FYI, I increase QET 's version 0.100.1 to 0.200.1.
On Debian like update your apt pinning...
https://qelectrotech.org/wiki_new/doc/i … an_pinning
QElectroTech → News → Nouveautés de la version de développement 0.9> 0.200.1
Sous linuxmint, ça m'installe la 0.9 quand je modifies le pinning:
Package: qelectrotech*
Pin: version 0.200.*
Pin-Priority: 1001
Elles est basée sur quoi ta linuxmint, Ubuntu 24.04?
Donc oui vu qu'il n'y a pas de paquet Qt6 envoyé vers Noble et Jammy sur le PPA, que les anciens en 0.100.1...
The stable/unstable Debian packages for QET have been migrated to Qt6 today; for the Ubuntu PPA, I’ve dropeed Jammy 22.04 (Qt 62.4) and Noble 24.02 (Qt 6.4.2)...keep Resolute 26.04 (Qt6.10.12)
Comparing Qt 6.4 (released late 2022) to Qt 6.10 (released late 2025) reveals roughly three years of continuous evolution within the Qt Framework. Qt 6.10 delivers substantial performance optimizations, advanced vector and Lottie graphics rendering, updated mobile/embedded platform support, and QML workflow enhancements that build significantly upon the foundation established in Qt 6.4.
Performance and Rendering
Curve Renderer & Graphics: Qt 6.10 introduces a new curve renderer leading to sharper vector graphics and up to 25% performance gains on complex scenes compared to older minor versions like 6.4.
Pointerlab
3D and 2D Graphs: Qt Graphs expanded significantly for 2D capabilities (multi-axes, hover support), and Qt Quick 3D added advanced features like height-field geometries from images and cubemap skyboxes.
Lottie Animations: Qt 6.10 brings native lottietoqml tools and a VectorImage Lottie backend for direct loading and CSS keyframe animation support for SVGs.
Platform Updates
Operating Systems: Qt 6.4 targets older OS baselines, whereas Qt 6.10 extends support up to modern ecosystems including updated Android (up to Android 16), iOS, and macOS versions alongside native WebView2 support on Windows
Source Ai
@galexis: si ça pose un soucis je peux ré activer l'upload to le PPA de Ubuntu 24.04... avec Qt 6.4.2...
Edit: ré activé sur le PPA, te faudra attendre les prochains builds. Apres tu aurras une meilleure experience sur des packages compilés avec des versions >= à Qt 6.10, sur Windows c'est Qt 6.11 comme sur mon repo Flatpak.
En attendant tu as une AppImage X86_64 https://github.com/qelectrotech/qelectr … 9266074692
https://github.com/qelectrotech/qelectr … 4/workflow
https://github.com/qelectrotech/qelectr … 5307607302
Même s'il fonctionne très bien depuis des années le port Qt 5 est "end of life" depuis un moment, donc les builds Qt5 vont bientôt être supprimées.
The V200 hasn't shown up in the .deb version for me yet. It's there in the Flatpak version.
But what I noticed right away was:
The language setting for German isn't displayed there.
It's in French.
I've already switched it back to German and restarted Qelectrotech-Flatpak.
What your OS, Debian ?
Have you changed pinning?
cat /etc/apt/preferences.d/40qelectrotech-devel
Pin: version 0.200.1.*
Pin-Priority: 1001
It's in French.
Good find, elements dir, langs, etc, was missing, thanks for report it, Thomas.
I will see it tomorow.
Have you changed pinning?cat /etc/apt/preferences.d/40qelectrotech-devel Package: qelectrotech* Pin: version 0.200.1.* Pin-Priority: 1001
I'm still on an Ubuntu derivative.
No, I haven't explicitly changed anything.
I thought it would come through the regular update.
I'm not that familiar with Linux yet.
Don’t rush it – there’s a major problem: the QET binary in Qt6 can’t find the ‘common’ collection, or its ‘langs’ translations and ‘titleblocks’.
It used to work for Windows packages; does it still work, or is there a problem with certain packages?
I’ve been drawing with qelectrotech-0.200.1-qt6+git9269-x86-win64-readytouse for the past few days and just tested the actual qelectrotech-0.200.1-qt6+git9348-x86-win64-readytouse, everything is fine.
No issues with the collection, translation or thetitleblocks.
