1 (edited by okanbicer5 2019-04-24 13:02:42)
Topic: Wrong coming arrow conductor name after reload
General conductor name formula %F.%seqt_1  "folio label . index number".
When I use coming arrow from another folio going arrow, conductor names come from going arrow conductor name with formula (%F.%seqt_1). It is ok.
But after reopen project coming arrow conductor names changes to current Folio label(%F) but keeps index number(seqt_1).
Can you help? I cant fix the issue, i dont want to label conductor manually because any folio changes i will have to change all of them.
http://i68.tinypic.com/oqg8ar.jpg
Re: Wrong coming arrow conductor name after reload
check this :
https://download.qelectrotech.org/qet/forum_img/folio_numbers.png
Thanks for your help.
But I think version doesnt same. Should i upgrade to developement version(0.7)
http://i66.tinypic.com/1zl3s5h.png
You could try 0.7-rc1, but make a backup off your project before, if you want to return on 0.60 after.
Edit : Use label instead of their ID is already checked in your version.
You need to replace manualhy propertie %id/%total by your number folio.
https://download.qelectrotech.org/qet/forum_img/folio_number.png
I think you have added a summary page in your project and folio position was changed?
6 (edited by okanbicer5 2019-04-24 15:54:50)
Unfortenatly this option doesn't fix the issue.( 0.7-rc1 )
I didnt add summer page. I close the app and reopen it then referenced (coming arrow) line name changes.
It occurs inverse way. When i remove source conductor and reconnect it. Name become referenced cable name 03.04. Reopen app it is become 02.04.
Project is in attachments. 02 and 03 folio you can see.
Edit: Atachment doesnt work
We transfer link:
https://we.tl/t-vWTUVGLUD9
Ok. I will try now.
8 (edited by okanbicer5 2019-04-24 16:05:22)
With formula "%id/%total" or directly labeling "02" coming arrow conductor always named with their folio name
not the refereced source folio name. (after reopen application)
Is dangerous to autonum conductor with formula (%F.%seqt_1) when you use link to other folio.
Remove formula in all conductors you want to link, unlink and reconnect.
If not equipotential is wrong.
https://download.qelectrotech.org/qet/forum_img/link_error.png
https://download.qelectrotech.org/qet/forum_img/link_error2.png
And program crashe....
10 (edited by okanbicer5 2019-04-25 00:51:18)
Yes, when i use sequence number with only "%seqh_1" or "%seqt_1" for conductor, problem doesnt occur.
I am not expert of electirical drawing and my friend advice that "you should reference folio label in your conductor because in a big project it is hard to find the conductor only with sequence number". I think it is reasonable.
But if you advice "use only sequence number or use manuel label for conductors". It is okey but how can customer can find cable number in a big project(many folios) with printed version(in a lot of A4 papers).
Edit:
Are there any practices I dont know? I am ready to use it.
Well, If you want to use formula %F.%seqt_1 for conductors, the best pratice or workaround is to add a report on other folio
  1. link this report to previous conductor
  2. create conductor in folio 03 after,  (btw not try to link directly 2 different formula %F.%seqt_1  conductors).
By example in your project I delete conductor 03.05 in folio 3, unlink the report, now link again just enter 02.05 in filter bar and choose the good conductor (02-D9) position and after redraw conductor in your folio 3.
Good morning.
Yes I did it same manner. First it was labeled 02.05 (with formula %F.%seqt_1). Save and close the app and reopen it. It appears 03.05 (03 current folio number.)
Even when I open your attachment I saw 03.05 not the 02.05. nomicons/sad
My way
1. Draw outgoing arrow- connect with formulated conductor
2. Draw incoming arrow in another folio - link it with outgoing arrow
3. Connect incoming arrow with pins(conductors named 1.step conductor till to reopen)
