Topic: Text size when opening Old Project
I'm having an issue that when i open a project, that i have created in V6 or earlier, in v7 all the element texts are increased in size to 9pt causing a few issues.
Is there any way of stopping this without having 2 versions of the software?
Cheers
Rob
Re: Text size when opening Old Project
On 0.7 you could change texts fonts policy on the fly in QET settings, just relad project to see changes.
BTW, 0.7 not change your project texts size when you launch 0.6 or 0.7 version.
You could provide project or captures?
Cheers,
Iv'e had a quick play with that text setting and it doesn't seem to be the right thing,
The easiest thing to see it on in the schneider Altistart01N2 Element on the opened project all the terminal markers are 9pt whereas when i drag a new element in they are 4pt
i have tried to attach some screen grabs, hope this helps and thankyou for your help
Capture 2.PNG, 112.05 kb, 1572 x 923
I f you try new project under 0.7 and only drag and drop  the schneider Altistart01N2 Element, save it and re open it, texts are changed?
Please paste QET version.
5 (edited by rob.rose125 2019-07-12 10:11:21)
When I do that the new element stays the same with no change.
Version attached. thanks again for your help.
Capture3.PNG, 24.69 kb, 1313 x 721
Isn't the latest, please upgrade, thanks.
5749 is build the 24/02/2019.
DOH!nomicons/blush  updating to RC2 5942 has fixed the issue.
Thanks Again
And thanks for the excellent Program!
Cool ;-)
Thanks for compliments.
