Topic: Single Line Conductor - Need more then 3.
Under Edit single line conductor, i need to add more then 3 phases, upto 10-12 (IHC cables or corr-B) in Denmark, i made some danish symbols and would like to translate to danish too, but before that, i need to know i can use the program.
Is there a way to remove limit of 3 phases?
Thanks nomicons/smile
Re: Single Line Conductor - Need more then 3.
at the moment, no, until you create the functionality by yourself.
3 (edited by inTempo 2017-04-19 21:35:45)
Okay, i did find the place where its coded, but i cannot compile the source.
Anyone have a complete Qt and MinGW that can compile it?
I installed MinGW, and trying to install Qt gives error about w32api.h wrong version, forced it, but keep getting alot of errors on on compile.
So if anyone have a complete source (or point to working source) + Qt+MinGW setup and can pack it, would be sweet.
Would also have been sweet if it was a Visual studio project nomicons/tongue
Its the source on the source page, i downloaded Qmake 4.4.0
MinGW i downloaded the installer, and just installed everything on the normal installation page in installer
Qmake errors:
Project MESSAGE: Warning: unknown QT: widgets
Project MESSAGE: Warning: unknown QT: printsupport
MinGW32-make error
K:\VisualStudio\qelectrotech-0.5-src>mingw32-make
mingw32-make -f Makefile.Release
mingw32-make[1]: Entering directory 'K:/VisualStudio/qelectrotech-0.5-src'
c:\Qt\4.4.0\bin\uic.exe sources\PropertiesEditor\propertieseditordockwidget.ui -o sources\ui\ui_propertieseditordockwidget.h
c:\Qt\4.4.0\bin\uic.exe sources\richtext\addlinkdialog.ui -o sources\ui\ui_addlinkdialog.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\autonumselectorwidget.ui -o sources\ui\ui_autonumselectorwidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\borderpropertieswidget.ui -o sources\ui\ui_borderpropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\conductorpropertiesdialog.ui -o sources\ui\ui_conductorpropertiesdialog.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\conductorpropertieswidget.ui -o sources\ui\ui_conductorpropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\diagramselection.ui -o sources\ui\ui_diagramselection.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\dialogautonum.ui -o sources\ui\ui_dialogautonum.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\dialogwaiting.ui -o sources\ui\ui_dialogwaiting.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\elementinfopartwidget.ui -o sources\ui\ui_elementinfopartwidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\elementinfowidget.ui -o sources\ui\ui_elementinfowidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\elementselectorwidget.ui -o sources\ui\ui_elementselectorwidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\imagepropertieswidget.ui -o sources\ui\ui_imagepropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\linksingleelementwidget.ui -o sources\ui\ui_linksingleelementwidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\masterpropertieswidget.ui -o sources\ui\ui_masterpropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\numparteditorw.ui -o sources\ui\ui_numparteditorw.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\potentialselectordialog.ui -o sources\ui\ui_potentialselectordialog.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\reportpropertiewidget.ui -o sources\ui\ui_reportpropertiewidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\selectautonumw.ui -o sources\ui\ui_selectautonumw.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\shapegraphicsitempropertieswidget.ui -o sources\ui\ui_shapegraphicsitempropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\titleblockpropertieswidget.ui -o sources\ui\ui_titleblockpropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\ui\xrefpropertieswidget.ui -o sources\ui\ui_xrefpropertieswidget.h
