Topic: Text orientation (not saved)
Hi!
When I change the orientation of the text on the wire label, the orientation is not saved, are there any ways to solve this problem?
version QE:QElectroTech V 0.80-DEV+265de06fed79751d3
Compilation: GCC 8.3.0 - built with Qt 5.12.5 - Date : Oct 9 2019 : 10:17:54 - run with Qt 5.12.5 using 16 thread(s)
OS : winnt - x86_64 - Version : Windows 10 (10.0) - Kernel : 10.0.18363
030.png, 65.25 kb, 1593 x 469
Re: Text orientation (not saved)
just use "Space" key for rotate wire label, if you change text orientation in the widget when you select a wire, you need to move or modify your wire path to see label orientation new change.
Or simply right click on wire label and "Choose text orientation".
https://download.qelectrotech.org/qet/forum_img/wire_label_widget.png
Hi,just use "Space" key
Thank you very much!
Problem solved!
