Topic: transferring elements in a project between folios
Good afternoon, colleagues.
I couldn't find information on transferring an item in the same project between folios. How do I do this?
I have a group of elements I need to move them to another folio, and so that the information, cross-references remain, is this possible?
Re: transferring elements in a project between folios
I could be wrong, but copy / paste removes information cross-references deliberately in the code.
=> uses a text editor and copy at hand.
this is bad and inconvenient, sometimes you need to move the element ( just move(cut/paste) and not copy), you have to do it all over again
A function to do this would be valuable nomicons/smile
Also block duplicate, where connectionsbetween elements in the block are duplicated.
Maybe move could be a subset of same code as duplicate.
you may find it here,
https://git.tuxfamily.org/qet/qet.git/t … w.cpp#n195
it may also be that I am completely wrong nomicons/unsure
but even if you want to change this what should be the default function and how do you switch between
this may already be in there
first line
Screenshot_20201116_203031.png, 43.48 kb, 1022 x 243
