401
Revision: 5664
Author: blacksun
Date: 2018-12-28 19:39:54 +0100 (Fri, 28 Dec 2018)
Log Message:
Title block : add two news variables, previous-folio-num and next-folio-num
Deux nouvelles variable sont disponible pour les cartouches :
previous-folio-num : permettant d'afficher le numéro du folio précédent.
next-folio-num : permettant d'afficher le numéro du folio suivant.
Utile depuis qu'il est possible de numéroté les folios, de manière non consécutif.
Joshua wrote:
Revision: 5664
Author: blacksun
Log Message:
Cool !
403
Revision: 5666
Author:   scorpio810
Date:     2018-12-29 09:45:17 +0100 (Sat, 29 Dec 2018)
Log Message:
Title block : list of texts variables can be selected with the mouse and
copied to the clipboard using a context menu or standard keyboard
shortcuts.
404
Revision: 5672
Author:   scorpio810
Date:     2018-12-29 20:37:16 +0100 (Sat, 29 Dec 2018)
Log Message:
Update Hungarian translations, thanks Gabor
405
Revision: 5674
Author: scorpio810
Date: 2018-12-30 15:31:16 +0100 (Sun, 30 Dec 2018)
Log Message:
Move some elements to 01_thumbnails_mounting_plate folder
 history | grep "svn move"
 9179  svn move finder/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/
 9180  svn move gce/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/
 9181  svn move hiquel/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/
 9182  svn move jumo/99_assembly_plan/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/jumo/
 9191  svn move omron/99_assembly_plan/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/omron/
 9192  svn move schaffner/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/
 9193  svn move schneider_electric/99_assembly_plan/ ../98_graphics/99_assembly_plan/01_thumbnails_mounting_plate/schneider_electric/
406
https://github.com/AlDanial/cloc
[16:15:01] laurent@debian:~/qet_element_moderation$ cloc qelectrotech_trunk-181229/
Unescaped left brace in regex is deprecated here (and will be fatal in Perl 5.32), passed through in regex; marked by <-- HERE in m/({ <-- HERE |})/ at /usr/bin/cloc line 8555.
    6352 text files.
    6291 unique files.
    5821 files ignored.
github.com/AlDanial/cloc v 1.76  T=2.63 s (201.5 files/s, 138227.1 lines/s)
Language                         files          blank        comment           code
Qt Linguist                         25            543              0         253942
C++                                219           9830          20975          49837
C/C++ Header                       221           2893           5346          10592
Qt                                  41              0              0           7711
XML                                  6              0             22            750
Markdown                             3            129              0            362
Bourne Shell                         5             91             71            266
Perl                                 1             22             35            259
ProGuard                             3             45             37            186
DOS Batch                            3             19             21             94
DTD                                  1              8              0             61
CSS                                  1              0              0             21
Qt Project                           1              2              1              8
Windows Resource File                1              0              0              1
SUM:                               531          13582          26508         324090
cloc qelectrotech_trunk-181229/sources/
     472 text files.
     472 unique files.
       4 files ignored.
github.com/AlDanial/cloc v 1.76  T=1.05 s (447.7 files/s, 101068.0 lines/s)
C++                            211           9683          20672          49169
C/C++ Header                   216           2845           5123          10445
Qt                              41              0              0           7711
SUM:                           468          12528          25795          67325
ohcount qelectrotech_trunk-181229/
Examining 6968 file(s)
                          Ohloh Line Count Summary
Language          Files       Code    Comment  Comment %      Blank      Total
typescript           25     253942          0       0.0%        543     254485
cpp                 439      60426      26292      30.3%      12719      99437
xml                  47       8412         22       0.3%          0       8434
nsis                  5        903        165      15.4%        212       1280
shell                 5        266         71      21.1%         91        428
perl                  1        258         36      12.2%         22        316
make                  3        186         37      16.6%         45        268
bat                   3         94         21      18.3%         19        134
css                   1         21          0       0.0%          0         21
c                     1         11         21      65.6%          4         36
idl_pvwave            1          9          0       0.0%          2         11
Total               531     324528      26665       7.6%      13657     364850
407
Joshua wrote:
Revision: 5664
Author: blacksun
Log Message:
408
Bonjour, j'étais en 05dev, windows 32Bits.
