Topic: can we perform an element check when selecting or loading the element?
for the following error see https://qelectrotech.org/forum/viewtopic.php?id=1780
Calypso wrote:
each connection is given its own identification when it is inserted into a symbol. With your symbols it looks like the connectors have been copied and then pasted because the identifications are duplicated. As far as I know, this problem has been fixed (current version).
sincerely yours
Stebo
it is more convenient if Qet can already report these errors
2 (edited by De-Backer 2020-09-01 21:31:47)
Re: can we perform an element check when selecting or loading the element?
and for the main element lib, can we (dev team) check this ourselves quickly?
eg: run a shell file.
grep -w -R '<terminal' ~/GIT/qet/elements/* > list.xml
grep -w -R ' uuid=' list.xml > list_tot.xml
I get to a list with grep
this is a part
qet/elements/10_electric/10_allpole/310_relays_contactors&contacts/01_coils/timer816.elmt:        <terminal name="" y="-15" orientation="n" uuid="{46ca50be-4ef1-4d74-be46-dc0715a4ade7}" x="-10"/>
qet/elements/10_electric/10_allpole/310_relays_contactors&contacts/01_coils/timer816.elmt:        <terminal name="" y="-15" orientation="n" uuid="{dd0b15b5-4a54-4b8a-aef2-aac5d0cc34d5}" x="0"/>
qet/elements/10_electric/10_allpole/310_relays_contactors&contacts/01_coils/timer816.elmt:        <terminal name="" y="15" orientation="s" uuid="{4cb91363-bfe0-4c8c-b72c-98e3d0f395f0}" x="0"/>
qet/elements/10_electric/10_allpole/310_relays_contactors&contacts/01_coils/tmr48.elmt:        <terminal name="" y="-15" orientation="n" uuid="{2cab732d-93cc-43e6-84d7-48ded4ee3017}" x="0"/>
qet/elements/10_electric/10_allpole/310_relays_contactors&contacts/01_coils/tmr48.elmt:        <terminal name="" y="-15" orientation="n" uuid="{678476ba-0a47-480b-b4ad-9c0c68ec4782}" x="-10"/>
qet/elements/10_electric/10_allpole/310_relays_contactors&contacts/01_coils/tmr48.elmt:        <terminal name="" y="15" orientation="s" uuid="{4df61e5b-a18a-46e2-bff9-c1ba9c5ea7b4}" x="0"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="0" y="-20" orientation="n" uuid="{3df8699b-43a1-49c1-b3fa-7d796925f1ba}"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="20" y="-20" orientation="n" uuid="{982f8530-4d05-4898-98d8-eff984bdee69}"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="40" y="-21" orientation="n" uuid="{c2f4a1a9-a2d0-4b8c-bfcf-21b3fc086a1a}"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="20" y="10" orientation="s" uuid="{4f7f506e-bf2f-4d24-ba5b-c00b97944b25}"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="0" y="10" orientation="s" uuid="{0aaa2455-818f-4d41-a60a-7c49c97624fa}"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="40" y="9.96107" orientation="s" uuid="{854f00a1-93ca-48e3-9084-f000c7d94518}"/>
qet/elements/10_electric/10_allpole/330_transformers&power_supplies/10_transformers/tranfo230_400_12_24.elmt:        <terminal name="" x="20" y="9.96107" orientation="s" uuid="{c3b19e93-736b-4fd4-9575-1ab895e8b007}"/>
qet/elements/10_electric/10_allpole/390_sensors&instruments/04_sensors_optical/crepuscolar.elmt:        <terminal x="33" name="" y="16" uuid="{18296c32-8291-41de-85ac-8ee71221d60e}" orientation="e"/>
qet/elements/10_electric/10_allpole/390_sensors&instruments/04_sensors_optical/crepuscolar.elmt:        <terminal x="33" name="" y="-16" uuid="{d3fb1f4c-3acb-4e24-89de-864cb3d8ce51}" orientation="e"/>
qet/elements/10_electric/10_allpole/390_sensors&instruments/04_sensors_optical/crepuscolar.elmt:        <terminal x="33" name="" y="0" uuid="{622be5b4-4bc6-447c-88f4-183b11f48438}" orientation="e"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/10_engines/moteurmono3.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{b9e2135d-c4f6-453b-b5b4-2ba35162e5c3}"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/10_engines/moteurmono3.elmt:        <terminal orientation="s" name="" x="-10" y="25" uuid="{11d03113-9117-44b4-ba52-31c187dbaea2}"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/10_engines/moteurmono3.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{680a5950-c6c5-4cd3-b778-8728fc66fa02}"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/60_lightings/crepuscolar.elmt:        <terminal x="33" name="" y="16" uuid="{18296c32-8291-41de-85ac-8ee71221d60e}" orientation="e"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/60_lightings/crepuscolar.elmt:        <terminal x="33" name="" y="-16" uuid="{d3fb1f4c-3acb-4e24-89de-864cb3d8ce51}" orientation="e"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/60_lightings/crepuscolar.elmt:        <terminal x="33" name="" y="0" uuid="{622be5b4-4bc6-447c-88f4-183b11f48438}" orientation="e"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v -2.elmt:        <terminal y="-10" uuid="{25856fc8-a4f9-424d-8ce9-2c622b33a013}" x="-20" orientation="n" name=""/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v -2.elmt:        <terminal y="-10" uuid="{e1ff28ca-3f4b-472b-9242-32632655ab02}" x="-40" orientation="n" name=""/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v -2.elmt:        <terminal y="-10" uuid="{273ab8b4-9e35-446a-a0e5-8588738dbd61}" x="40" orientation="n" name=""/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v -2.elmt:        <terminal y="-10" uuid="{2cd0f02f-9fc9-488f-b0b5-506296460149}" x="20" orientation="n" name=""/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v -2.elmt:        <terminal y="-10" uuid="{bc4a4212-db22-4cbe-94f2-f9cb1ca5e2f5}" x="0" orientation="n" name=""/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v.elmt:        <terminal name="" y="-10" x="40" orientation="n" uuid="{273ab8b4-9e35-446a-a0e5-8588738dbd61}"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v.elmt:        <terminal name="" y="-10" x="-40" orientation="n" uuid="{e1ff28ca-3f4b-472b-9242-32632655ab02}"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v.elmt:        <terminal name="" y="-10" x="20" orientation="n" uuid="{2cd0f02f-9fc9-488f-b0b5-506296460149}"/>
qet/elements/10_electric/10_allpole/391_consumers&actuators/70_servomoteur/v2v.elmt:        <terminal name="" y="-10" x="-20" orientation="n" uuid="{25856fc8-a4f9-424d-8ce9-2c622b33a013}"/>
qet/elements/10_electric/10_allpole/395_electronics&semiconductors/31_integrated_circuits/78xx.elmt:        <terminal orientation="s" x="0" uuid="{1172f0ce-993f-4023-abb6-c00a3e190629}" y="20" name=""/>
qet/elements/10_electric/10_allpole/395_electronics&semiconductors/31_integrated_circuits/78xx.elmt:        <terminal orientation="s" x="10" uuid="{cb98556d-792d-4c8b-9187-d12608882c9b}" y="20" name=""/>