Thanks you Achim, also the problem is related to Debian and Flatpak packages?
https://github.com/qelectrotech/qelectr … 5311849130
Fixed for Debian, PPA, and Flatpak packages, no problem on Windows, this issue it's only related to Linux and macOS packages on cmake/paths_compilation_installation.cmake.
https://github.com/qelectrotech/qelectr … de939f3efe
Enjoy! ![]()
2026-08-17 19:43:30.838 Info: Start-up
2026-08-17 19:43:30.839 Info: debugging enabled: false
2026-08-17 19:43:30.839 Info: Qt library version: QVersionNumber(6.10.2)
2026-08-17 19:43:30.839 Info: Qt library path default prefix: "/usr"
2026-08-17 19:43:30.839 Info: Qt library path documentation: "/usr/share/qt6/doc"
2026-08-17 19:43:30.839 Info: Qt library path headers: "/usr/include/x86_64-linux-gnu/qt6"
2026-08-17 19:43:30.839 Info: Qt library path libraries: "/usr/lib/x86_64-linux-gnu"
2026-08-17 19:43:30.839 Info: Qt library path executables: "/usr/lib/qt6/libexec"
2026-08-17 19:43:30.839 Info: Qt library path Qt binaries: "/usr/lib/qt6/bin"
2026-08-17 19:43:30.839 Info: Qt library path Qt plugins: "/usr/lib/x86_64-linux-gnu/qt6/plugins"
2026-08-17 19:43:30.839 Info: Qt library path installed QML extensions: "/usr/lib/x86_64-linux-gnu/qt6/qml"
2026-08-17 19:43:30.839 Info: Qt library path dependent Qt data: "/usr/lib/x86_64-linux-gnu/qt6"
2026-08-17 19:43:30.839 Info: Qt library path independent Qt data: "/usr/share/qt6"
2026-08-17 19:43:30.839 Info: Qt library path translation: "/usr/share/qt6/translations"
2026-08-17 19:43:30.839 Info: Qt library path examples: "/usr/lib/x86_64-linux-gnu/qt6/examples"
2026-08-17 19:43:30.839 Info: Qt library path Qt testcases: "/usr/tests"
2026-08-17 19:43:30.839 Info: Qt library path Qt settings: "/etc/xdg"
2026-08-17 19:43:30.839 Info: "QElectroTech V 0.200.1-dev"
2026-08-17 19:43:30.839 Info: "Compilation : GCC 16.2.0"
2026-08-17 19:43:30.839 Info: "Built with Qt 6.10.2 - x86_64 - Date : Aug 17 2026 : 17:03:53"
2026-08-17 19:43:30.839 Info: "Run with Qt 6.10.2 using 48 thread(s)"
2026-08-17 19:43:30.839 Info: "CPU : model name\t: AMD Ryzen Threadripper 3960X 24-Core Processor\n"
2026-08-17 19:43:30.839 Info: "RAM Total : 64 GB"
2026-08-17 19:43:30.839 Info: "RAM Available : 58 GB"
2026-08-17 19:43:30.839 Info: "GPU : Advanced Micro Devices, Inc. [AMD/ATI] Navi 22 [Radeon RX 6700/6700 XT/6750 XT / 6800M/6850M XT] (rev df)\n"
2026-08-17 19:43:30.839 Info: "GPU RAM : Video memory: 10240MB\n Dedicated video memory: 10240 MB\n Currently available dedicated video memory: 8765 MB\n"
2026-08-17 19:43:30.839 Info: "OS : linux - x86_64 - Version : Debian GNU/Linux forky/sid - Kernel : 7.1.8+deb14-amd64"
2026-08-17 19:43:30.839 Info: OS System language: "fr_FR"
2026-08-17 19:43:30.839 Info: OS System Native Country Name: "France"
2026-08-17 19:43:30.839 Info: OS System Native Language Name: "français"
2026-08-17 19:43:30.839 Info: System language defined in QET configuration: "fr"
2026-08-17 19:43:30.839 Info: language Path: "/usr/share/qelectrotech/lang/"
2026-08-17 19:43:30.839 Info: Common Elements Dir: "/usr/share/qelectrotech/elements/"
2026-08-17 19:43:30.839 Info: Common TitleBlock Templates Dir: "/usr/share/qelectrotech/titleblocks/"
2026-08-17 19:43:30.839 Info: Custom Elements Dir: "/home/laurent/.local/share/QElectroTech/QElectroTech/elements/"
2026-08-17 19:43:30.839 Info: Custom TitleBlock Templates Dir: "/home/laurent/.local/share/QElectroTech/QElectroTech/titleblocks/"
2026-08-17 19:43:30.839 Info: Company Elements Dir: "/home/laurent/.local/share/QElectroTech/QElectroTech/elements-company/"
