Topic: generateSvg: Corrected view
I downloaded, compiled and run qelectrotech-0.100 under Linux Mint 21.3.
As the svg export is concerned I noticed a bug, that I was able to fix.
Problem
With "export elements only" the contents of svg export is not correctly centered within the exported area, which causes some contents to be clipped.
Fix
sources/exportdialog.cpp: 421
Replace
   svg_engine.setSize(QSize((width*9/16), (height*9/16)));
by
   svg_engine.setSize(QSize(width, height));
   svg_engine.setViewBox(QRect(0, 0, width*0.75, height*0.75));
This corrected the problem.
Regards
Tom
Re: generateSvg: Corrected view
Added, thanks you Tom.