qet/elements/10_electric/10_allpole/395_electronics&semiconductors/31_integrated_circuits/78xx.elmt:        <terminal orientation="s" x="-10" uuid="{6d0dfdc6-2d90-4470-af17-02b20d615a0f}" y="20" name=""/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/alarme.elmt:        <terminal orientation="n" name="" x="60" y="-180" uuid="{8a24b0e5-af93-4b55-a585-2735bf871b4e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/alarme.elmt:        <terminal orientation="s" name="" x="50" y="-110" uuid="{492f48b8-61d9-422e-9ca3-9c1c14be9321}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/alarme.elmt:        <terminal orientation="n" name="" x="40" y="-180" uuid="{1c88072a-41a6-4742-a8bc-2edc31b8c112}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/antenne.elmt:        <terminal orientation="s" x="60" name="" y="-110" uuid="{512f7c12-3641-44a1-993f-a6cca9f2b375}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/antenne.elmt:        <terminal orientation="n" x="50" name="" y="-160" uuid="{a7186089-1b70-4a30-b3a8-1a23d89abb2e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/antenne.elmt:        <terminal orientation="n" x="70" name="" y="-160" uuid="{26208b89-66a0-4ff8-a5e4-d5da7fa4eed7}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_chauffage.elmt:        <terminal x="10" y="-14" orientation="n" uuid="{f112c459-f423-41ac-9652-9c30ea0ed0b5}" name=""/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_chauffage.elmt:        <terminal x="-10" y="-14" orientation="n" uuid="{7869b2d0-e245-4bf9-86dc-d3be70d93aaf}" name=""/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_chauffage_a_accumulation.elmt:        <terminal x="-10" y="-14" orientation="n" uuid="{4f998512-2f26-4c17-bd0c-2bcf1acbb41f}" name=""/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_chauffage_a_accumulation.elmt:        <terminal x="10" y="-14" orientation="n" uuid="{4f998512-2f26-4c17-bd0c-2bcf1acbb41f}" name=""/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_cuisson.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{d23d5d6a-748b-48d2-a474-1d0a864cf539}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_cuisson.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{701b0f84-6e94-4e95-90c6-c3c99772b23e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_de_cuisson.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{55aa6d67-e3c4-4b76-9d08-05bf5fc819bd}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_electromenager.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{f406d716-7aa1-4e8f-a89e-1e6e59511d19}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_electromenager.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{0e0f9fc5-4eda-43b8-869e-4961bf1cf69e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/appareil_electromenager.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{9879b02c-8516-4315-93a8-be77fd0e4d9e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/armoire_seche_linge.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{77acd157-1173-402e-9413-595418ceee77}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/armoire_seche_linge.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{d97c53e8-65d0-463a-8f18-9401a58b8505}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/armoire_seche_linge.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{38c6fa73-fb9d-40ca-9e0c-9d36d1b10e40}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/arrosage-auto.elmt:        <terminal orientation="n" name="" x="50" y="-170" uuid="{93358b8a-3493-4b52-bfd9-baa2684bb631}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/arrosage-auto.elmt:        <terminal orientation="n" name="" x="70" y="-170" uuid="{4e7c8c50-f27c-43ed-b45d-91d7946a0ded}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat-ext.elmt:        <terminal orientation="n" name="" x="50" y="-180" uuid="{723765bc-b612-4e1a-92ef-567119429f9d}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat-ext.elmt:        <terminal orientation="n" name="" x="70" y="-180" uuid="{8c1aa559-1491-45cb-aa15-e8bbff0f376e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat-ext.elmt:        <terminal orientation="s" name="" x="60" y="-100" uuid="{68237cd7-8357-4a9c-8e50-9f8f1d6debe7}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_mono.elmt:        <terminal y="-100" x="60" name="" orientation="s" uuid="{7952be86-3060-4cc0-a781-ac00d7e59a10}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_mono.elmt:        <terminal y="-170" x="70" name="" orientation="n" uuid="{2c7f1e9b-9e1f-4e67-b3f6-57af9d1e7f67}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_mono.elmt:        <terminal y="-170" x="50" name="" orientation="n" uuid="{523f90d3-a9c6-4f37-a8c3-a96ba3d9e03d}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_tetra.elmt:        <terminal orientation="n" x="70" name="" y="-170" uuid="{ec57a9a7-8d5e-4732-a80c-83c85021092b}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_tetra.elmt:        <terminal orientation="n" x="30" name="" y="-170" uuid="{19497264-2af0-4205-b907-99031a635c85}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_tetra.elmt:        <terminal orientation="n" x="90" name="" y="-170" uuid="{8de1c58e-eaa6-4cf4-9e39-eacc3a4576ef}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_tetra.elmt:        <terminal orientation="s" x="60" name="" y="-100" uuid="{925343e0-1d6c-4115-bf99-c0855e070aef}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_ext_tetra.elmt:        <terminal orientation="n" x="50" name="" y="-170" uuid="{1316653b-2662-438c-a097-889c1abc779b}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage _tetra.elmt:        <terminal orientation="n" x="50" name="" y="-170" uuid="{fd224ec8-a206-4f1b-9c6a-77d1c8d720af}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage _tetra.elmt:        <terminal orientation="s" x="60" name="" y="-100" uuid="{cab960c8-9a88-4778-93e8-8870d1a45ec6}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage _tetra.elmt:        <terminal orientation="n" x="70" name="" y="-170" uuid="{4ff9ca97-d39b-4b69-8c29-64878c5a8216}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage _tetra.elmt:        <terminal orientation="n" x="90" name="" y="-170" uuid="{ea3d5e12-550a-4020-9d77-7f68df1c346f}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage _tetra.elmt:        <terminal orientation="n" x="30" name="" y="-170" uuid="{c0a75599-da2d-4ba3-acf9-6712290142f9}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage_mono.elmt:        <terminal orientation="s" x="60" name="" y="-100" uuid="{eeadc2ae-971c-415d-b9c9-fe4b697c4638}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage_mono.elmt:        <terminal