https://github.com/qelectrotech/qelectr … r/pull/483
ispyisail wrote:
Headless command-line export
Adds a headless (no-GUI) command-line export so projects can be rendered and
exported in batch / CI pipelines without opening the editor. This is a
long-standing request (qelectrotech.org bugtracker #171, GitHub #309; the
list export addresses @pkess's request in #162 to "export all connections as
a list").
Usage
qelectrotech --export-pdf    <project.qet> <output.pdf>
qelectrotech --export-png    <project.qet> <output_dir>
qelectrotech --export-svg    <project.qet> <output_dir>
qelectrotech --export-cables <project.qet> <output.csv>
qelectrotech --export-wires  <project.qet> <output.csv>
pdf — one multi-page document, one diagram per page.
png / svg — one file per diagram, named <NN>_<title>.<ext>.
cables — wiring list (one row per conductor) as CSV.
wires — list of distinct wire numbers as CSV.
How it works
The export request is detected in main() before SingleApplication
is created, so a batch run does not attach to / focus a running GUI
instance. A plain QApplication is used (offscreen-capable).
Rendering reuses Diagram::render() over
BorderTitleBlock::borderAndTitleBlockRect() — the same path the GUI export
uses — so output matches the on-screen drawing.
The image/PDF code lives in a new CLIExport namespace
(sources/cli_export.{h,cpp}); main.cpp only gains a small dispatch hook.
List exports
The CSV list exports reuse the existing exporters rather than duplicating
logic:
--export-cables → WiringListExport. To make it usable headlessly,
WiringListExport::toCsv() (which mixed CSV generation with a file dialog
and file write) is refactored: a new const method toCsvString() builds and
returns the CSV, and toCsv() now calls it before doing the dialog + write.
No behavioural change to the existing GUI export.
--export-wires → ConductorNumExport::wiresNum() (already a pure string
producer).
Testing
PDF/PNG/SVG verified against native example projects (e.g.
Habitat-Schemas_developpes.qet) — output opens and matches the GUI render.
--export-cables / --export-wires verified end-to-end: both exit 0 and
produce the same CSV the GUI exporters produce.
https://github.com/qelectrotech/qelectr … r/pull/485
ispyisail wrote:
CLI export: don't draw the editor grid in PDF/PNG/SVG output
#485
https://github.com/qelectrotech/qelectr … r/pull/488
kellermorph wrote:
Fix “Exclude from auto-numbering” and “Potential isolation” tick boxes fault #482
Closed
Potential Isolation option for terminals #471
https://github.com/qelectrotech/qelectr … r/pull/489
ispyisail wrote:
CLI: add verification & data-export tools (info, BOM, nets, links, check-elements, resave)
#489
Follow-up to #483, extending the headless CLI with six read-only tools. The structured outputs (JSON/CSV) are aimed at automation and AI-driven pipelines — the CLI is effectively QET's programmatic surface — plus an element-library validator.
| flag | output | purpose |
| `--info` | JSON | structural project summary: per-folio element/conductor counts, page size, free (unconnected) terminals, project totals |
| `--export-bom` | CSV | bill of materials, one row per element (from `element_nomenclature_view`, same source as the GUI BOM) |
| `--export-nets` | JSON | electrical nets (connected-terminal potentials) — connectivity ground truth, via `Conductor::relatedPotentialConductors()` |
| `--export-links` | CSV | element cross-references (master/slave/report), flagging unresolved links |
| `--check-elements` | stdout | validate one `.elmt` or a directory against the element schema (XML, root definition, bounding box, terminals); OK/WARN/FAIL, non-zero exit on failure |
| `--resave` | .qet | load and rewrite the project XML (round-trip integrity check) |
All read-only and **additive** — no change to the existing pdf/png/svg/cables/wires options. `run()` is adjusted to handle the differing argument arity (`--info` takes an optional output; `--check-elements` takes a path, not a project).
Built and verified on Qt5 + KF5 (Ubuntu). `--check-elements` validated against the full bundled element collection (0 false failures, agreeing with QET's own loader).
https://github.com/qelectrotech/qelectr … r/pull/490
CLI: clickable cross-reference hyperlinks in PDF export
#490
Brings the GUI's clickable PDF cross-reference / folio navigation (cd76b6a) to the headless `--export-pdf` path, via a shared helper — as discussed on #483.
Two commits, bisectable per your suggested order:
**1. Extract `pdf_links.{cpp,h}` shared helper.** Moves the link-injection logic and `convertUriToGoTo()` post-processor out of `ProjectPrintWindow` into a standalone translation unit. The scene→page mapping is passed in as a `PageGeometry` (transform + `devToPdf` + source-rect lookup) so each caller supplies its own correct geometry — the helper never assumes a `QPrinter`. `ProjectPrintWindow` stays a pure caller: it builds its `PageGeometry` from the printer page layout exactly as before. No behavioural change to GUI print; no class-structure changes.
**2. Wire into CLI `exportPdf()`.** Builds the geometry from the `QPdfWriter` (96 dpi, zero margins, page sized to the diagram → scale ~1, no centering) — rebuilt from scratch, not reused from the printer path — and calls the helper per page, then post-processes after the painter closes.
**Verified** on `examples/industrial.qet` (50 pages): the exported PDF contains 304 `/GoTo` + `/FitR` internal link annotations (0 leftover `/URI`), well-formed. Builds clean on Qt5 + KF5 (Ubuntu).
Independent of the CLI tools in #489.
*Developed with assistance from Claude (Anthropic).*