c:\Qt\4.4.0\bin\uic.exe sources\editor\ui\elementpropertieseditorwidget.ui -o sources\ui\ui_elementpropertieseditorwidget.h
g++ -c -std=c++11 -O2 -Wall -frtti -fexceptions -mthreads -DUNICODE -DQT_LARGEFILE_SUPPORT -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQT_DLL -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\4.4.0\include\QtCore" -I"c:\Qt\4.4.0\include\QtCore" -I"c:\Qt\4.4.0\include\QtNetwork" -I"c:\Qt\4.4.0\include\QtNetwork" -I"c:\Qt\4.4.0\include\QtGui" -I"c:\Qt\4.4.0\include\QtGui" -I"c:\Qt\4.4.0\include\QtXml" -I"c:\Qt\4.4.0\include\QtXml" -I"c:\Qt\4.4.0\include\QtSql" -I"c:\Qt\4.4.0\include\QtSql" -I"c:\Qt\4.4.0\include\QtSvg" -I"c:\Qt\4.4.0\include\QtSvg" -I"c:\Qt\4.4.0\include" -I"sources" -I"sources\titleblock" -I"sources\ui" -I"sources\qetgraphicsitem" -I"sources\richtext" -I"sources\factory" -I"sources\properties" -I"sources\dvevent" -I"sources\editor" -I"sources\editor\esevent" -I"sources\editor\graphicspart" -I"sources\undocommand" -I"sources\diagramevent" -I"c:\Qt\4.4.0\include\ActiveQt" -I"release" -I"sources\ui" -I"c:\Qt\4.4.0\mkspecs\default" -o release\propertieseditordockwidget.o sources\PropertiesEditor\propertieseditordockwidget.cpp
g++ -c -std=c++11 -O2 -Wall -frtti -fexceptions -mthreads -DUNICODE -DQT_LARGEFILE_SUPPORT -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQT_DLL -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\4.4.0\include\QtCore" -I"c:\Qt\4.4.0\include\QtCore" -I"c:\Qt\4.4.0\include\QtNetwork" -I"c:\Qt\4.4.0\include\QtNetwork" -I"c:\Qt\4.4.0\include\QtGui" -I"c:\Qt\4.4.0\include\QtGui" -I"c:\Qt\4.4.0\include\QtXml" -I"c:\Qt\4.4.0\include\QtXml" -I"c:\Qt\4.4.0\include\QtSql" -I"c:\Qt\4.4.0\include\QtSql" -I"c:\Qt\4.4.0\include\QtSvg" -I"c:\Qt\4.4.0\include\QtSvg" -I"c:\Qt\4.4.0\include" -I"sources" -I"sources\titleblock" -I"sources\ui" -I"sources\qetgraphicsitem" -I"sources\richtext" -I"sources\factory" -I"sources\properties" -I"sources\dvevent" -I"sources\editor" -I"sources\editor\esevent" -I"sources\editor\graphicspart" -I"sources\undocommand" -I"sources\diagramevent" -I"c:\Qt\4.4.0\include\ActiveQt" -I"release" -I"sources\ui" -I"c:\Qt\4.4.0\mkspecs\default" -o release\propertieseditorwidget.o sources\PropertiesEditor\propertieseditorwidget.cpp
g++ -c -std=c++11 -O2 -Wall -frtti -fexceptions -mthreads -DUNICODE -DQT_LARGEFILE_SUPPORT -DQET_ALLOW_OVERRIDE_CED_OPTION -DQET_ALLOW_OVERRIDE_CTBTD_OPTION -DQET_ALLOW_OVERRIDE_CD_OPTION -DQT_DLL -DQT_NO_DEBUG -DQT_SVG_LIB -DQT_SQL_LIB -DQT_XML_LIB -DQT_GUI_LIB -DQT_NETWORK_LIB -DQT_CORE_LIB -DQT_THREAD_SUPPORT -DQT_NEEDS_QMAIN -I"c:\Qt\4.4.0\include\QtCore" -I"c:\Qt\4.4.0\include\QtCore" -I"c:\Qt\4.4.0\include\QtNetwork" -I"c:\Qt\4.4.0\include\QtNetwork" -I"c:\Qt\4.4.0\include\QtGui" -I"c:\Qt\4.4.0\include\QtGui" -I"c:\Qt\4.4.0\include\QtXml" -I"c:\Qt\4.4.0\include\QtXml" -I"c:\Qt\4.4.0\include\QtSql" -I"c:\Qt\4.4.0\include\QtSql" -I"c:\Qt\4.4.0\include\QtSvg" -I"c:\Qt\4.4.0\include\QtSvg" -I"c:\Qt\4.4.0\include" -I"sources" -I"sources\titleblock" -I"sources\ui" -I"sources\qetgraphicsitem" -I"sources\richtext" -I"sources\factory" -I"sources\properties" -I"sources\dvevent" -I"sources\editor" -I"sources\editor\esevent" -I"sources\editor\graphicspart" -I"sources\undocommand" -I"sources\diagramevent" -I"c:\Qt\4.4.0\include\ActiveQt" -I"release" -I"sources\ui" -I"c:\Qt\4.4.0\mkspecs\default" -o release\qetgraphicshandlerutility.o sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp
In file included from sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:18:0:
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:38:45: error: 'QVector' does not name a type
   void drawHandler(QPainter *painter, const QVector<QPointF> &points, bool color2 = false);
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:38:52: error: expected ',' or '...' before '<' token
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:41:56: error: 'QVector' does not name a type
