Topic: Installation
Hallo
Ich kann das Programm nicht installieren. Egal welche Datei ich benutze, Windows meldet mir immer wieder, dass die Datei nicht vertrauenswürdig ist und ich sie deshalb nicht herunterladen kann. Was kann ich tun?
Hello
I can't install the program. No matter which file I use, Windows keeps telling me that the file isn't trustworthy and that I can't download it. What can I do?
Best regards and a kiss ... Hieronymus
Re: Installation
Could you provide some more details, such as your Windows version and antivirus software, and attach a few screenshots?
Re: Installation
https://stackoverflow.com/questions/489 … ed-app-fro
Option 2: Buy an "Extended Validation" (EV) code signing certificate
A guaranteed way to immediately and permanently get rid of the Microsoft SmartScreen warnings is to buy an "Extended Validation" (EV) code signing certificate from one of the Microsoft-approved certificate authorities (CA's), and to sign your app with that EV certificate.
Such an EV certificate will typically cost you somewhere between 300 and 700 USD per year (you better compare prices), and will only be issued to registered businesses. If you're a single developer, you must be a sole proprietor and have an active business license. You can read more about the formal requirements for EV code signing certificates in the EV Code Signing Certificate Guidelines.
Even €200 a year is out of the question – we don’t have enough donations to cover that certificate. I’m already paying for the Apple Developer Account out of my own pocket – €99 a year just to signed and notarized Apple Silicon bundles aarch64 – and on top of that, there’s the hosting fee of €160/year and the domain registrar fee...
https://github.com/qelectrotech/qelectr … issues/445
Please search on www "bypass SmartScreen warning in Windows."
Re: Installation
Virustotal show file is safe: 1/53 security vendor flagged this file as malicious
https://www.virustotal.com/gui/file/973 … ?nocache=1
Re: Installation
https://signpath.org/ is asking us to set up a CI/CD pipeline...
It’s already very complicated to compile QET for Windows; setting up a CI/CD pipeline on our GitHub is even more complicated.
For years (15 years) I have been providing QET packages for Windows; they are cross-compiled on my Debian machine using MXE and based on the old scripts from the Digikam developer. See: https://qelectrotech.org/forum/viewtopi … 976#p13976
Cross-compilation is an advantage for me as everything is scripted, but it  involves compromises: static builds, EXE files containing the DLLs, and deployment with winqtdeploy not working in cross-compilation!
https://github.com/qelectrotech/qelectr … Windows.sh
Furthermore, the NSIS installer scripts are still based on the old 2.X version; I don’t have the time and nor healthor, the skills to rewrite them to make them compatible with NSIS 3.X. EDIT: DONE!
We are therefore looking for people with expertise in Windows CI/CD (AppVeyor, GitHub), as well as people capable of reviewing the Windows installer.
Re: Installation
I used the Claude AI tool as part of a Windows-based CI/CD pipeline using GitHub Actions. It wasn’t easy—neither for me nor for the AI—but we’ll soon have a CI/CD pipeline that can be signed by the SignPath Foundation.
Excellent! Well done for your perseverance — that was a massive undertaking!
To summarise everything we’ve achieved together:
Build
CMake + Ninja with -j$(nproc) for parallelisation
SQLite3 hints for FindSQLite3
QET_EXPORT_PROJECT_DB passed to the compiler
ccache with GitHub Actions cache
Packaging
Clean and maintainable patch_nsi.py in build-aux/windows/
Correct Windows absolute paths with backslashes in the .nsi
3-pass ldd scan for all transitive DLLs
libsqlite3, libharfbuzz, libbrotli, libpcre2, libicuXX... everything’s there
Compiled .qm files copied to lang/
Version in the format 0.100.1-r8821-abc1234_x86_64-win64 consistent with the official packaging
CI/CD
MSYS2_ARG_CONV_EXCL for NSIS arguments
git in MSYS2, fetch-depth: 0 for the revision
FORCE_JAVASCRIPT_ACTIONS_TO_NODE24 for actions
All the best with QElectroTech!
You’re welcome! It was a real technical challenge — between the quirks of MSYS2, Windows/POSIX paths, NSIS, CMake vs qmake, and hidden SQLite dependencies, there was plenty to get to grips with.
The result is clean and robust — a complete Windows CI/CD pipeline for a high-quality open-source project. All the best with QElectroTech, and feel free to get in touch if you have any other topics you’d like to explore
The installer isn't ready for production yet; it still needs some finishing polished. OK ->Done.
Re: Installation
https://qelectrotech.github.io/qelectro … ce-mirror/
https://github.com/qelectrotech/qelectr … ag/nightly
Enjoy! nomicons/wink
Re: Installation
Now we have:
✅ A robust Windows CI/CD pipeline using ccache, NSIS and 7-Zip for zipping Windows "Ready-to-use" portable versions
✅ A public GitHub Pages site with direct downloads
✅ An automatic nightly Windows build triggered by every push to the master branch
✅ The SignPath Foundation application ready to submit
Re: Installation
Now we have an Windows MSI installer.
It was a real struggle with WiX v7 — between the EULA, namespaces, !(bind.Variable.) vs $(var.), WixVariable refusing to be a child of WixUI, and the non-embedded cab1.cab. But the result is clean and robust.
To summarise what we now have in the repository:
windows-build.yml — full MSYS2/UCRT64 build with NSIS, ccache, portable artefacts + installer, triggered manually
windows-msi.yml — generates a standalone MSI with WiX v7, embedded GPL-2 licence, QET.bat launcher adapted for Program Files
test-vs2026.yml — validates compatibility with the VS 2026 image prior to the 8 June migration
QElectroTech.wxs — complete WiX v7 definition with automatic harvesting, shortcuts, .qet file association
https://github.com/qelectrotech/qelectr … -win64.msi
Re: Installation
Every Monday at 2 am (UTC) (cron) or manually
  windows-build.yml
  ├── build-windows  →  generates an exe file(installer) + zip(ReadyToUse) + portable artefact for MSI builder
  └── deploy-pages   →  clears old files, uploads the exe file + zip to the ‘release nightly’ repository
        ↓ (workflow_run: completed + successful)
  windows-msi.yml
  ├── uploads the portable artefact
  ├── builds the MSI with WiX v7
  ├── deletes the old .msi, uploads the MSI to the nightly version
  └── generates and deploys GitHub Pages  ← the 3 URLs are known here
The GitHub Pages page is no longer generated by windows-build.yml but by windows-msi.yml once the MSI is in the release
Re: Installation
MSI installer
https://www.virustotal.com/gui/file/d53 … ?nocache=1
No security vendors flagged this file as malicious
Installer.exe
https://www.virustotal.com/gui/file/fde … ?nocache=1
1/60 security vendor flagged this file as malicious
ReadyTouse
https://www.virustotal.com/gui/file/8df … ?nocache=1
1/52 security vendor flagged this file as malicious
