1 (edited by Nuri 2017-02-23 16:03:48)
Topic: DXFtoQET version from 26.03.2016 does not work
I wanted to try the newer version of the DXFtoQET converter and I have downloaded this binary from here:
https://download.qelectrotech.org/qet/b … 016-03-26/
Then, I put the binary in /home/nuri/.qet and start QET.
I open the element editor and click on "Starting the DXf converter plugin" and... nothing happens nomicons/wassat
There was no problem with the older version (from 15.11.2015) available here:
https://download.qelectrotech.org/qet/b … 4_qt5.5.1/
Furthermore, the DXFtoQET 15.11.2015 is about 1MB big and those from 26.03.2016 is about 20MB big.
Why such a difference? nomicons/pouty
Re: DXFtoQET version from 26.03.2016 does not work
You run chmod +x DXFQET before?
Latest is builded in debug mode, don't run perfect in release mode ..
Same thing with latest ronny commit, and the result isn't nice for the moment.
nomicons/blush
Now it's working!
Why it does not work to upload files on your links. Do you think this could be because of the fact that I use a proxy? Or is it something wrong with the links themselves? Thanks for the reply.
What links?
Revision: 4932
Author:   rdsivd
Date:     2017-03-18 12:10:54 +0100 (Sat, 18 Mar 2017)
Log Message:
added Mtext and spline
Linux X86_64 Qt 5.7.1 build here :
https://download.qelectrotech.org/qet/b … 8/DXFtoQET