2026-08-17 19:43:30.839 Info: Company TitleBlock Templates Dir: "/home/laurent/.local/share/QElectroTech/QElectroTech/titleblocks-company/"
2026-08-17 19:43:30.839 Info: For QET configuration-files:
2026-08-17 19:43:30.839 Info: App Config Location: "/home/laurent/.config/QElectroTech/QElectroTech"
2026-08-17 19:43:30.839 Info: For data-files (user-/company-collections, titleblocks, etc.):
2026-08-17 19:43:30.839 Info: App Data Location: "/home/laurent/.local/share/QElectroTech/QElectroTech"
2026-08-17 19:43:30.839 Info: Directory for project stalefiles:
2026-08-17 19:43:30.839 Info: Generic Data Location: "/home/laurent/.local/share/stalefiles/QElectroTech/"
2026-08-17 19:43:30.839 Info: Count the elements in your collections (Official-common-collection, company-collections, custom-collections):
2026-08-17 19:43:30.865 Info: Common Elements count: 8755 Elements
2026-08-17 19:43:30.873 Info: Custom Elements count: 1631 Elements
2026-08-17 19:43:30.874 Info: Company Elements count: 214 Elements
2026-08-17 19:43:30.874 Info: *** Qt screens ***
2026-08-17 19:43:30.874 Info: "( 1 : 1920 x 1080 )"
2026-08-17 19:43:30.874 Info: "( 2 : 3840 x 2160 )"
2026-08-17 19:43:30.874 Info: DISK : /run
2026-08-17 19:43:30.874 Info: FileSystemType: "tmpfs"
2026-08-17 19:43:30.874 Info: SizeTotal: 6 GB
2026-08-17 19:43:30.874 Info: AvailableSize: 6 GB
2026-08-17 19:43:30.874 Info: FileSystemType: "ext4"
2026-08-17 19:43:30.874 Info: SizeTotal: 79 GB
2026-08-17 19:43:30.874 Info: AvailableSize: 9 GB
2026-08-17 19:43:30.874 Info: DISK : /tmp
2026-08-17 19:43:30.874 Info: SizeTotal: 33 GB
2026-08-17 19:43:30.874 Info: AvailableSize: 33 GB
2026-08-17 19:43:30.874 Debug: isReadOnly: true (./sources/machine_info.cpp:236, void MachineInfo::send_info_to_debug())
2026-08-17 19:43:30.874 Info: DISK : /run/credentials/systemd-journald.service
2026-08-17 19:43:30.874 Info: SizeTotal: 0 GB
2026-08-17 19:43:30.874 Info: AvailableSize: 0 GB
2026-08-17 19:43:30.874 Info: DISK : /home
2026-08-17 19:43:30.874 Info: SizeTotal: 902 GB
2026-08-17 19:43:30.874 Info: AvailableSize: 385 GB
2026-08-17 19:43:30.874 Info: DISK : /media/backup2
2026-08-17 19:43:30.874 Info: SizeTotal: 983 GB
2026-08-17 19:43:30.874 Info: AvailableSize: 113 GB
2026-08-17 19:43:30.874 Info: DISK : /media/backup3
2026-08-17 19:43:30.875 Info: FileSystemType: "ext4"
2026-08-17 19:43:30.875 Info: SizeTotal: 491 GB
2026-08-17 19:43:30.875 Info: AvailableSize: 106 GB
2026-08-17 19:43:30.875 Info: DISK : /boot/efi
2026-08-17 19:43:30.875 Info: FileSystemType: "vfat"
2026-08-17 19:43:30.875 Info: SizeTotal: 0 GB
2026-08-17 19:43:30.875 Info: AvailableSize: 0 GB
2026-08-17 19:43:30.875 Info: DISK : /media/backup6
2026-08-17 19:43:30.875 Info: SizeTotal: 1967 GB
2026-08-17 19:43:30.875 Info: AvailableSize: 1043 GB
2026-08-17 19:43:30.875 Debug: isReadOnly: true (./sources/machine_info.cpp:236, void MachineInfo::send_info_to_debug())
2026-08-17 19:43:30.875 Info: DISK : /run/credentials/libvirtd.service
2026-08-17 19:43:30.875 Info: FileSystemType: "tmpfs"
2026-08-17 19:43:30.875 Info: DISK : /run/user/1000
2026-08-17 19:43:30.875 Info: SizeTotal: 6 GB
2026-08-17 19:43:30.875 Info: AvailableSize: 6 GB
2026-08-17 19:43:30.875 Info: DISK USED: /
2026-08-17 19:43:30.875 Info: SizeTotal: 79 GB
2026-08-17 19:43:30.875 Info: AvailableSize: 9 GB
2026-08-17 19:43:30.875 Info: Count All Elements in collections = 10600 Elements
2026-08-17 19:43:31.135 Info: Elements collection reload
