Folio-wide crosshair under the mouse (Display menu)- #1559
https://github.com/qelectrotech/qelectr … /pull/1559
QElectroTech → News → Nouveautés de la version de développement 0.9> 0.200.1
Hi all,
A new Linux AppImage of QElectroTech is available for testing: QElectroTech_0.200.1-r11275-x86_64.AppImage (~73 MB).
Built from current master with Qt 6.11.2 and KDE Frameworks 6
Built on Ubuntu 24.04, so it needs glibc 2.39 or newer: Ubuntu 24.04+, Debian 13+, Fedora 40+, Arch, openSUSE Tumbleweed. It will not run on Ubuntu 22.04 or Debian 12.
No libfuse2 required
Includes the project database export, PDF links, etc..
Download: https://download.qelectrotech.org/qet/b … .0/X86_64/
Usage:
chmod +x QElectroTech_*.AppImage
./QElectroTech_*.AppImagePlease report any problem here (distribution, desktop, X11 or Wayland). Thanks for testing!
Now added AppImages to GitHub CI/CD:
https://qelectrotech.github.io/qelectro … ce-mirror/
Where .qetdb stands: what works, what's next, and testers wanted
https://github.com/qelectrotech/qelectr … sions/1648
Add a history of saves inside a .qetdb, off by default
https://github.com/qelectrotech/qelectr … /pull/1659
macOS arm64: new build with Qt 6.12 — fonts and collections fixed
Hello everyone,
A new macOS arm64 (Apple Silicon) build is available: qelectrotech-0.200.x-rXXXX-arm64.dmg
Download page
What changed
Fonts: the fonts shipped with QET (Liberation Sans/Serif/Mono and osifont) were missing from the font chooser in Settings > Texts on macOS, so they could only be picked after installing them by hand from the .app bundle. QET now uses Qt's own font dialog everywhere, which lists them directly. If you installed these fonts manually as a workaround, you can remove them from Font Book.
Qt 6.12: the bundle is now built with Qt 6.12 (Homebrew).
Packaging: the build script now stops on any missing file instead of producing an incomplete bundle (elements collection, title blocks, icon, Info.plist).
If you downloaded a macOS build earlier today and QET does not find the elements collection or the title blocks, please download the new one: that build was incomplete.
As this is the first build with Qt 6.12, feedback is welcome, especially on:
the font dialogs (Settings > Texts, element editor, tables, cross references);
opening and saving projects, including .qetdb files;
translations of the standard buttons (OK/Cancel...) in your language.
Thanks for your reports!
Feature/dimensioning- #1666
https://github.com/qelectrotech/qelectr … /pull/1666
47 new features on master, 15 October – 1 November 2026
https://github.com/qelectrotech/qelectr … sions/1701
16 new features on master, 1–7 November 2026
https://github.com/qelectrotech/qelectr … sions/1771
Generated in 0.037 seconds (16% PHP - 84% DB) with 11 queries