   int pointIsHoverHandler (const QPointF &point, const QVector<QPointF> &vector) const;
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:41:63: error: expected ',' or '...' before '<' token
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:42:3: error: 'QVector' does not name a type
   QVector<QRectF> handlerRect (const QVector<QPointF> &vector) const;
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:50:10: error: 'QVector' does not name a type
   static QVector <QPointF> pointsForRect (const QRectF &rect);
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:51:10: error: 'QVector' does not name a type
   static QVector <QPointF> pointsForLine (const QLineF &line);
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:63:6: error: prototype for 'void QetGraphicsHandlerUtility::drawHandler(QPainter*, const QVector<QPointF>&, bool)' does not match any in class 'QetGraphicsHandlerUtility'
 void QetGraphicsHandlerUtility::drawHandler(QPainter *painter, const QVector<QPointF> &points, bool color2) {
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:38:8: error: candidates are: void QetGraphicsHandlerUtility::drawHandler(QPainter*, int)
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:37:6: error:                 void QetGraphicsHandlerUtility::drawHandler(QPainter*, const QPointF&, bool)
 void QetGraphicsHandlerUtility::drawHandler(QPainter *painter, const QPointF &point, bool color2)
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:84:5: error: prototype for 'int QetGraphicsHandlerUtility::pointIsHoverHandler(const QPointF&, const QVector<QPointF>&) const' does not match any in class 'QetGraphicsHandlerUtility'
 int QetGraphicsHandlerUtility::pointIsHoverHandler(const QPointF &point, const QVector<QPointF> &vector) const
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.h:41:7: error: candidate is: int QetGraphicsHandlerUtility::pointIsHoverHandler(const QPointF&, int) const
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:100:88: error: no 'QVector<QRectF> QetGraphicsHandlerUtility::handlerRect(const QVector<QPointF>&) const' member function declared in class 'QetGraphicsHandlerUtility'
 QVector<QRectF> QetGraphicsHandlerUtility::handlerRect(const QVector<QPointF> &vector) const
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:136:77: error: no 'QVector<QPointF> QetGraphicsHandlerUtility::pointsForRect(const QRectF&)' member function declared in class 'QetGraphicsHandlerUtility'
 QVector<QPointF> QetGraphicsHandlerUtility::pointsForRect(const QRectF &rect)
sources\QetGraphicsItemModeler\qetgraphicshandlerutility.cpp:165:77: error: no 'QVector<QPointF> QetGraphicsHandlerUtility::pointsForLine(const QLineF&)' member function declared in class 'QetGraphicsHandlerUtility'
 QVector<QPointF> QetGraphicsHandlerUtility::pointsForLine(const QLineF &line) {
Makefile.Release:1833: recipe for target 'release/qetgraphicshandlerutility.o' failed
mingw32-make[1]: *** [release/qetgraphicshandlerutility.o] Error 1
mingw32-make[1]: Leaving directory 'K:/VisualStudio/qelectrotech-0.5-src'
Makefile:34: recipe for target 'release' failed
mingw32-make: *** [release] Error 2
Why?
Install Qt with MinGW and qt creator IDE.
FYI, you could see my documentation.
https://qelectrotech.org/wiki_new/doc/dev_windows
Hey! it 's only Qt5 after QET 0.4 version.
Download Qt 5.8 or other version for visual studio and build latest QET source.
Like Qt 5.8.0 for Windows 64-bit (VS 2015, 1.0 GB)
https://www.qt.io/download-open-source/#section-2
8 (edited by inTempo 2017-04-19 22:12:51)
Ah okay thanks, i followed guide here
qelectrotech.org/wiki_new/en/doc/test_dev_version
said download the file “qt-win-opensource-4.4.0-mingw.exe”.
So of course i used that, i will try with the 5.8, thank you.
Guide is very old, now I cross-compil Windows packages directly in my Debian.
Windows is very slow for this thing, Gnu/Linux is very faster.
