Topic: Automatic numbering bugs
Good day, sirs!
Just look at the video
Bug#1
https://drive.google.com/open?id=0B-TYW … E11dWw4LTg
Bug#2
https://drive.google.com/open?id=0B-TYW … U1COFlkV1U
Thanks!
QElectroTech → EN : Help, suggestions, discussions, ... → Automatic numbering bugs
Good day, sirs!
Bug#1
Bug#2
Thanks!
could you send us your project for examine problem, in private if you wish it?
sure. Send me please your e-mail
Read in about QET menu.
I will forward to Davi, and Joshua.
You have send your project to mailling list in the moderation tail, this ML is public and all guys can read, and if is very important and privy I prefer not moderate this mail wich whas sent by you.
In about qet search scorpio in authors tab and dfochi in contributeurs tab email or in this url, or by private message on this forum:
https://qelectrotech.org/contact.html.en
ok
<conductor num="504" frozenlabel="504" terminal1="21" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="10" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
<conductor num="504" frozenlabel="504" terminal1="10" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="23" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
Strange !
<conductor num="%id%seqt_1" frozenlabel="%id%seqt_1" terminal1="25" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="11" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
<conductor seqt_1="00" num="%id%seqt_1" frozenlabel="%id%seqt_1" terminal1="34" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="42" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/><conductor seqt_1="03" num="%id%seqt_1" frozenlabel="%id%seqt_1" terminal1="40" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="30" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
<conductor seqt_1="06" num="%id%seqt_1" frozenlabel="%id%seqt_1" terminal1="31" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="24" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
<conductor vertirotatetext="270" function="" y="0" frozenlabel="504" seqt_1="04" x="0" numsize="7" terminal2="41" condsize="1" userx="620" num="504" displaytext="1" tension-protocol="" terminal1="28" onetextperfolio="1" usery="400" horizrotatetext="0" type="multi"/>
<conductor seqt_1="07" num="504" frozenlabel="504" terminal1="22" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="29" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
<conductor seqt_1="08" num="504" frozenlabel="504" terminal1="26" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="39" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
<conductor num="504" frozenlabel="504" terminal1="20" y="0" tension-protocol="" vertirotatetext="270" displaytext="1" x="0" terminal2="27" condsize="1" type="multi" function="" onetextperfolio="1" horizrotatetext="0" numsize="7"/>
</conductors>
Don't use conductor autonum %ID for linking by report element to other conductor. #2
Thank you for reporting these problems and for having send your project, we believe that these problems are now solved.
Revision: 4744
Author: blacksun
Date: 2016-10-17 14:17:45 +0200 (Mon, 17 Oct 2016)
Log Message:
Keep up to date the label of element when folio position change (Formula contain %id)
Revision: 4746
Author: blacksun
Date: 2016-10-17 16:26:13 +0200 (Mon, 17 Oct 2016)
Log Message:
Bug fix : Conductor text with formula that contain %id isn't good when open project (variable %id is replaced by 0 in each folio)
Generated in 0.041 seconds (23% PHP - 77% DB) with 11 queries
