Oi Jucelei, O scorpio810(manager) tinha sugerido numa discussao aqui um scrypt que dois Brasileiros criaram, eu achei que era para o To/FROM. Mudei uma ou duas linhas e consegui.
I found a Python scrypt created by two brasiliens, i'm asking if it was he.
Here you are the crypt. double-click on the py file and it generates the .csv file. You should write your good file path in the end of scrypt. If not it simply doesn't do anything. Any error
#To use with QElectroTec software; qet files generating a .csv file
#labels from/to
#Transformed by Daniel Berlowitz - 2026-09-09
#Ver 1a
import zipfile
import xml.etree.ElementTree as ET
import os
import tempfile
import csv
def extract_content_qet(file_path):
"""Unzip .qetz or return .qet path"""
if zipfile.is_zipfile(file_path):
with zipfile.ZipFile(file_path, 'r') as zip_ref:
temp_dir = tempfile.mkdtemp()
zip_ref.extract('content.qet', temp_dir)
return os.path.join(temp_dir, 'content.qet')
return file_path
def build_terminal_uuid_map(root):
"""Builds a dict mapping terminal UUIDs to their names"""
terminal_map = {}
for terminal in root.iter('terminal'):
uuid = terminal.get('uuid')
name = terminal.get('name')
if uuid and name:
terminal_map[uuid] = name
return terminal_map
def build_link_uuid_map(root):
"""Builds a dict mapping link UUIDs to their associated element UUIDs"""
link_map = {}
for element in root.iter('element'):
element_uuid = element.get('uuid')
links_node = element.find('links_uuids')
if links_node is not None:
for link in links_node.findall('link_uuid'):
link_uuid = link.get('uuid')
if link_uuid:
print(f"{element_uuid} -> {link_uuid}")
link_map[link_uuid] = element_uuid # You can also store the full element if needed
return link_map
def find_element_by_uuid(root, target_uuid):
"""Finds the <element> with the given UUID"""
if element.get('uuid') == target_uuid:
return element
return None
def find_parent_by_uuid(root, target_uuid):
"""Finds the parent of the <element> with the given UUID"""
for parent in root.iter('diagram'):
for child in parent.iter('element'):
if child.get("uuid") == target_uuid:
return parent
return None
def extract_conductors_with_terminal_names(root, terminal_map, link_map):
"""Extracts conductor data and resolves terminal UUIDs to names"""
conductors = []
seenlinks = []
for conductor in root.iter('conductor'):
start_uuid = conductor.get('terminal1')
end_uuid = conductor.get('terminal2')
element1_name = conductor.get('element1_name')
element1_label = conductor.get('element1_label')
element1_uuid = conductor.get('element1')
element2_name = conductor.get('element2_name')
element2_label = conductor.get('element2_label')
element2_uuid = conductor.get('element2')
seen = False
if(conductor.get('element1_name') == "Going arrow" or conductor.get('element1_name') == "Coming arrow"):
element1_name = "*****"
print("Element 1 is a reference")
print(f"Element 1 uuid = {element1_uuid}")
ele = find_element_by_uuid(root, element1_uuid)
if ele is not None:
links_node = ele.find('links_uuids')
if link_uuid:
if link_uuid in seenlinks:
print(f"link uuuid {link_uuid} already seen")
seen = True
else:
print(f"Element 1 link uuuid {link_uuid}")
for conductor2 in root.iter('conductor'):
if conductor2.get('element2') == link_uuid:
print(f"adding {element1_uuid}")
seenlinks.append(element1_uuid)
element1_name = conductor2.get('element1_name')
element1_label = conductor2.get('element1_label')
element1_uuid = conductor2.get('element1')
start_uuid = conductor2.get('terminal1')
if conductor2.get('element1') == link_uuid:
print(f"adding {element2_uuid}")
seenlinks.append(element2_uuid)
element1_name = conductor2.get('element2_name')
element1_label = conductor2.get('element2_label')
element1_uuid = conductor2.get('element2')
start_uuid = conductor2.get('terminal2')
