Re: Biblioteca WEG
After using many find + sed commands and finish with kate editor I can change the font to Liberation Sans in Catanlan translation element directory but the diff to push to master was 2 X the entire size off collection like 145 Mio only the patch????!!!!!
[17:04:44] laurent@debian:~$ history | grep find
8596  find . -name "*.elmt" -exec sh -c sed -i'/font=/{n;s/Sans Serif,9,-1,5,50,0,0,0,0,0/Liberation Sans,9,-1,5,50,0,0,0,0,0,Regular/}'
8597  find . -name "*.elmt" -exec sh  sed -i'/font=/{n;s/Sans Serif,9,-1,5,50,0,0,0,0,0/Liberation Sans,9,-1,5,50,0,0,0,0,0,Regular/}'
8670  find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,10,-1,5,50,0,0,0,0,0/Liberation Sans,10,-1,5,50,0,0,0,0,0,Regular/g' {} \;
8671  find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,8,-1,5,50,0,0,0,0,0/Liberation Sans,8,-1,5,50,0,0,0,0,0,Regular/g' {} \;
8672  find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,7,-1,5,50,0,0,0,0,0/Liberation Sans,7,-1,5,50,0,0,0,0,0,Regular/g' {} \;
8673  find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,6,-1,5,50,0,0,0,0,0/Liberation Sans,6,-1,5,50,0,0,0,0,0,Regular/g' {} \;
8674  find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,5,-1,5,50,0,0,0,0,0/Liberation Sans,5,-1,5,50,0,0,0,0,0,Regular/g' {} \;
8734  find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,5,-1,5,50,0,0,0,0,0,normal/Liberation Sans,5,-1,5,50,0,0,0,0,0,Regular/g' {} \;
https://download.qelectrotech.org/qet/s … onts.patch
What interests us is just extracting the Catalan translation strings from the diff.
See Xavier script's perl here: https://download.qelectrotech.org/qet/scripts/
BTW, we used these this perl scripts 15 years ago, now my memory fails me.
Note regarding the translation of elements: do not use the QET editor, but manually edit the elmt file using a text editor and add your country tag to the XLM file. Use spaces rather than tabs for alignment.
If you are using the QET Qt 5 editor, XML attributes will be saved randomly by default. This is a requirement requested by some to Qt 's team to avoid hacks, but in our case, the diff file is very large and incomprehensible...
Example:
<definition hotspot_x="35" hotspot_y="25" version="0.100.0" type="element" height="50" width="70" link_type="simple">
    <uuid uuid="{2b9f2e91-da08-497d-b065-bd2d68d716d9}"/>
    <names>
        <name lang="ca">Filtre</name>
        <name lang="fr">Filtre</name>
        <name lang="en">Filter</name>
        <name lang="es">Filtro</name>
        <name lang="nl">Filter</name>
        <name lang="it">Filtro</name>
        <name lang="ar">مُرشّح</name>
        <name lang="pl">Filtr</name>
        <name lang="cs">Filtr</name>
        <name lang="el">Φίλτρο</name>
    </names>
    <elementInformations/>
Re: Biblioteca WEG
Salut Laurent,
when we want the fonts to be replaced correctly, we need to include the quote-signs into replacement!
