as master slave works with this contactmirror on the bottom, however working fine, i have used the renvoi elements.
i will make rar file and put it here as a renvoielements.
i am working on a good lib with master/slave usage.
i did just all of them and put them in separate map, 1 for next page (master) and one for previous page (slave)
the visual is almost same as master/slave, however you have to do it manually.
and no not good idea to have a switch on it, however you can use same as above with this master slave as the working is exact same. i did thought of that, however found many elements have wrong terminal behavior so have to redraw many of them. (editor is not keeping up this master/slave and renvoi as it is still in development. editor is running 0.3 and we are in 0.4
paul deelen
shooter@home.nl
