotadora\"" [ Diagram(0x1d09f3c0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.030 Debug: "exporting diagram \"PE-1104 Vibradores\"" [ Diagram(0x1d2fcca0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.038 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X13)\"" [ Diagram(0x1d7d5d80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.057 Debug: "exporting diagram \"PE-1104 Régua de Bornes (X14)\"" [ Diagram(0x1dd26470) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.076 Debug: "exporting diagram \"PE-1104 Comando Manual\"" [ Diagram(0x1e1490d0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.079 Debug: "exporting diagram \"QC Linha 04 Balança\"" [ Diagram(0x1dfe5720) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.086 Debug: "exporting diagram \"QC Linha 04 Comando\"" [ Diagram(0x1e1731e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.097 Debug: "exporting diagram \"QC Linha 04 Régua de Bornes (X24)\"" [ Diagram(0x1e4296e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.111 Debug: "exporting diagram \"PE-1103 Misturadores\"" [ Diagram(0x1e8a53f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.123 Debug: "exporting diagram \"PE-1103 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x1e938850) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.136 Debug: "exporting diagram \"PE-1103 Vávula e Rosca do Moinho\"" [ Diagram(0x1eb79820) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.148 Debug: "exporting diagram \"PE-1103 Moinho\"" [ Diagram(0x1effbb90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.160 Debug: "exporting diagram \"PE-1103 Exaustor\"" [ Diagram(0x1f365a40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.171 Debug: "exporting diagram \"PE-1103 Vávula e Rosca da Empacotadora\"" [ Diagram(0x1f60dc60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.181 Debug: "exporting diagram \"PE-1103 Vibradores\"" [ Diagram(0x1f60edc0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.191 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X15)\"" [ Diagram(0x1f51eb20) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.209 Debug: "exporting diagram \"PE-1103 Régua de Bornes (X16)\"" [ Diagram(0x1f2aa140) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.227 Debug: "exporting diagram \"PE-1103 Comando Manual\"" [ Diagram(0x1ef07760) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.230 Debug: "exporting diagram \"QC Linha 03 Balança\"" [ Diagram(0x20479010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.237 Debug: "exporting diagram \"QC Linha 03 Comando\"" [ Diagram(0x20523180) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.247 Debug: "exporting diagram \"QC Linha 03 Régua de Bornes (X25)\"" [ Diagram(0x1ce46a40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.260 Debug: "exporting diagram \"PE-1102 Misturadores\"" [ Diagram(0x20c13470) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.272 Debug: "exporting diagram \"PE-1102 Vávula e Rosca do Moinho\"" [ Diagram(0x20ef1c90) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.285 Debug: "exporting diagram \"PE-1102 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x20fa6ff0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.298 Debug: "exporting diagram \"PE-1102 Moinho\"" [ Diagram(0x2121ab80) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.310 Debug: "exporting diagram \"PE-1102 Exaustor\"" [ Diagram(0x215c1140) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.321 Debug: "exporting diagram \"PE-1102 Vávula e Rosca da Empacotadora\"" [ Diagram(0x219463e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.331 Debug: "exporting diagram \"PE-1102 Vibradores\"" [ Diagram(0x21babcb0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.341 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X17)\"" [ Diagram(0x21be7160) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.358 Debug: "exporting diagram \"PE-1102 Régua de Bornes (X18)\"" [ Diagram(0x22368e40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.378 Debug: "exporting diagram \"PE-1102 Comando Manual\"" [ Diagram(0x224b6110) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.382 Debug: "exporting diagram \"QC Linha 02 Balança\"" [ Diagram(0x21bc2df0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.389 Debug: "exporting diagram \"QC Linha 02 Comando\"" [ Diagram(0x228aeb30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.404 Debug: "exporting diagram \"QC Linha 02 Régua de Bornes (X26)\"" [ Diagram(0x22c28d30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.418 Debug: "exporting diagram \"PE-1101 Misturadores\"" [ Diagram(0x22f97840) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.431 Debug: "exporting diagram \"PE-1101 Nível / Sinaleiro / Exaustão\"" [ Diagram(0x22fece30) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.444 Debug: "exporting diagram \"PE-1101 Vávula e Rosca do Moinho\"" [ Diagram(0x233e4770) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.457 Debug: "exporting diagram \"PE-1101 Moinho\"" [ Diagram(0x22b19560) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.471 