orientation="n" x="70" name="" y="-170" uuid="{4ea8a41e-55c8-4157-8c16-fb88c5f997d1}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/bat_garage_mono.elmt:        <terminal orientation="n" x="50" name="" y="-170" uuid="{9be095b9-8adc-4198-989d-a7f5cc1d6f27}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chaudiere_murale.elmt:        <terminal y="30" orientation="s" uuid="{e4bb1151-00fb-485b-a066-000abf05c5f5}" name="" x="10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chaudiere_murale.elmt:        <terminal y="-50" orientation="n" uuid="{f34882c7-f9ea-45bc-bf2f-0e2554d159a8}" name="" x="-10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chaudiere_murale.elmt:        <terminal y="30" orientation="s" uuid="{5f8506cc-4546-420f-9d27-41f203fe1f34}" name="" x="-10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chaudiere_murale.elmt:        <terminal y="30" orientation="s" uuid="{12f05d54-538c-4e5d-9f02-0f1f7aa8ada1}" name="" x="0"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chaudiere_murale.elmt:        <terminal y="-50" orientation="n" uuid="{eca70d9c-af98-4bab-bcde-9f25a1b8ac80}" name="" x="10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chauffe_eau.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{95b5d1dd-00b1-463a-933f-84bbd0c11e8a}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chauffe_eau.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{e1f7aa54-6f70-4e5a-8b3a-6d2fc74fc2b9}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chauffe_eau.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{9b3b1807-62ba-40d9-a324-4f476afe692e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chauffe_eau1.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{80b6b49f-8b0d-42d9-9149-0cc4fec0d899}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chauffe_eau1.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{b967796c-6ea3-48d1-a424-fd7d0d3173ab}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/chauffe_eau1.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{af811e7b-30e5-4a2c-8f61-d908c0b42254}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur.elmt:        <terminal orientation="n" name="" x="50" y="-160" uuid="{2e112237-75df-47b3-bc8f-15fd0e89489f}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur.elmt:        <terminal orientation="s" name="" x="60" y="-100" uuid="{e323c17f-1635-4b73-898e-d07399277e39}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur.elmt:        <terminal orientation="n" name="" x="70" y="-160" uuid="{f827446e-eb79-4330-9e32-765e5f38e931}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur2.elmt:        <terminal orientation="n" name="" x="10" y="0" uuid="{f827446e-eb79-4330-9e32-765e5f38e931}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur2.elmt:        <terminal orientation="n" name="" x="-10" y="0" uuid="{2e112237-75df-47b3-bc8f-15fd0e89489f}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur2.elmt:        <terminal orientation="s" name="" x="0" y="60" uuid="{e323c17f-1635-4b73-898e-d07399277e39}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur_ext.elmt:        <terminal orientation="s" x="60" name="" y="-95" uuid="{358ab2d3-eccd-468b-b18b-7f0dd4581035}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur_ext.elmt:        <terminal orientation="n" x="70" name="" y="-160" uuid="{c912c700-4dde-4f89-86e6-5e8ab6d60704}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur_ext.elmt:        <terminal orientation="n" x="50" name="" y="-160" uuid="{6d55186b-c0e1-4e17-a38f-a2d32fb35469}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur_int.elmt:        <terminal orientation="n" name="" x="70" uuid="{144d8081-1cbf-4fff-9227-290d6baa887f}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur_int.elmt:        <terminal orientation="s" name="" x="60" uuid="{cb015e43-949c-4f32-b8b6-3667c144e8ff}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/climatiseur_int.elmt:        <terminal orientation="n" name="" x="50" uuid="{775e3f50-23c1-42f9-9d94-8968521d6b0e}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/congelateur.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{b6819b17-30fc-43a5-93c7-e2e364c1ec86}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/congelateur.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{cc159b63-6d07-4c5a-a56c-14d8fbe1c12f}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/congelateur.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{b6819b17-30fc-43a5-93c7-e2e364c1ec86}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/congelateur1.elmt:        <terminal orientation="n" x="50" name="" y="-180" uuid="{52825f3a-c55b-44ea-b134-d51eeccdc603}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/congelateur1.elmt:        <terminal orientation="n" x="70" name="" y="-180" uuid="{56f6b90b-679d-4c53-acd0-0b8cc594dabc}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/congelateur1.elmt:        <terminal orientation="s" x="60" name="" y="-90" uuid="{a7b499d7-0dab-4562-89e0-ff3a5d2dd063}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/cuisiniere_electrique.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{58242f41-2168-4193-96b9-e7921f40d9ac}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/cuisiniere_electrique.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{c0d5355e-29f2-424d-bf3a-d57e422e9c92}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/cuisiniere_electrique.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{16a7a2bf-a1cf-4d5d-b826-085520b07b52}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers10.elmt:        <terminal y="-110" x="60" uuid="{4ac6c3e2-422e-444f-a672-dc32c6b3051d}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers10.elmt:        <terminal y="-170" x="70" uuid="{a60b80d0-408a-4f52-bd6b-609dae4ca192}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers10.elmt:        <terminal y="-170" x="50" uuid="{7affc2fe-0e65-4c98-ac9d-41043d1a5d8d}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers16.elmt:        <terminal y="-160" x="70" uuid="{4dbe5a3d-6714-457c-b789-2b7538b2e570}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers16.elmt:        <terminal y="-160" x="50" uuid="{216504bb-f1a5-4ccb-9828-3f3cee98b30f}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers16.elmt:        <terminal y="-110" x="60" uuid="{f1c25d0f-705c-42be-ae42-477901b4e704}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers20.elmt:        <terminal y="-160" x="70" uuid="{765221fa-159d-4f28-ae45-d87d3e167f8a}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers20.elmt:        <terminal