Je viens de me lancer sur la 07Dev.
je rencontre un soucis avec les cartouches utilisateurs :
si j'ouvre mes anciens projets, je me retrouve avec un nom de version 0.70-dev+svn5685.
j'utilisais la personnalisation de mon cartouche en appelant un %version. dans custom.
j'ai bien compris que le mot version faisait appel à la version du logiciel.
Mais du coup, ai-je un moyen de récupérer cette information sans devoir la réécrire dès que j'ouvre un ancien projet.
PS je ne pense pas être le seul a avoir personnalusé mes cartouches en ajoutant le mot version pour la version de schema.
merci encore pour le boulot fourni
409
Ok, je viens de voir....tant pis je reprendrait au cas car les nouvelles variables sont mieux structurées et plus complètes.
Je vais d'ailleurs refaire mes cartouches en tenant compte des nouvelles variables
410
Revision: 5666
Author: scorpio810
Log Message:
shortcuts.
Quand on copie la variable (du bas de la fenêtre) et qu'on le copie dans le champs au dessus, cela ajoute un espace devant le % (sur la readytouse). J'ai beau faire attention à la sélection, l'espace est ajouté....
Est-il envisagé de pouvoir appeler les variables cartouches dans un champs texte? Ceci dans le but de bricoler un cartouche de page de garde....
411
Je m'en suis aperçu aussi en faisant la petite vidéo de démonstration, c'est quand même mieux que de devoir écrire les noms de variables à la main, je regarderai si je peut virer cet espace dans le collage.
Si tu peux être plus clair.
412
Pour le copier/coller des variables dans l'éditeur de cartouche, le travail de Laurent m'a donné une idée que je suis en train de coder.
Il s'agit d'une combo-box (liste déroulante) dans laquelle on choisis une variable, c'elle ci est automatiquement mis dans le presse papier, après un simple 'coller' suffit.
Bonne idée Joshua.
414
Dans le cartouche de la page de garde que j'ai mis en capture, j'indique la révision, le nombre de folio total, mais ceci manuellement. Si on pouvait appeler les variables %index-revision et %folio-total cela éviterais l'oublis. Aujourd'hui, sur cet exemple, ce n'ai pas un élément, juste des basic shape. Si les variables de cartouches s'étendaient aux éléments, je le ferais ainsi.
En passant, les variables "folio précédent" et "folio suivant" marchent bien...
415
Non, ce n'est pas possible pour l'instant avec des textes simples.
Dans l'exemple ci-joint et fourni avec les paquets, tu as un exemple de page de garde.
Elles sont limitées, la limitation peut s'enlever, mais es-ce vraiment utile?
De plus je ne vois que dans l'autonum des elements pour rajouter ces variables %loc%plant%index, etc
416
Ce ne serait pas utile si on pouvait limiter la largeur des cartouches de façon propre.
417
mais si.
Bon reste la ligne du cadre en haut ...nomicons/whistling
https://download.qelectrotech.org/qet/forum_img/galexis_title_block.png
418
C'était ça le problème, il reste une ligne disgracieuse...
419
Toi pas connaitre le blanco nomicons/smiley-green nomicons/whistling
https://download.qelectrotech.org/qet/forum_img/galexis_blanco.png
420
nomicons/laughing nomicons/laughing  Laurent le roi du workaround
Revision: 5687
Author: blacksun
Date: 2019-01-02 17:56:46 +0100 (Wed, 02 Jan 2019)
Log Message:
NameList widget : add a combo box for easily paste texts, like the variables for title block.
Why not ....
423 (edited by Joshua 2019-01-05 00:16:07)
Revision: 5698
Author: blacksun
Date: 2019-01-04 23:06:34 +0100 (Fri, 04 Jan 2019)
Log Message:
Element panel : elements can be searched by their name but also with by all their informations.
Lors d'une recherche dans le panel d'élément, en plus du nom, les éléments sont aussi filtrer par leurs informations (fabricant, référence, code interne etc...)
424 (edited by gleissoncg2 2019-01-06 19:00:12)
[font=Verdana, Helvetica, Arial, sans-serif]I notice that when I am doing sequential automatic I notice that when I am doing sequential automatic numbering of the wires, at some point if I give a Ctrl +Z , the number sequence does not return to the last number placed . Is there any way to do this?[/font]
425
Not for the moment, you need to go to autonum rules and decrease manualy this counter.
