Topic: Symbols visualization
I have a little problem with symbols visualization.
I mean, when is open a page, I see graphics symbols not on same lines, but if I want to print on pdf I see perfect all on line .
This was , on 6 version as 7 version.
What happens ?
Thanks all
Re: Symbols visualization
You can make a picture, what your version and your screen.
Windows 10 Home is SO. The image i don't know how to do for insert it. Sorry but it's the first time that i write in a forum.
Can you help me ?
https://ibb.co/Gs426bB
You use multiple screens?
yes
I solved my little problem , I changed resolution on left monitor , en fact on the left was 100 % and on PC right was 125% . In these case they must be the same .Thanks to Scorpio810 for suggestion .Many thanks .
Thanks for your feed back.
HELP , please .
Another little question . Before,  my QeT has generated the increment pages from 1 to 4 on intestation, now from 0 to 3 , it's problem because my project are saved with old system . Now i have a different page and i  all reference changed .
https://ibb.co/x5NLV55
800x688Because you have changed in config option -> Projects -> Number the title block columns to 0 ...
Solved.
It was not marked, i tried make it and remove it. And now it restart correctly from 1 to 4 like i want it , strange .
Again many thanks Scorpio810 .
Hi all
It's possible copy a page from 1 project to another project , holding all references ?
Thanks .
you can and keep all references but you need to link again elements and report.
See in setting : uncheck : do not store the label of items in the copy paste.
Perfect .Solved . Thanks Scorpio810
