doc:translation [21/07/2023 12:25] – Use HTTPS for download.qelectrotech.org xavier | doc:translation [22/12/2023 21:30] – [How to update .ts files from source files?] scorpio810 | ||
Ligne 95: | Ligne 95: | ||
Note: *.ts are generally updated by the developer when he considers that the character strings to be translated are viable or by translators. | Note: *.ts are generally updated by the developer when he considers that the character strings to be translated are viable or by translators. | ||
* Édit qelectrotech.pro file: Comment out the lines starting with '' | * Édit qelectrotech.pro file: Comment out the lines starting with '' | ||
- | * Run the following command: < | + | * Run the following command: < |
* Restore missing references to source files : < | * Restore missing references to source files : < | ||
* Restore file qelectrotech.pro: | * Restore file qelectrotech.pro: |
