1 (edited by shestipal 2016-08-07 22:40:45)
Topic: Arrows move
Good evening.
When I select the element, I can move it down, but when I press up arrow it does not react
[size=4]QElectroTech V 0.51-dev+svn4607
[size=4]ubuntu 16.04
[size=4] This bug has come approximately one week ago . Thanks
Re: Arrows move
When I select text and press ctrl+c then ctrl+v it inserts the text on the same place, but then I try to move selected text to the new position - only folio moves, but text is on the old place.
It is strange because in works with elements but it doesnot work with text =(
Thanks!
3 (edited by scorpio810 2016-08-07 23:09:12)
Re: Arrows move
Good evening,
No problem here.
Right click on element or a text field, you see menu cut/copy, and paste text where is mouse cursor position.
Re: Arrows move
thanks, everything works well now
Re: Arrows move
shestipal wrote:
When I select the element, I can move it down, but when I press up arrow it does not react.
Thanks for reporting this bug. I committed a fix for it today. If you experience any other strange behavior please report it.
Re: Arrows move
sorry for delay. Everything is OK now. Thanks dfochi!
