Topic: properties editor
when i make a name and a value the last value is blanked when pressing oke
it happens in project properties:
probably due to sorting process
the last was zz with text last but last is blanked the next time i ask for it.
paul deelen
shooter@home.nl
Re: properties editor
I did not understand, could you explain better.
go to project properties
put in a name in the properties field and a value
put one more name in and a value
now a input field will be added to the display.
when pressing oke
the second value disappears.
paul deelen
shooter@home.nl
I didn't confirm, and i use doubleclick for enter value.
Tried in my Debian and VM seven see attached capture.
https://download.qelectrotech.org/qet/forum_img/project_settings.png
oke now press oke and go again to the project properties now last input is gone
paul deelen
shooter@home.nl