For example:
From the original Oldtimer-Elements in the other thread, we find these font-descriptions:
Noto Sans ExtraBold,10,-1,0,81,0,0,0,0,0,Regular
Noto Sans ExtraBold,5,-1,0,81,0,0,0,0,0,Regular
Noto Sans ExtraBold,6,-1,0,81,0,0,0,0,0,Regular
Noto Sans ExtraBold,7,-1,0,81,0,0,0,0,0,Regular
Noto Sans ExtraBold,9,-1,0,81,0,0,0,0,0,Regular
Sans Serif,10,-1,0,50,0,0,0,0,0
Sans Serif,12,-1,0,50,0,0,0,0,0
Sans Serif,12,-1,5,50,0,0,0,0,0
Sans Serif,15,-1,5,50,0,0,0,0,0
Sans Serif,30,-1,5,50,0,0,0,0,0
Sans Serif,3,-1,5,50,0,0,0,0,0
Sans Serif,4,-1,0,50,0,0,0,0,0
Sans Serif,4,-1,5,0,0,0,0,0,0,normal
Sans Serif,4,-1,5,25,0,0,0,0,0
Sans Serif,4,-1,5,50,0,0,0,0,0
Sans Serif,5,-1,5,25,0,0,0,0,0
Sans Serif,6,-1,0,50,0,0,0,0,0
Sans Serif,6,-1,5,0,0,0,0,0,0,normal
Sans Serif,6,-1,5,25,0,0,0,0,0
Sans Serif,6,-1,5,50,0,0,0,0,0,Regular
Sans Serif,7,-1,0,50,0,0,0,0,0
Sans Serif,7,-1,5,25,0,0,0,0,0
Sans Serif,8,-1,5,0,0,0,0,0,0,normal
Sans Serif,9,-1,0,50,0,0,0,0,0
Sans Serif,9,-1,5,0,0,0,0,0,0,normal
Sans Serif,9,-1,5,50,0,0,0,0,0,Regular
Just looking at the last two lines we see double ... but not quite:
One font-string ends with a number and the other font-string also includes ",Regular".
If we only replace this
by this
the last line would be changed to
Liberation Sans,9,-1,5,50,0,0,0,0,0,Regular,Regular
what would be wrong!
Inserting an additional element-name is another topic...
Re: Biblioteca WEG
@scorpio810:
Salut Laurent !
On the way to have a script to insert Catalan translation of names to existing elements, I updated elements with filenames containing blanks in their name by replacing blanks to underscores.
Stay tuned for upgraded elements with Catalan translations...  nomicons/wink
Gruß
  plc-user
Re: Biblioteca WEG
Hallo plc-user
I was added in 2013 this note for future...
cat patcher\ traduction.txt
./apply_translation_diff.sh ~/qet_directory/diff.tmp
./set_name.sh elements/capteurs/actionneurs/bvs_oi-3-001-e.elmt es 'BVS OI-3-001-E'
./translations_stat.sh force
elementsA = Antoni_catalan translated
diff -urPp elementsA/ elements/ > 02sources.patch
./apply_translation_diff.sh /home/laurent/qet_element_moderation/Nouveau_dossier4/02sources.diff &> output.txt
Gruß
Attachment icon apply_translation_diff.sh 360 b, 132 downloads since 2025-12-11
Attachment icon extract_translations_from_diff.sh 123 b, 98 downloads since 2025-12-11
Re: Biblioteca WEG
See also merge_it script.
Re: Biblioteca WEG
plc-user wrote:
Salut Laurent,
For example:
by this
Hallo plc-user
so maybe this command work
find . -name "*.elmt" -exec  sed -i -e 's/Sans Serif,/Liberation Sans,/g' {} \;
Re: Biblioteca WEG
Hallo plc-user!
I just saw your last commits, many thanks to push an very clean Catatan translation PR without noise off XML random attibutes and font family changes, very good job! \o/ nomicons/wink
If you could share your scripts for future translations we can't solving, I would be very grateful.
Yes, I know! It was very simple for end users to use the QET Element editor GUI to add new translations since they could edit .elmt files manually with a text editor.
Until further notice, we advise our translators to translate the ~ 8,500 elements in the official collection by opening each *.elmt file one by one in a good text editor and adding their translations of elements between the XML tags <names>  </names> in the following style:
<name lang="de">Energietechnik</name>
        <name lang="fr">Energie</name>
        <name lang="ar">طاقة</name>
        <name lang="en">Energy</name>
        <name lang="cs">Energie</name>
        <name lang="pl">Energia</name>
        <name lang="es">Energía</name>
        <name lang="it">Energia</name>
        <name lang="el">Ενέργεια</name>
        <name lang="nl">Energie</name>
        <name lang="ru">Сантехника</name>
        <name lang="da">Energi teknik</name>
I think it is easier for new contributors or translators to use QET's integrated editor to get a vector view of the symbol represented in order to better translate the element itself!
