Topic: [0.200.1-dev] Spacebar rotation doesn't work before placing the first
In QElectroTech v0.200.1-dev (tested on both Windows and macOS), pressing the Spacebar to rotate an element while dragging/hovering it over the diagram before placing it does not work initially.
Steps to reproduce:
1. Drag an element from the elements collection panel onto the diagram area.
2. Before clicking to place it, press the Spacebar to rotate it -> Nothing happens (tested in both Spanish and English UI, across Windows and macOS).
3. Once you click to place the first element, the next floating element in continuous placement mode CAN be rotated normally with the Spacebar.
Workaround / Root cause clue:
While holding the floating element before placing it, if you click once on the diagram's title bar (or header area), the keyboard focus transfers from the collection panel to the diagram view, and the Spacebar rotation immediately starts working before placing the element.
Since this happens identically on both Windows and macOS, it looks like a cross-platform Qt focus issue where DiagramView does not automatically grab keyboard focus when dragging an element from the collection tree.
Best regards.