Debug: "exporting diagram \"PE-1101 Exaustor\"" [ Diagram(0x21b654f0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.482 Debug: "exporting diagram \"PE-1101 Vávula e Rosca da Empacotadora\"" [ Diagram(0x23c56750) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.494 Debug: "exporting diagram \"PE-1101 Vibradores\"" [ Diagram(0x23f57780) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.500 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X19)\"" [ Diagram(0x23f3f810) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.517 Debug: "exporting diagram \"PE-1101 Régua de Bornes (X20)\"" [ Diagram(0x246bf010) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.536 Debug: "exporting diagram \"PE-1101 Comando Manual\"" [ Diagram(0x249b7720) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.539 Debug: "exporting diagram \"QC Linha 01 Balança\"" [ Diagram(0x23e33a50) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.546 Debug: "exporting diagram \"QC Linha 01 Comando\"" [ Diagram(0x24bcc260) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.556 Debug: "exporting diagram \"QC Linha 01 Régua de Bornes (X27)\"" [ Diagram(0x24e04a40) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.570 Debug: "exporting diagram \"\"" [ Diagram(0x219531e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.570 Debug: "exporting diagram \"\"" [ Diagram(0x252a86e0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.570 Debug: "exporting diagram \"\"" [ Diagram(0x218eb4b0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.570 Debug: "exporting diagram \"\"" [ Diagram(0x2152b740) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x25021500) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x2501bb60) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x25024250) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251d80a0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x25025180) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251de660) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251df070) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251d0df0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x25017480) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251e4430) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251f7620) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:28.571 Debug: "exporting diagram \"\"" [ Diagram(0x251fc6d0) ] (../../qet/sources/qetproject.cpp:893, QDomDocument QETProject::toXml())
23:17:29.484 Info: Elements collection finished to be loaded
23:18:04.608 Warning: QWidget::setLayout: Attempting to set QLayout "" on StyleEditor "", which already has a layout (:0, )
23:18:04.615 Warning: QWidget::setLayout: Attempting to set QLayout "" on StyleEditor "", which already has a layout (:0, )
23:18:04.620 Warning: QWidget::setLayout: Attempting to set QLayout "" on StyleEditor "", which already has a layout (:0, )
23:18:04.625 Warning: QWidget::setLayout: Attempting to set QLayout "" on StyleEditor "", which already has a layout (:0, )
23:18:04.628 Warning: QWidget::setLayout: Attempting to set QLayout "" on StyleEditor "", which already has a layout (:0, )
23:18:04.631 Warning: QWidget::setLayout: Attempting to set QLayout "" on StyleEditor "", which already has a layout (:0, )
i wonder if this is the problem,
if this is full of enters then you can get this
Screenshot_20201210_232509.png, 79.47 kb, 1072 x 823
https://i.chzbgr.com/full/9157105920/h9E08B443/zone-where-theyre-not-expending-energy-to-cool-off-or-get-warm-is-between-85-and-100-degrees
Use this fake laptop for your cat, uhu.
https://i.pinimg.com/564x/bd/75/30/bd75308c860ec343f1df2870c952a2bd.jpg
could it be?
De-Backer wrote:
could it be?
Maybe palhenrique fell asleep on keyboard him or his cat ...  nomicons/smiley-green   I saw 1 million carriage returns in this file. and a lot off blank lines ..
I don't know how programming works. But, while editing the project, components were added and removed. Pages have also been removed.
The plug-in for creating the terminals has been executed several times.
I don't know if this information helps.
Ahhh. I do not have
cats ... lol
kkkkkkk
But perhaps the problem is on the first few pages due to more qet_tb execution than the last ones. For more saves and shipments.
in fairness, this could be a serious bug
it is possible but it remains difficult for us to find this in 123
This file opened quickly in QElectroTech V 0.70 + a375424c0d79751d3. However, it freezes after editing and then closes.
23 (edited by palhenrique 2020-12-15 20:04:46)
Hi De-Backer. The file you sent is infinitely faster compared to the one I sent.
Thank you very much. I will continue the project thanks to you and Scorpio810.
Unfortunately, I don't know what happened to get to the point of freezing. This is the biggest diagram I have. Soon I will be working on another project as big as. I keep you informed.
When using qet_tb_generator the cable column has no more data. It would have been the cleaning Scorpio did.
What can I do to not lose this information?
Qet_tb_generator 1.7.png, 194.64 kb, 1440 x 900
