Topic: Conductor Label text
Hello all,
I am newe in your forum, as I am new also in your software.
I would like to try if it fits what I currently need.
As a new one, I have many doubts and I tried to solve it thru this forum and user manual.
I am designing a broadcast facilities. I was using a CAD software, but I want to improve it, and I was wondering if QET could fits it.
To do it, I need to connect many devices with many ports, and define the type of conductor (Video Cable, Network Cable, Fiber optic cable...). And name it in both sides. After the schematic, a cable list is generated with following information: Equipment source, place of equipment source, port source, cable number or designator, and equipment destination, place destination, port destination... I see in your forum that this file could not be generated unfortunately, but I am wondering about other needs:
Labels in the schematic: I need to have the labels for each conductor in both sides, close to the ports, as the screenshot I see in your webpage. This is one of the most important, because could be a mesh for me if I can't.
Define different conductor type, and this will define de cable designator. Sometimes, the connection is not in the same sheet, is it possible to reference different sheets?
Many thanks
Re: Conductor Label text
Hi Jordi and welcome,
maybe like  this example?
https://download.qelectrotech.org/qet/s … energy.pdf
https://download.qelectrotech.org/qet/s … %d0%b0.pdf
https://download.qelectrotech.org/qet/schemas_pdf/
Hi @scorpio810,
Many thanks! yes, many of what I need are in this examples. I should to have a look into it.
Regarding the cable/conductor list, nothing to do,right?
Thanks again!
For now in 0.8-dev version you can just export to csv conductors list.
See https://qelectrotech.org/forum/viewtopic.php?id=1496
Thanks,
Now, I need to learn french...
I see another old post regarding the labels/names in conductors:
https://qelectrotech.org/forum/viewtopic.php?id=1194
Is it already possible?
Many thanks.