y="-110" x="60" uuid="{27dc831e-db6b-42c3-a656-e2426687fe50}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers20.elmt:        <terminal y="-160" x="50" uuid="{e894bd54-0250-4efa-a97f-a30babe19042}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers32.elmt:        <terminal y="-160" x="50" uuid="{3867082f-2162-419d-bf2b-00999ed6a7b3}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers32.elmt:        <terminal y="-160" x="70" uuid="{40cea879-afe2-4989-9c15-ac884c83082e}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tetra.elmt:        <terminal y="-160" x="30" uuid="{e950e3e3-8df4-4345-afe1-eeb8818c30e9}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tetra.elmt:        <terminal y="-160" x="90" uuid="{ec4005ba-c2a0-4da3-be99-b8080045b52f}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tetra.elmt:        <terminal y="-160" x="50" uuid="{7359e628-d930-49a9-be7f-659f315aa45b}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tetra.elmt:        <terminal y="-160" x="70" uuid="{f44068a2-1e2f-4fd6-a5fd-4cb21ce08a03}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tri.elmt:        <terminal y="-160" x="40" uuid="{00f48c1c-4c2b-42e7-a703-47b971686680}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tri.elmt:        <terminal y="-160" x="80" uuid="{3a1761b5-fe22-4862-ad08-f7b90ba70ff0}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/divers_tri.elmt:        <terminal y="-160" x="60" uuid="{0a9f9c67-f00d-4a24-a61a-3aa8553ff75b}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/double-flux.elmt:        <terminal orientation="s" name="" x="60" y="-95" uuid="{af362965-a238-4407-8c92-12dcb6e90f62}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/double-flux.elmt:        <terminal orientation="n" name="" x="50" y="-170" uuid="{d8be0cf9-8eb2-49a5-b9fa-b0a536a0149e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/double-flux.elmt:        <terminal orientation="n" name="" x="70" y="-170" uuid="{f3ba218e-ae2b-4a78-ad11-bbbafe2bf1c4}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/double-flux2.elmt:        <terminal orientation="s" name="" x="0" y="45" uuid="{af362965-a238-4407-8c92-12dcb6e90f62}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/double-flux2.elmt:        <terminal orientation="n" name="" x="-10" y="-30" uuid="{d8be0cf9-8eb2-49a5-b9fa-b0a536a0149e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/double-flux2.elmt:        <terminal orientation="n" name="" x="10" y="-30" uuid="{f3ba218e-ae2b-4a78-ad11-bbbafe2bf1c4}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau-chaude-2.elmt:        <terminal orientation="n" x="70" name="" y="-170" uuid="{7674a643-3ea7-4482-98ad-443cd9cee619}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau-chaude-2.elmt:        <terminal orientation="s" x="60" name="" y="-100" uuid="{03ae4057-7a29-485b-9ee3-9ca3d657bce7}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau-chaude-2.elmt:        <terminal orientation="n" x="50" name="" y="-170" uuid="{79b39d44-87e4-464b-8310-e476e1113486}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_mono.elmt:        <terminal orientation="s" x="60" name="" y="-100" uuid="{05a1c801-1b11-40b1-9a05-200a470324a3}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_mono.elmt:        <terminal orientation="n" x="50" name="" y="-160" uuid="{dcbab1b9-5d74-4f63-8d5c-05fcd19b3eaf}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_mono.elmt:        <terminal orientation="n" x="70" name="" y="-160" uuid="{761a1d0e-5324-4454-b72f-89d8e33ca53c}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_tri.elmt:        <terminal orientation="n" name="" x="60" uuid="{25bb1181-bccd-4b3b-bbc0-2e73b16d7a6a}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_tri.elmt:        <terminal orientation="n" name="" x="80" uuid="{f0907dd1-1217-4409-b7ba-f6fef1ffe614}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_tri.elmt:        <terminal orientation="n" name="" x="40" uuid="{be1862b4-55de-4af4-ba79-0adb3f6e617b}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eau_chaude_tri.elmt:        <terminal orientation="s" name="" x="60" uuid="{e358978d-8d75-40fb-bb6b-2e8833849266}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage (2).elmt:        <terminal y="20" orientation="s" uuid="{5e35d52e-4a3a-461c-a53f-9e6e6f684f4f}" name="" x="0"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage (2).elmt:        <terminal y="-20" orientation="n" uuid="{bc31bdbc-5454-48c5-b913-48b69c7be3f4}" name="" x="-10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage (2).elmt:        <terminal y="-20" orientation="n" uuid="{a9072ac7-314d-444d-8aa8-40dc41ae277b}" name="" x="10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage-ext.elmt:        <terminal orientation="n" name="" x="70" uuid="{d38a0bdb-9d2c-4ce7-83a8-987098e970c2}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage-ext.elmt:        <terminal orientation="s" name="" x="60" uuid="{44a9cebb-5cc8-4d89-b2e7-bd9e3bed864f}" y="-110"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage-ext.elmt:        <terminal orientation="n" name="" x="50" uuid="{2e3ba283-b918-4f68-9ad4-0ae658b61337}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage.elmt:        <terminal orientation="n" name="" x="50" uuid="{743ec6ca-61e9-4783-b3cc-54a31fcd020e}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage.elmt:        <terminal orientation="s" name="" x="60" uuid="{9ffa5bd8-d5c3-416e-b5b2-ddb3d565e0d1}" y="-98"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage.elmt:        <terminal orientation="n" name="" x="70" uuid="{bf24747d-b080-4cdf-9abd-043b852afa4b}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage1.elmt:        <terminal orientation="n" name="" x="50" uuid="{a91e64ff-4368-499e-b0f8-342c19fe5ef8}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage1.elmt:        <terminal orientation="n" name="" x="70" uuid="{7a268d3e-b07f-4af4-aa2c-5f08b8108be8}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/eclairage1.elmt:        <terminal orientation="s" name="" x="60" uuid="{3cedbdb8-6f20-4768-ae19-21ebacf4300e}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_congelateur.elmt:        <terminal orientation="n" x="70" name="" y="-170" uuid="{693ace1d-578b-449a-aa1d-e0727faf1cd2}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_congelateur.elmt:        <terminal orientation="n" x="50" name="" y="-170" uuid="{c1d23393-51de-4b04-829e-fedbfd3dcda1}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_congelateur.elmt:        <terminal orientation="s" x="60" name="" y="-90" uuid="{13bf67c5-cf17-4734-b275-c161474e3383}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_four.elmt:        <terminal orientation="s" name="" x="60" uuid="{ec8d94ea-5436-41f5-b011-f3431a90ac9d}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_four.elmt:        <terminal orientation="n" name="" x="50" uuid="{d4836e40-7fa3-4547-826e-d3ee274b1ddb}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_four.elmt:        <terminal orientation="n" name="" x="70" uuid="{9c5bb1fb-e5f6-458d-af6a-2e636c0f52cb}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_hotte.elmt:        <terminal orientation="n" name="" x="50" uuid="{8ed22208-8758-4af3-9d48-c48e0746cd17}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_hotte.elmt:        <terminal orientation="n" name="" x="70" uuid="{4d7a08aa-fb67-4175-841a-cf05afd74ce0}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_hotte.elmt:        <terminal orientation="s" name="" x="60" uuid="{2a280cce-5305-461d-9f5a-7bf12db87e96}" y="-95"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_lave-linge.elmt:        <terminal orientation="n" name="" x="70" uuid="{1ce889d3-310a-4830-810b-9cfa69750c13}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_lave-linge.elmt:        <terminal orientation="w" name="" x="60" uuid="{82c03209-9e92-498c-ac62-9d58b68c4137}" y="-90"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_lave-linge.elmt:        <terminal orientation="n" name="" x="50" uuid="{237c83d2-9084-476c-8ffd-b82a69e616d0}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_lave-vaisselle.elmt:        <terminal orientation="n" name="" x="50" uuid="{5ee9be2d-7074-40e6-bd14-a57e41fc053d}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_lave-vaisselle.elmt:        <terminal orientation="n" name="" x="70" uuid="{c882dfa6-4970-4eda-87cc-2d62bf6a4733}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_lave-vaisselle.elmt:        <terminal orientation="w" name="" x="60" uuid="{a4df8fb9-ad1b-40dc-894f-42ad131487fc}" y="-90"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_micro-onde.elmt:        <terminal orientation="n" name="" x="50" uuid="{513c2b86-c20e-40e9-b322-f2bcde1ac385}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_micro-onde.elmt:        <terminal orientation="n" name="" x="70" uuid="{3a486942-813a-4d31-a38c-f9013533e865}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_micro-onde.elmt:        <terminal orientation="s" name="" x="60" uuid="{f2635817-1726-4533-bf52-de582ae965af}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_plaques.elmt:        <terminal orientation="s" name="" x="60" uuid="{a2005e4f-e7d0-4db9-8d5f-4bf397a20d2c}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_plaques.elmt:        <terminal orientation="n" name="" x="70" uuid="{ffef43a3-b413-4824-a306-74dfe1932dcc}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_plaques.elmt:        <terminal orientation="n" name="" x="50" uuid="{04c1a1e7-707a-4703-9467-e0a2bd619ab2}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_plaques_2.elmt:        <terminal orientation="n" name="" x="60" uuid="{651185c8-ba29-4ad7-8d10-a37a628d875e}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_plaques_2.elmt:        <terminal orientation="n" name="" x="80" uuid="{ebad152a-2a7e-4830-bd21-cdb79547dd40}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_plaques_2.elmt:        <terminal orientation="s" name="" x="70" uuid="{87d84ca0-c53b-41c8-babb-f49f49a6cfdf}" y="-110"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_refrigerateur.elmt:        <terminal orientation="n" name="" x="50" uuid="{0e4ffe10-3d4a-45f0-9f09-e14533685a97}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_refrigerateur.elmt:        <terminal orientation="n" name="" x="70" uuid="{2965d7c0-9ade-4427-b485-217255ed8148}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_refrigerateur.elmt:        <terminal orientation="w" name="" x="60" uuid="{74d91b02-9c70-411a-8e0a-25a338bcf0c4}" y="-90"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_seche-linge.elmt:        <terminal orientation="n" name="" x="50" uuid="{8ee41291-dab8-4909-84b5-a7b7b9888f18}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_seche-linge.elmt:        <terminal orientation="w" name="" x="60" uuid="{2153a7d5-70b3-4dbb-a5af-806867603bed}" y="-90"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_seche-linge.elmt:        <terminal orientation="n" name="" x="70" uuid="{77678068-6ce4-4e66-b840-93a9cbf486f5}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_seche-linge_2.elmt:        <terminal orientation="n" name="" x="50" uuid="{c32ba629-f0ca-45e0-a449-5ad50cbd9137}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/em_seche-linge_2.elmt:        <terminal orientation="n" name="" x="70" uuid="{49be744f-5371-4b55-b19f-f50672ac882b}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/filtration.elmt:        <terminal x="60" y="-95" orientation="s" name="" uuid="{424196f6-7674-48ca-ab78-6610ebe31f7a}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/filtration.elmt:        <terminal x="50" y="-170" orientation="n" name="" uuid="{34a9cb5c-b5b5-479a-8b07-2fd10ecb5227}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/filtration.elmt:        <terminal x="70" y="-170" orientation="n" name="" uuid="{2362a69a-8c7b-4d60-a628-086f57cb98be}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/four_micro_onde.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{ce174422-ad0d-4504-83fc-48adb0b11e4c}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/four_micro_onde.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{e425277e-a393-4fe7-aab2-75025b7fd352}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/four_micro_onde.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{fb8635e6-fb90-4ce7-a5a3-9d876cbedc3e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/garage.elmt:        <terminal orientation="n" name="" x="50" uuid="{8dae2627-0b48-4054-aa90-68363a2f6c6e}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/garage.elmt:        <terminal orientation="n" name="" x="70" uuid="{fb108633-7f5e-4865-a6ee-331379ddd9cb}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/garage.elmt:        <terminal orientation="s" name="" x="60" uuid="{60fe2106-6f98-4e73-8c27-38b5805e2047}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/gestion-energie.elmt:        <terminal orientation="n" name="" x="50" uuid="{e96dc82e-f597-47dc-8040-5606515e884e}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/gestion-energie.elmt:        <terminal orientation="n" name="" x="70" uuid="{74549a99-4cbc-48fe-9e1a-569759eab2ba}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/heures-creuses.elmt:        <terminal orientation="n" name="" x="50" uuid="{a849bed1-f90a-4676-8e81-37bde24ca06e}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/heures-creuses.elmt:        <terminal orientation="n" name="" x="70" uuid="{70898310-3dc9-4013-956d-aff34e6dd6c0}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/hotte_aspirante_filtrante.