Topic: Previous and next folio
Instead of using the Folio Id I often use folio numbers with defined ranges.
eg.
001 - Title page
002...005 - Index pages
051...090 - Main Current
101...199 - Control current
301...399 - PLC
501...599 - Material lists
701...799 - Terminal lists
etc.
This leaves a lot of gaps between the page ranges. Afterwards it is more easy to put in some new parts.
The problem is, when printed out, it is hard to see if there misses any page. That is why I'd like to add in the title block a cell with "previous page" and "next page". Is there a possibility to do so, or will there be some option available in the future?
Re: Previous and next folio
You could use the arrows found in
QET Collection
  Electric
    All-Pole
      Folio referencing
Close to the title block on all pages draw a short line and use the arrows, and link to adjacent pages.
I use a similar method but link to and from block schematic page(s), using home brew symbols instead of the arrows.
it would be a good new feature,
For the moment, I'm already developing a new feature that will take some time to be finish.
I put your request it in the todo-list
Thank you for your reactions.
The option with the reference arrows is a nice temporary option, but I have one problem with it. I use references for a lot of connections with the following type (%F-%c), eg. 312-3. Since there are more references at one page the column number is needed.
For the Folio references though I would like to have only page numbers. I found a way to change them in the project settings, but then all the references change. Is there an option available to set the reference type to (%F) for these references only?
We think you 'll love it, I can not say more.. nomicons/happy
6 (edited by Nuri 2018-09-16 14:45:48)
is it the dictionnary for translations?
No nomicons/smiley-green
But I think you will be very interested by that, let Joshua work on it.
ok, then "miam miam"... nomicons/smiley-green
I 'm very eager to try it.  <3
Wow, you've got my attention. Love new features!
I guess many will go to the latest version 0.7-dev after. :angel:
I say no more.
Exciting !nomicons/wink
I guess many will go to the latest version 0.7-dev after. nomicons/angel
I say no more.
mmm... if I search it, I will find it! nomicons/whistling
Revision: 5664
Author: blacksun
Date: 2018-12-28 19:39:54 +0100 (Fri, 28 Dec 2018)
Log Message:
Title block : add two news variables, previous-folio-num and next-folio-num