if(conductor.get('element2_name') == "Going arrow" or conductor.get('element2_name') == "Coming arrow"):
print("Element 2 is a reference")
print(f"Element 2 uuid = {element2_uuid}")
ele = find_element_by_uuid(root, element2_uuid)
if ele is not None:
if link_uuid:
seen = True
else:
print(f"Element 2 link uuuid {link_uuid}")
element2_name = conductor2.get('element2_name')
element2_label = conductor2.get('element2_label')
element2_uuid = conductor2.get('element2')
end_uuid = conductor2.get('terminal2')
element2_name = conductor2.get('element1_name')
element2_label = conductor2.get('element1_label')
element2_uuid = conductor2.get('element1')
end_uuid = conductor2.get('terminal1')
ele1 = find_element_by_uuid(root, element1_uuid)
ele2 = find_element_by_uuid(root, element2_uuid)
element1_loc = ""
element2_loc = ""
if ele1 is not None:
info_container = ele1.find('elementInformations')
if info_container is not None:
for elem in info_container.findall('elementInformation'):
if elem.attrib.get('name') == 'location':
element1_loc = elem.text
if ele2 is not None:
info_container = ele2.find('elementInformations')
element2_loc = elem.text
if seen == False:
if not element1_loc:
print(f"Element1 loc is empty")
parent = find_parent_by_uuid(root, element1_uuid)
if parent:
element1_loc = "+" + str(parent.get('locmach') or '')
if not element2_loc:
print(f"Element2 loc is empty")
parent = find_parent_by_uuid(root, element2_uuid)
if parent:
element2_loc = "+" + str(parent.get('locmach') or '')
# --- MODIFICAÇÃO LOGICA DE-PARA ORIGEM/DESTINO ---
term1_name = terminal_map.get(start_uuid, '??')
term2_name = terminal_map.get(end_uuid, '??')
# Formata a string destino final de cada ponta (Ex: -FC1:2 ou -X1:5)
# Você pode concatenar a localização se preferir, ex: f"{element2_loc}{element2_label}:{term2_name}"
tag_para_ponta_S = f"{element2_label}.{term2_name}"
tag_para_ponta_E = f"{element1_label}.{term1_name}"
# LINHA 1: Etiqueta física para o lado S (Start) apontando para onde ele VAI (Destino)
conductors.append({
#'ONDE_SERA_CONECTADO': f"{element1_label}.{term1_name}:{element2_label}.{term2_name} ",
'ONDE_SERA_CONECTADO /': f"{element1_label}.{term1_name}/{element2_label}.{term2_name} ",
#'TEXTO_ANILHA_IMPRESSAO': tag_para_ponta_S,
'LOCALIZACAO': element1_loc,
'COMP_PART': element1_name,
'SECAO_CABO': conductor.get('conductor_section'),
'COR_CABO': conductor.get('conductor_color'),
'TAG_FIO_SINAL': conductor.get('num')
# Il sera tout sur une ligne. LINHA 2: Etiqueta física para o lado E (End) apontando para de onde ele VEM (Origem)
#conductors.append({
# 'ONDE_SERA_CONECTADO': f"{element2_label}.{term2_name}",
# 'TEXTO_ANILHA_IMPRESSAO': tag_para_ponta_E,
# 'LOCALIZACAO': element2_loc,
# 'COMP_PART': element2_name,
#'SECAO_CABO': conductor.get('conductor_section'),
# 'COR_CABO': conductor.get('conductor_color'),
# 'TAG_FIO_SINAL': conductor.get('num')
return conductors
def process_qet_file(file_path, output_csv='conductors_named.csv'):
qet_path = extract_content_qet(file_path)
tree = ET.parse(qet_path)
root = tree.getroot()
terminal_map = build_terminal_uuid_map(root)
link_map = build_link_uuid_map(root)
conductors = extract_conductors_with_terminal_names(root, terminal_map, link_map)
# --- ESSE BLOCO GERA O ARQUIVO NO SEU COMPUTADOR ---
if conductors:
with open(output_csv, 'w', newline='', encoding='utf-8') as f:
# Correção: Pega as chaves do primeiro item da lista para definir o cabeçalho
keys = conductors[0].keys()
writer = csv.DictWriter(f, fieldnames=keys)
writer.writeheader()
writer.writerows(conductors)
print(f"Exported {len(conductors)} wire labels (De-Para) to {output_csv}")
else:
print("No conductors found.")
# Execução automática do Script ao rodar o arquivo
if __name__ == "__main__":
process_qet_file(r"D:\python on QElectroTech tests\STM030000 Formation Rack, Schema Electrique.qet")