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{eda005cb-5210-4d35-9014-354aa1c4ba15}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/hotte_aspirante_filtrante.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{fa8ee3f4-af56-4155-ab60-ff0230c06381}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/hotte_aspirante_filtrante.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{b2537051-ac6e-43e0-8b38-9b70e5416901}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave-linge2.elmt:        <terminal orientation="n" name="" x="-10" y="-30" uuid="{79a75695-2506-4be2-b37c-88fa8e361b65}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave-linge2.elmt:        <terminal orientation="n" name="" x="10" y="-30" uuid="{fcbd86bd-2a65-4f67-b64e-8ad7c93c4683}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave-linge2.elmt:        <terminal orientation="s" name="" x="0" y="20" uuid="{7bd9a67f-963c-4116-ab81-2d9a7b879b62}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_linge.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{0d95341f-da46-41c9-81d5-fea87aa3829b}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_linge.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{a78d27c5-462f-41c0-bcef-beb1eec237e4}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_linge.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{8e71a582-ace6-47bd-b78d-b4ddfd5f8efc}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaiselle.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{49e50554-5ae1-4441-91cb-f19c4c039f8c}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaiselle.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{8b02c49f-e13d-4cdc-a640-7b6b63a60c33}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaiselle.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{51103b6a-6ee8-40e1-838a-969e9e72d761}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaiselle2.elmt:        <terminal orientation="n" name="" x="-10" y="-20" uuid="{fa89ad78-6814-4739-8f55-1807c7328c2a}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaiselle2.elmt:        <terminal orientation="n" name="" x="10" y="-20" uuid="{c3289d4a-3319-4b9c-81d8-15ef69de6724}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaiselle2.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{85bf15b9-0dc4-47e4-a324-de2edcb7cd21}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaisselles.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{e97da64d-414b-4803-a7d2-92e58e18dcac}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaisselles.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{844f5937-e88f-4c72-963c-3946effcdd98}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/lave_vaisselles.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{041631f8-1a4c-483e-a0dd-94bdbe8479c4}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur-volet-roulant2.elmt:        <terminal orientation="n" name="" x="0" y="0" uuid="{1faccbcf-d5b9-499a-8b15-62ab1e26ec4b}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur-volet-roulant2.elmt:        <terminal orientation="s" name="" x="0" y="31" uuid="{75053000-1b78-46f8-bbc3-0cb07150413e}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur-volet-roulant2.elmt:        <terminal orientation="n" name="" x="20" y="0" uuid="{0e03d738-1660-4a68-918f-178d10d6d9f9}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur-volet-roulant2.elmt:        <terminal orientation="n" name="" x="46.0591" y="-0.125" uuid="{46836d6e-6977-49e4-bde1-e82e1773a6df}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_mono.elmt:        <terminal orientation="s" name="" x="60" uuid="{bc205df0-bbdc-4f87-b604-4ada82db5fa3}" y="-110"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_mono.elmt:        <terminal orientation="n" name="" x="50" uuid="{b23de979-e4d2-45c9-9368-c577cd4a0ac1}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_mono.elmt:        <terminal orientation="n" name="" x="70" uuid="{a6936c20-3010-442e-91ce-3f1d91fdc6ca}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_tri.elmt:        <terminal orientation="n" name="" x="40" uuid="{c8e06860-e36e-446e-944c-823ae1e82439}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_tri.elmt:        <terminal orientation="n" name="" x="80" uuid="{74eb39db-3e43-4205-9e3c-395388e56f11}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_tri.elmt:        <terminal orientation="s" name="" x="60" uuid="{c0c69691-baa6-4304-bd28-35ad21444405}" y="-110"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/moteur_tri.elmt:        <terminal orientation="n" name="" x="60" uuid="{4b1caf58-c67f-4d0b-827c-f264cfe94dfd}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/oven.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{958c1acb-6486-467c-9240-bcbe45f39c02}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/oven.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{5ac887d1-3455-450d-8597-fe1cb05a3aaa}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/oven.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{f19ddc68-342e-43a8-9ba2-2918a4220864}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plancher_chauffant.elmt:        <terminal orientation="s" name="" x="0" uuid="{7d383dfe-7049-4f2c-b8c3-f202cb295224}" y="-20"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plancher_chauffant.elmt:        <terminal orientation="n" name="" x="10" uuid="{016cf312-f14a-49b6-aa5b-a1de991af26d}" y="-80"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plancher_chauffant.elmt:        <terminal orientation="n" name="" x="-10" uuid="{016cf312-f14a-49b6-aa5b-a1de991af26d}" y="-80"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plancher_chauffant_2.elmt:        <terminal x="50" y="-170" orientation="n" name="" uuid="{4bd22cc2-afac-429a-b651-3575a18eef40}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plancher_chauffant_2.elmt:        <terminal x="60" y="-115" orientation="s" name="" uuid="{10ceb531-363b-4888-b6fe-7c206710802d}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plancher_chauffant_2.elmt:        <terminal x="70" y="-170" orientation="n" name="" uuid="{10f8e008-6783-463b-876f-0ae9b683c334}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plaque_cuisson.