Topic: Hotkeys in element editor do not work and software unexpectedly close
Good day dear sirs.
Ubuntu 16.04LTS with all updates arhitecture 64.
Help please, I really like this software (these two bugs at my pc and my colleague PC )
Thanks in advance!
Re: Hotkeys in element editor do not work and software unexpectedly close
Hi Shestipal,
What your version 0.5, or 0.51-dev?
3 (edited by shestipal 2016-07-23 16:13:12)
version .5
Hi scorpio810, I discovered that qet closes not unexpectedly. It happens after I delete connection I see grafical artefact (i mean that i steel see this connection but there is not). And next operation cause to crash. Every time the same. Thanks for quick reply!
You could try 0.51-dev Nightly builds with my Ubuntu PPA.
I think your problem is solved in this devel version.
https://qelectrotech.org/wiki_new/doc/install_ubuntu
Thanks, scorpio. I've installed. I will test and report. Bug with language switching does not disappear for sure. The rest I will test.
When you switch Language you need to restart QET, or re load element collection.
Thanks.
0.51-dev :
Improve RAM used
Faster load on start
Faster load project
Conductors size, new basic shapes pattern and style, copy folio in other project, Label folio, automatic num for element, conductor folio and swith to empty rules, etc.
sorry, Scorpio. I meant switch input method for sure.
and one more think. If you will plan something new.
When I select something it is really difficult to select something which touches other elements. I always select what i do not need. I would like to select inner space but i select everything which touches the frame.
The better way is to select inner space when you drug mouse from left, and select everything which touches frame when you drag from right to left.
Thanks
Dear Scorpio. 0.51 is totally disappointed. It crashes every time when i connect one terminal to another with switched on auto connection and when I try to put my own element from library with switched on auto connection.
Also if I switched off auto connection option it crashes but not instantly. Tell me how I can help you to discower this problem
Thank you for reporting this bug.
No time today for found which commit has the bug, latest Joshua or Davi commit.
Thanks Scorpio. Please inform when I can update my qet to 0.51
Very good software!
This is rev 4586 which crash QET with terminal element.
and you will prepare "good" 0.51 without bugsy commit?
Yes off course. nomicons/tongue
Revision: 4590
Author:   dfochi
Date:     2016-07-25 16:17:54 +0200 (Mon, 25 Jul 2016)
Log Message:
Fix Terminal Crash and corrected Terminal prefix behavior.
everything is ok, thanks Scorpio!
