Topic: Fix issue on macOS: Not able to open a *.qet file with double click
Fix issue on macOS: Not able to open a *.qet, *.elmt, *.tittleblock file with double click under osx:
https://github.com/qelectrotech/qelectr … issues/218
Thanks Ispyisail for the detailed trace.
New macOS build was uploaded.
Enjoy it! nomicons/wink
Re: Fix issue on macOS: Not able to open a *.qet file with double click
FYI, macOS Apple Silicon arm64, signed and notarized it's now on Qt6 + KF6 frameworks ports.
Enjoy! nomicons/wink
Edit:
## macOS: KF6 dependency notes for arummler (Homebrew build)
I spent some time this week digging into the KF6-on-Homebrew situation for the macOS build and wanted to share what I found, so this isn't blocking or urgent — just a pointer for when you get to it.
### Starting point
I based my testing on Gilles Caulier's (digiKam maintainer) Qt6/KF6 compilation setup for Homebrew, rather than the MacPorts framework — trying to see if it could be a faster/simpler path than MacPorts for getting KF6 on macOS.
### What I ran into
- Some KF6 modules in Gilles' Homebrew tap/build failed to compile. After checking, none of the failing modules are actually needed by QET, so they can just be skipped/excluded rather than fixed.
- I also revisited the old QET wiki instructions for a KF5 Homebrew tap (`kde-mac/kde`, https://invent.kde.org/packaging/homebrew-kde.git). That same tap is still alive today and has been extended to include KF6 formulas alongside the old KF5 ones (mirror: https://github.com/KDE/homebrew-kde).
- That tap is currently **in the process of migrating most frameworks into `homebrew/core`**, which could explain some of the build conflicts — formulas in the tap may clash with versions already provided by `homebrew/core`.
- The old wiki tap command uses `--force-auto-update`, which **no longer exists** — it was removed from Homebrew in March 2024 (4.2.13). The correct command today is just:
  brew tap kde-mac/kde https://invent.kde.org/packaging/homebrew-kde.git
- The wiki also references a `do-caveats.sh` helper script (`"$(brew --repo kde-mac/kde)/tools/do-caveats.sh"`), which didn't work for me either — worth checking whether it still exists at that path once the tap is tapped correctly (without the obsolete flag).
### Relevant note
Historically (KF5 era), QET only ever needed two modules from that tap: `kf5-kcoreaddons` and `kf5-kwidgetsaddons`. The KF6 equivalents are presumably `kf6-kcoreaddons` and `kf6-kwidgetsaddons` — worth targeting only those instead of trying to build the whole tap.
Happy to share more details if useful, but wanted to get this pointer written down while it's fresh.