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{b2c4ba2f-173f-4ca9-ace1-2c5b92f93bae}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plaque_cuisson.elmt:        <terminal orientation="s" name="" x="0" y="30" uuid="{0a68f4bc-4934-40b2-ac11-c233acb77e44}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/plaque_cuisson.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{57d26b67-b059-44d1-9cbb-788e2f6f8ed6}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_mono.elmt:        <terminal orientation="s" name="" x="60" uuid="{58f7992d-3a19-4941-8153-1a7585dc1ba4}" y="-110"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_mono.elmt:        <terminal orientation="n" name="" x="50" uuid="{b37fe597-2329-484b-a1af-cb6366b0134e}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_mono.elmt:        <terminal orientation="n" name="" x="70" uuid="{9830b3a0-60f4-4e16-ad89-8fa80b27201c}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_tri.elmt:        <terminal orientation="n" name="" x="60" uuid="{9fef16a7-426f-4739-b4fd-010fc6f2d96a}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_tri.elmt:        <terminal orientation="n" name="" x="40" uuid="{af970a95-ee7d-4b24-93ac-7cddd5f33026}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_tri.elmt:        <terminal orientation="n" name="" x="80" uuid="{93628a68-8ee0-4637-bd1a-a93ba73f7c85}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/pompe_tri.elmt:        <terminal orientation="s" name="" x="60" uuid="{f3588b4e-6b18-4a7b-8a9a-4bcfcb68b6d0}" y="-110"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/portail.elmt:        <terminal orientation="w" name="" x="60" uuid="{7a2bf8e6-991c-46b1-bce2-4c003f4d2741}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/portail.elmt:        <terminal orientation="n" name="" x="50" uuid="{4aca5802-bcf4-48b5-86fe-622db0a6bf6c}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/portail.elmt:        <terminal orientation="n" name="" x="70" uuid="{bf27ed89-14dd-402c-bfb7-e2577b5a1590}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/porte-garage.elmt:        <terminal orientation="n" name="" x="70" uuid="{47229211-f1fb-4dfe-beae-7202eb8bf158}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/porte-garage.elmt:        <terminal orientation="w" name="" x="60" uuid="{25ba5256-1af0-41bc-b6a0-2e144898f2e3}" y="-105"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/porte-garage.elmt:        <terminal orientation="n" name="" x="50" uuid="{947ff614-911b-4d58-87aa-73cc6978d12c}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/porte-garage.elmt:        <terminal orientation="n" name="" x="60" uuid="{b80cb2c4-573d-4f07-adbb-6378ff6b7a83}" y="-290"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-10.elmt:        <terminal orientation="s" name="" x="60" uuid="{d80699ad-17df-4e35-81b7-822abe5ca9da}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-10.elmt:        <terminal orientation="n" name="" x="70" uuid="{b87cb774-f6ee-4552-8f7d-e23dce9ef5bc}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-10.elmt:        <terminal orientation="n" name="" x="50" uuid="{7e8cee38-044f-474a-8947-3553e4670312}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-16.elmt:        <terminal orientation="n" name="" x="50" uuid="{e9f8e1d0-2081-4dcf-ad28-4c109afc4134}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-16.elmt:        <terminal orientation="s" name="" x="60" uuid="{4617dfeb-f8a0-4ea0-90cc-5f71026874fd}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-16.elmt:        <terminal orientation="n" name="" x="70" uuid="{2a924961-4f71-47c9-a19a-253dd5dce8e8}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-20.elmt:        <terminal orientation="s" name="" x="60" uuid="{6f1a6ed7-de7b-4545-8f40-16d25239463d}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-20.elmt:        <terminal orientation="n" name="" x="70" uuid="{e8f9b2fd-2a4e-4016-b123-3e7ee2fc85b3}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-20.elmt:        <terminal orientation="n" name="" x="50" uuid="{18acda57-d500-4515-82bf-eb75a8fdcf0f}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-2p-t-230v.elmt:        <terminal orientation="n" name="" x="70" uuid="{3b889261-baf3-4edb-b385-394839b11856}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-2p-t-230v.elmt:        <terminal orientation="s" name="" x="60" uuid="{4ddfab58-6f71-4d7c-ac6c-487ecf83c8ed}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-2p-t-230v.elmt:        <terminal orientation="n" name="" x="50" uuid="{f89eb4ca-ba3d-4c1c-a732-f4e25fab82ff}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-32.elmt:        <terminal name="" orientation="n" uuid="{01846186-8fe1-4c9c-b243-5208e4258d80}" x="70" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-32.elmt:        <terminal name="" orientation="n" uuid="{8bd7c977-1bc4-4a3e-9043-3f49ee9769ef}" x="50" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-32.elmt:        <terminal name="" orientation="s" uuid="{b56d62da-b358-439b-ae3b-11d34fd2d733}" x="60" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-230v.elmt:        <terminal y="-170" x="40" uuid="{330c0d21-5eba-47d7-a1b2-8423b674eb9e}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-230v.elmt:        <terminal y="-170" x="60" uuid="{3bb93825-67d3-4d24-a742-9303bd7c3544}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-230v.elmt:        <terminal y="-170" x="80" uuid="{943dc497-37d3-44cf-8c4b-83db06903920}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-400v.elmt:        <terminal orientation="n" name="" x="40" uuid="{9d904b42-2911-4106-a952-f9c6fe248cc2}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-400v.elmt:        <terminal orientation="n" name="" x="80" uuid="{fd0f4cc9-ba44-41d3-aa12-644de54e6413}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-400v.elmt:        <terminal orientation="n" name="" x="60" uuid="{757b0ef5-d28e-4623-8d4e-11b13d783bac}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-3p-t-400v.elmt:        <terminal orientation="s" name="" x="60" uuid="{8aab1ec9-1923-4b47-83ee-60a9c583e451}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-4p-t-230v.elmt:        <terminal orientation="s" name="" x="60" uuid="{65d86c92-90df-46be-9fea-6d2a66d83a74}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-4p-t-230v.elmt:        <terminal orientation="n" name="" x="50" uuid="{1e44dc8f-45a8-4f04-938e-195fd89dd9b9}" y="-190"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-4p-t-230v.elmt:        <terminal orientation="n" name="" x="90" uuid="{4e0e9e9d-d69b-4549-a2af-c252d40c26fb}" y="-190"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-4p-t-230v.elmt:        <terminal