2026-08-17 19:43:31.284 Debug: === MAKRO PFAD CHECK === "/home/laurent/.local/share/QElectroTech/QElectroTech/macros/" (./sources/ElementsCollection/elementscollectionmodel.cpp:333, void ElementsCollectionModel::addMacrosCollection(bool))
2026-08-17 19:43:31.306 Warning: EventLoopWatchdog: main thread stalled for 217 ms (expected a tick every 50 ms) (./sources/logging/eventloopwatchdog.cpp:54, void EventLoopWatchdog::tick())
2026-08-17 19:43:31.459 Info: Elements collection finished to be loaded in 0.324 seconds
2026-08-17 19:43:31.658 Warning: EventLoopWatchdog: main thread stalled for 250 ms (expected a tick every 50 ms) (./sources/logging/eventloopwatchdog.cpp:54, void EventLoopWatchdog::tick())
yeah the Flatpak got the Translation. Thank you Laurent.
I've already noticed 5 errors.
1. Full slave elements are no longer filtered out of the selection properties.
2. Connection transfer no longer works between PLC master and PLC slave.
3. When I copy and paste a terminal, the existing wires are connected to the new terminal.
4. The text editor no longer works correctly for free text.
5. The configured layout of the windows for numbering, component collection, etc., is not saved and is missing the next time the program is opened.
Translated with DeepL.com (free version)
5. The configured layout of the windows for numbering, component collection, etc., is not saved and is missing the next time the program is opened.Translated with DeepL.com (free version)
This has nothing to do with Flapak’s packaging, but concerns the code. Have you encountered the same problem in your development version?
You use cmake and Qt6 + KF6 in your development version?
Thanks for report these issues.
I just noticed this in the QT6 version. I don't see this behavior in the QT5 version.
My local fork is still on QT5. I'll wait until my pull requests are merged or closed before patching it to that version so I can continue working on it. So I tested it with the Flatpak version.
Interesting. Please update your development version to Qt6 to track these issues.
If you have free time compare Flatpak with arummler AppImage X86_64 CI/CD.
https://github.com/qelectrotech/qelectr … 9298216379
https://github.com/qelectrotech/qelectr … r/pull/722
Yeah, I'll see if I can figure out how to fix the issues on my own.
Like I said, I won't update until the pull requests are done. I don't know enough about this to switch between QT versions.
Just install debhelper (>= 11),
cmake,
ninja-build,
qt6-base-dev,
qt6-svg-dev,
qt6-l10n-tools,
qt6-tools-dev,
libkf6widgetsaddons-dev,
libkf6coreaddons-dev,
libsqlite3-dev,
libqt6sql6-sqlite,
qt6-base-private-dev,
pkgconf,
libpugixml-dev
and use cmake
mkdir build && cd build
cmake .. -G Ninja -DQT_VERSION_MAJOR=6 -DBUILD_WITH_KF=ON -DBUILD_KF=OFF -DPACKAGE_TESTS=OFF
time ninja -j48
Yesterday, as part of a major retrofit of an old installation machinery, I was able to test PDF files exported from QET (Qt6 MSI installer) with page references, XREFs links on a very, very old PC running Windows 98 SE to April 5000/Orphée, equipped with Acrobat Reader 5.0. The software opened them without any problems and the page references and XREFs links worked perfectly – brilliant! This will make troubleshooting much easier, with the PLC programme in one window and the drawings in another. just need to change old vintage 14" crt monitor to an new lcd monitor..19"..
And I no longer need to carry my QET laptop around with me everywhere, even though the Ctrl + F shortcut is more convenient than the PDF search function for carrying out in-depth searches within a large QET's project.
Generated in 0.037 seconds (17% PHP - 83% DB) with 11 queries
