Topic: QElectroTech craches
I am using QElectroTech V 0.70-dev+svn5495.
When QElectroTech is open and I doubleclick a file ....qet,the program crashes without a message. It just disappears. When I open QElectroTech again a message appears that a repair file exist and if I want to open it.
2 (edited by Morganol 2018-09-04 13:14:45)
Re: QElectroTech craches
Can you tell us a bit of what system you use?
If you start it from command line, is there any messages when it crashes?
Edit: Oh by the way:
Welcome to the club nomicons/smile
 /Edit
If QET is already open the good way to open an project is by menu file -> Open, or latest files.
Thanks for report this issue, this no work here on my Debian machine but no crasche QET, is not open the file...
My system is: Windows 10 Home, Version 1803, Build 17134.228.
No message at all. It just stops.
Oh by the way:
Welcome to the club 20x20
Thanks.
Indeed that is the way I normally do it. But I had a situation where i found it easier to just doubleclik the files I wanted to open.
So do not launch QET before.
Simply doubleclik  on the file launch QET and your project/element/titleblock in the right editor.
