Topic: Elements not used but in the BOM
Hello Community
I have copied an existing file for another project. When I export the BOM to a sqlite database I still
in the database which are not used. They are not in the visible project but still in th database.
Purging or clenaing up the project doen`t help. They are still in.
The strange thing is that the same query in the software doesn`t show these elements.
What is the reason for this and how can I get rid of the unused also in the sqlite DB?
Thank you.
Chris
Re: Elements not used but in the BOM
Hello Chris,
what the QET version, OS?
Please share an little example.
Did you notice anything unusual when you looked at the project's XML?
BR Laurent
c.lehner wrote:
Hello Community
topgames
Thank you.
Chris
Hi Chris, it sounds like the SQLite export is still keeping references from the original copied project, even though those items are no longer visible in the current design. In many tools, deleted or unused components can remain in the internal database until a full rebuild or “compact/repair” process is done. You could try creating a completely new project and importing only the active schematic/PCB files, then export the BOM again. That usually removes hidden legacy entries. Also check if there’s an option to refresh or regenerate the project database before exporting.