orientation="n" name="" x="70" uuid="{63a92906-ecda-4181-b79f-1fc36c9fba14}" y="-190"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-4p-t-230v.elmt:        <terminal orientation="n" name="" x="30" uuid="{2bcb5569-fd81-4ceb-94cc-c73d3cf80e90}" y="-190"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-exterieur.elmt:        <terminal orientation="n" name="" x="50" uuid="{1695df9e-dce0-4d3b-af4b-38aa894870ab}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-exterieur.elmt:        <terminal orientation="n" name="" x="70" uuid="{2305c014-3afd-4038-9188-34d497ae7fe3}" y="-170"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-exterieur.elmt:        <terminal orientation="s" name="" x="60" uuid="{ca41736b-399e-4ea0-9c91-3b8a33023bb0}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra16.elmt:        <terminal y="-170" x="90" uuid="{13ac21b1-bee7-4ae9-a1fb-3d1ea165f95a}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra16.elmt:        <terminal y="-170" x="70" uuid="{146436b6-0464-4857-ae0b-3e4ab413e41d}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra16.elmt:        <terminal y="-170" x="50" uuid="{6e389ae7-7fc2-468f-bad2-0da1ed374947}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra16.elmt:        <terminal y="-170" x="30" uuid="{1f881585-30d6-499d-96ac-055a6c02920a}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra32.elmt:        <terminal y="-170" x="50" uuid="{0a4e28b0-4faf-4417-a2a5-50b29803f19c}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra32.elmt:        <terminal y="-170" x="70" uuid="{27628c48-4291-4a90-9c2a-c47325755bd4}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tetra32.elmt:        <terminal y="-100" x="60" uuid="{ecb3a6f7-fa97-4a9c-a843-30ba39f51967}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri16.elmt:        <terminal y="-170" x="80" uuid="{8bdada1d-67f4-4a89-b907-5901f1531fc9}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri16.elmt:        <terminal y="-100" x="60" uuid="{5c24ae76-bfc5-4ccd-8e2f-a3c22fa768ae}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri16.elmt:        <terminal y="-170" x="60" uuid="{cf25aa71-ef28-4ddb-bdc9-11d33fdea3a2}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri16.elmt:        <terminal y="-170" x="40" uuid="{f1d8ee80-c359-4741-937a-aab7c32737ce}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri32.elmt:        <terminal y="-170" x="60" uuid="{98907cac-c938-45c2-8097-976250766ae3}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri32.elmt:        <terminal y="-100" x="60" uuid="{83f1d662-99e5-44d3-8114-218e7718ecdc}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri32.elmt:        <terminal y="-170" x="80" uuid="{9bbec5a3-8c4c-4710-b172-1db8a37260b3}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise-tri32.elmt:        <terminal y="-170" x="40" uuid="{ee741235-dd16-4d81-a2d1-39dbcbef90d5}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise_allemande_10a.elmt:        <terminal y="-170" x="50" uuid="{8399c17f-830f-4cd1-949d-0cadff085dae}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise_allemande_10a.elmt:        <terminal y="-100" x="60" uuid="{f1bbb51c-3506-4f45-9498-65acadefe4ce}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise_allemande_10a.elmt:        <terminal y="-170" x="70" uuid="{dff7179c-0ebc-4423-a140-416be26a4e21}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise_allemande_16a.elmt:        <terminal y="-170" x="50" uuid="{acd0e8f7-1e58-40b2-9f4d-b940bd437d05}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise_allemande_16a.elmt:        <terminal y="-100" x="60" uuid="{ae556f74-9de1-4e74-a847-6021bec72d8c}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/prise_allemande_16a.elmt:        <terminal y="-170" x="70" uuid="{78d881a0-47c3-4a57-ae6f-3096c177df86}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/protection-foudre.elmt:        <terminal y="-170" x="70" uuid="{2e247aed-1c15-4e28-a710-c9a51dce0253}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/protection-foudre.elmt:        <terminal y="-100" x="60" uuid="{feb4e0cd-b5b9-44b0-a06a-c1d8ec4c78ff}" name="" orientation="s"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/protection-foudre.elmt:        <terminal y="-170" x="50" uuid="{d631e2db-6006-45a7-b784-f5612b912413}" name="" orientation="n"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur (2).elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{5abd9f82-1eab-4203-94da-95b82fc82672}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur (2).elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{00840cc4-dad1-4246-9928-99605a67819f}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur (2).elmt:        <terminal orientation="s" name="" x="0" y="20" uuid="{458bfeca-0e4d-40d2-ac10-4b51dfeab581}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur.elmt:        <terminal orientation="s" name="" x="60" uuid="{0e7dbfd2-52f2-4ac6-b7cb-da1362794c90}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur.elmt:        <terminal orientation="n" name="" x="70" uuid="{bc5dee6b-9078-4aff-ba4c-d86059aff80a}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur.elmt:        <terminal orientation="n" name="" x="50" uuid="{496cdc24-5d56-41fc-b665-64aea9563670}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur1.elmt:        <terminal orientation="n" name="" x="50" uuid="{1cc0fdc1-bf65-49ad-be41-88d0a51ad334}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur1.elmt:        <terminal orientation="n" name="" x="70" uuid="{a13c6f57-2a4c-4764-8c88-7043ff7444f4}" y="-160"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur1.elmt:        <terminal orientation="s" name="" x="60" uuid="{427b052b-6681-4ad6-9cfb-1c057d914336}" y="-100"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur_soufflant_seche_cheveux.elmt:        <terminal orientation="n" name="" x="-10" uuid="{e5493254-cd3d-4b0f-8db6-db69a81b207f}" y="-10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur_soufflant_seche_cheveux.elmt:        <terminal orientation="n" name="" x="10" uuid="{7156d3ab-469c-49c2-bc30-dd9ee1a513b3}" y="-10"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/radiateur_soufflant_seche_cheveux.elmt:        <terminal orientation="s" name="" x="0" uuid="{abee7d33-4181-4424-9133-2f9e1dabfdd7}" y="30"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/refrigerateur.elmt:        <terminal orientation="n" name="" x="-10" y="-10" uuid="{3a8c8738-1b8c-4f02-9fc9-a2349814fc7a}"/>
qet/elements/10_electric/10_allpole/500_home_installation/20_home_appliances/refrigerateur.elmt:        <terminal orientation="n" name="" x="10" y="-10" uuid="{c2a12b3b-9597-4c0c-83ee-652194376fb9}"/>
but how do you find the double uuids?
