76
Re: Folios non consecutive numbering, new dock collection element (EN)
galexis wrote:
Thank you Davi for your help and to explain your commit. nomicons/smile
https://download.qelectrotech.org/qet/forum_img/autonum-element3.png
Hello,
se serait possible une explication en français de ce nouveau panneau ?
Merci
Oui, Click sur le bouton aide. ;-)
77
Super !
78
Revision: 4674
Author: dfochi
Date: 2016-08-29 17:37:42 +0200 (Mon, 29 Aug 2016)
Log Message:
Conductor Autonum now works with variables. Folio Autonumberings added to conductor autonum
This is the final transition of conductor autonumbering to variables. So now conductor autonumberings work with Folio Numberings (this is the biggest change). There is a lot of class renaming and deletion so the methods can work with both conductor and element autonums. Also, I expect to commit the Update Policy for Conductors as well so that user can set when the variables will be updated or not. Since there is a lot of lines added I expect some bugs to be found but I tried to make the code compatible with element autonum (there is still room for improvement in the compatibility) so that it would be easier to correct bugs.
79
Thank you Davi, I prepare new nightly build packages, so that anybody can try this new feature.
80
Revision: 4679
Author:   dfochi
Date:     2016-08-31 21:58:58 +0200 (Wed, 31 Aug 2016)
Log Message:
Updated qet_labels xml. Element formula now works with all elements types (logic, hydraulic, pneumatic and energy)
81
Revision: 4680
Author: dfochi
Date: 2016-09-01 21:41:49 +0200 (Thu, 01 Sep 2016)
Log Message:
Update Policy now works with conductor autonumberings
With this commit user can now set wheter to freeze or unfreeze conductor labels. I will make a video about this and post it as soon as I can
82 (edited by dfochi 2016-09-01 23:19:20)
Basic video showing some capabilities of Conductor and Element Variables and the Update Policy:
https://download.qelectrotech.org/qet/f … olicy.webm
https://download.qelectrotech.org/qet/forum_img/element_conductor_policy.webm
83
Nice video Davi, thanks.
Petite vidéo et patch fais à la va vite ou plutôt à la méthode Rache nomicons/tongue pour ajouter les labels sur les bornes, le but étant de se servir de tous les outils mis en place dernièrement règles Autonum, politique de management, etc.
De pouvoir ainsi dans la nomenclature connaitre le label du bloc et nom de la borne, position, etc.
Bon, pour l'instant les règles de numérotation auto ne fonctionnent pas encore.
Ce n'est qu'un petit hack sur le code de mon coté, reste encore à en discuter entre nous : plutôt que de faire un widget rien que pour la gestion des bornes, autant se servir de ce qui existe déjà, non?
https://download.qelectrotech.org/qet/forum_img/sommaireTerminal2.png
https://download.qelectrotech.org/qet/forum_img/sommaireTerminal.png
https://download.qelectrotech.org/qet/forum_img/sommaireTerminal3.png
https://download.qelectrotech.org/qet/forum_img/TerminalAutonum.png
84
C'est super tous ces petits aménagements, script : cela permet de réfléchir à comment pourrait fonctionner le système final.
Justement, si on commençait à parler de propriétés de borne/bornier ? Le sujet a souvent été ouvert mais n'est jamais allé très loin.
Faut-il ajouter une propriété "terre", "sectionnable" pour adapter le symbole dans le dessin du bornier ?
Faut-il pouvoir définir quelques part si le bornier est constitué de bornes étagées 2, 3 niveaux ou plus ?
Faut-il que les labels de bornes soient "liés" à un bornier pour leur appliquer la bonne représentation ?
85
Déjà pour commencer, le premier but à atteindre est de faire fonctionner la numérotation automatique sur ces éléments "borne/bornier", afin que l'utilisateur puisse créer ses propres règles borniers X1, X2, X3, etc, maintenant que ces éléments ont un label !
Pour l'instant tout est en place, nouveau Widget Autonum borne, etc, j'ai envoyé mon gros patch à Davi, voir s'il trouve ce qui coince.
Quand au script python il ne fonctionne qu'avec des labels de type X1:01 et les bornes d'Unalcalde.
Soit
X1 = nom du bloc de bornier (parent)
:   = séparateur
01 = nom de la borne (enfant)
A voir avec Unalcalde, c'est au niveau du script qu'on doit choisir la représentation des borniers.
exemple: bloc bornier X2 : simple, X3 : double étage, etc
86
Tu en connais beaucoup toi de borniers étagés sur 3 niveaux ou plus... déjà que deux étages c'est souvent une sacrée merde ... en dépannage ou si tu veux faire des modifications ..
87
Oui, de mémoire weidmuller en fait sur 4 étages et je crois bien, qu'ils en ont sur plus encore, en forme de pyramide !
http://catalog.weidmueller.com/procat/G … page=Group
88
Le script est destiné à rester ?
89
Revision: 4683
Author:   scorpio810
Date:     2016-09-03 20:22:14 +0200 (Sat, 03 Sep 2016)
Log Message:
Add Autonum for terminal elements
90
91
Workaround for terminal block label bug:
92
Revision: 4685
Author:   scorpio810
Date:     2016-09-04 17:19:36 +0200 (Sun, 04 Sep 2016)
Log Message:
Add new option in config for export or not terminal elements in nomenclature
93
Conductor AutoNum + Terminal AutoNum + Element AutoNum + plugin Python
94
Revision: 4686
Author:   dfochi
Date:     2016-09-04 20:14:26 +0200 (Sun, 04 Sep 2016)
Log Message:
Fix Undo(Ctrl+Z) crash related with conductor frozen label. Prevent freezing blank label in conductor
Revision: 4689
Author:   scorpio810
Date:     2016-09-05 18:49:16 +0200 (Mon, 05 Sep 2016)
Log Message:
Minor : Assign new variables %M and %LM to Conductor Autonum
95
Revision: 4698
Author: blacksun
Date: 2016-09-10 17:16:35 +0200 (Sat, 10 Sep 2016)
Log Message:
Minor fix: Unable to open elements directory with the elements panel in windows
96
Revision: 4707
Author:   scorpio810
Date:     2016-09-15 05:02:56 +0200 (Thu, 15 Sep 2016)
Log Message:
Add new action in help menu for launch the Manual online with Web browser by
default
97
Revision: 4710
Author:   scorpio810
Date:     2016-09-15 13:48:34 +0200 (Thu, 15 Sep 2016)
Log Message:
Minor : add a link to QET Youtube channel
Add a shortcut F1 for open manual online
Add a link for download latest devel build for Windows (only visible on
Win platform)
https://download.qelectrotech.org/qet/forum_img/links.png
98
Ceux sous Mac OS pourront profiter d'un paquet plus récent que la version 0.5 ici :
qelectrotech 0.51-dev r4650
99
Je viens de compiler la dernière version du trunk soit la 0.51-dev 4721 pour Mac OS sur ma Debian avec mon AMD FX 8350. (Yosemite  Xcode 6.1, Qt 5.6.1)
https://download.qelectrotech.org/qet/b … 0r4721.dmg
Enjoy ! nomicons/smile
https://download.qelectrotech.org/qet/forum_img/Qet-yosemiteAMD-FX8350.png
100
Revision: 4722
Author:   blacksun
Date:     2016-09-25 10:14:29 +0200 (Sun, 25 Sep 2016)
Log Message:
Element editor : add new handler for arc to resize angle with mouse.
