Topic: Language switch cause to jump to unexpected place
For example if you are inside text field it exits from it. If you are in the folio tittle it goes to the text field.
Version 0.5
Ubuntu 16.04LTS x64
QElectroTech → EN : Help, suggestions, discussions, ... → Language switch cause to jump to unexpected place
Version 0.5
Ubuntu 16.04LTS x64
I don't understand, could you explain better your problem or add image screen.
I will little bit later. Sure
https://drive.google.com/open?id=0B-TYW … EQwOVJvNEk
here you can see when I press capslock to switch language it jumps from "tittle" to "text" field
and also here in text field when I switch input language it exits text field
https://drive.google.com/open?id=0B-TYW … FdDNERyWnc
check please!
Only tab key jump to latest imput text field no capslock key.
Check yor keymap config, please.
strange. Looks everything is OK. But it does not disturb me. Thanks
Generated in 0.022 seconds (35% PHP - 65% DB) with 12 queries
