Topic: Changing cross reference symbols
I am using Qelectrotech to make a hydraulics schematic and I would like to reference valves from one folio to the other. the only problem is the contact symbol which apears in the schematics and has nothing to do there. is there a way to take it out, just leaving the reference visible?
Re: Changing cross reference symbols
Hi Julian,
symbols for Xref is hardcoded, btw you could see and hack this workaround : is use reports folio properties fonction.
http://qelectrotech.org/forum/viewtopic … 3141#p3141
Or try directly with these elements :
/qelectrotech/elements/10_electric/98_graphics/01_auxiliary_symbols/01_cross_ref_symbols
I cannot find /01_cross_ref_symbols it's not in the directory.
And I thought about the report folio properties but it doesn't let me use two terminals.
is in latest packages, but you could download at this url :
You could try to open in text editor your element and change link_type="simple" by
link_type="previous_report" or link_type="next_report"
Your element must contain a field texte "/" to work
Thanks i'll try that
