Topic: Strange: r4773 dont build in qtdesigner, but with make
Nice to see QET developing nomicons/smile
I know trunk may break sometimes. Here is what i found now:
r4773: Build suceeds with make but fail with qtcreator with message:
/build-qelectrotech-Desktop-Debug/debug/nomenclature.o:-1: In function `nomenclature::getElementInfo(Element*)':
/qelectrotech-trunk/sources/nomenclature.cpp:146: error: undefined reference to `autonum::AssignVariables::formulaToLabel(QString, autonum::sequenceStruct&, Diagram*, Element*)'
...and similar for following rows.
Re: Strange: r4773 dont build in qtdesigner, but with make
Thanks, it compiles, clean project, run qmake and compiling again, when fail to build with qt creator.
3 (edited by Morganol 2016-11-11 18:58:01)
1) How do i clean project?
2) was thingking qtdesigner ran qmake automatically...?
3) now i did svn up so i am now on r4774, started qtdesigner and selected Build>Run qmake, and then Build>Rebuild project and it went fine, now i run 4774 in debug mode.
4) I note now that it does not crash when i quit, like it used to nomicons/smile
5) New bug thing: QET GUI used to be in english, now it is in french!
In the dialog "Configure electrotech" at bottom the settign is "Systéme" like it was before.
And even when i change to "Anglais", and restart, it is still in french!
6) ...and it displays no default elements, only my custom...?!
Update: When i compile in console with qmake and make all is OK including 5 and 6.
Now i will try to check out with svn to a fresh dir and then use that for qtdesigner... will update here after that
(I am not running svn from within qtdesigner)
...that brought me r4775 nomicons/smile fresh in another folder
And it compiles with qtdesigner and works in debug mode as it should nomicons/smile
In build menu -> clean project ...
https://download.qelectrotech.org/qet/forum_img/qtcreator2.png
No.
Revision: 4774
Author:   scorpio810
Date:     2016-11-11 15:55:30 +0100 (Fri, 11 Nov 2016)
Log Message:
Fix warnings assignvariables
Nice !
Check your project config and command line argument in run field !
--common-elements-dir=/home/laurent/trunk/elements --lang-dir=/home/laurent/trunk/lang  --common-tbt-dir=/home/laurent/trunk/titleblocks
6
Thank you nomicons/smile
