Topic: New: universal macOS nightly DMG (Apple Silicon + Intel), Qt 6+ KF6
Hello everyone,
A macOS DMG is now built automatically by our GitHub CI, alongside the Windows MSI installer and the Linux AppImage, each time a maintainer or I trigger the Windows build run.
It is not built on every commit: new nightly builds appear on the download page after each of these runs.
  • Universal binary: one DMG for Apple Silicon (arm64) and Intel (x86_64) Macs
  • Qt 6.11 with KF6, built from the current master branch
  • macOS 14 (Sonoma) or newer
I have tested it on my Mac mini, natively on Apple Silicon and the Intel version through Rosetta 2: everything works, including the project database export, PDF import, etc.
How to test it yourself (in the Terminal, after copying QElectroTech to Applications):
Check that the binary is universal (should print x86_64 arm64):
lipo -archs /Applications/qelectrotech.app/Contents/MacOS/qelectrotech
On an Apple Silicon Mac, you can also run the Intel version. Install Rosetta 2 first if it is not already installed:
softwareupdate --install-rosetta --agree-to-license
then start QElectroTech in Intel mode:
arch -x86_64 /Applications/qelectrotech.app/Contents/MacOS/qelectrotech
Note: type these commands rather than copy them from a web page if you get a "usage" error: some browsers or editors turn the double dash -- into a long dash.
You can download it from the nightly page:
https://qelectrotech.github.io/qelectro … ce-mirror/
Important: this nightly DMG is not signed with our Apple Developer ID (no certificate is stored in the CI, for security reasons). macOS will block it at first launch. To open it, after copying QElectroTech to your Applications folder, either:
  • go to System Settings > Privacy & Security and click Open Anyway, or
  • run this command in the Terminal:
xattr -dr com.apple.quarantine /Applications/qelectrotech.app
Signed and notarized DMGs are still available on the QElectroTech download page, as before:
https://download.qelectrotech.org/qet/builds/MAC_OS_X/
I keep building these signed and notarized Apple Silicon (aarch64) DMGs myself, on my new Mac mini. If you do not want to deal with the step above, or for production use, please keep using those.
A big thank you to all our donors: this new Mac mini was bought with your donations to QElectroTech. It is used to build, sign, notarize and test QElectroTech on macOS. Your support makes this possible!
These nightly builds are for testing. Feedback is welcome, especially from Intel Mac users: please report any problem here or on GitHub.
Thanks!