Translated with DeepL.com (free version)
Best regards,
Re: Biblioteca WEG
Salut Laurent !
Unfortunately, replacing fonts involves manual work, as especially commercial operating systems from Redmond append localized parts to font descriptions and don't even shy away from spaces!
Here are a few examples from before the introduction of the Liberation fonts:
Arial,4,-1,5,75,1,0,0,0,0,Gras Italique
Arial Narrow,11,-1,5,75,0,0,0,0,0,Negrito
Arial Narrow Hu,9,-1,5,50,0,0,0,0,0, Normal
Calibri,6,-1,5,75,0,0,0,0,0,Bold
DINosaur Medium,9,-1,5,57,0,0,0,0,0,Medium
MS Shell Dlg 2,10,-1,5,50,0,0,0,0,0,Normál
MS Shell Dlg 2,1,-1,5,50,0,0,0,0,0,obyčejné
MS Shell Dlg 2,4,-1,5,75,0,0,0,0,0,Grassetto
MS Shell Dlg 2,4,-1,5,75,0,0,0,0,0,tučné
MS Shell Dlg 2,8,-1,5,75,0,0,0,0,0,Félkövér
Sans Serif,4,-1,5,0,0,0,0,0,0,ncrmal
URW Gothic [urw],4,-1,5,63,0,0,0,0,0,Demi
As you can see, we definitely have to take the entire font string into account when replacing fonts.
I don't have a complete script for this, but the search/replace function in DoubleCommander helps to avoid having to deal with each file individually.
At least a “translation table” has to be created manually. I don't yet know what a script for processing the files should look like.
For the extraction of font-strings from element-files, I use this part of a bash-script:
for i in  `find . -name "*.elmt"` ; do
  cat "$i" | grep font=\" | awk -F "font=\"" '{ print $2 }' | \
             awk -F "\"" '{ print $1 }' >> /tmp/tempfile.txt
  done
cat /tmp/tempfile.txt | sort | uniq > /tmp/fontstrings.txt
With this list we need to check, which of the Liberation-fonts matches the original best and create a translation-table.
In my opinion, we should only include elements in the official collection that are limited to the four fonts supplied by QET!
Re: Biblioteca WEG
Salut Laurent !
Thank you for the compliment!   nomicons/smile
To create this "clean" diff I used a script to add the translation from the same directory-structure as the official collection!
It searches the given directory for element-files and inside the files for the new translation, takes this and writes that to the same file in the structure of official collection.
Afterwards a new function of QET_ElementScaler sorts the localized names.
Here's the script:
#!/bin/bash
# Dieses Skript sucht nach Zeilen, die ein bestimmtes Muster enthalten,
# extrahiert diese und fügt sie in der Zieldatei nach einer Zeile ein,
# die ein anderes Muster enthält.
# Konfiguration
SourceDir="Antoni/"
DestDir="QET/"
# Muster, das in der Quelldatei gesucht wird, um Zeilen zu extrahieren
SOURCE_PATTERN="<name lang=\"ca\">"
# Muster, das in der Zieldatei gesucht wird, um die Einfügeposition zu finden (Einfügen erfolgt NACH dieser Zeile)
DEST_PATTERN="<names>"
# und nun in einer Schleife alle Element-Dateien bearbeiten
for SOURCE_FILE in  `find ./$SourceDir -name "*.elmt"` ; do
  DEST_FILE=${SOURCE_FILE/"$SourceDir"/"$DestDir"}
  # zur Kontrolle die Dateinamen aufschreiben
  #echo "Source: $SOURCE_FILE --> Destination: $DEST_FILE"
  # wenn die Ziel-Datei ncht existiert --> weiter!
  if [ ! -e "$DEST_FILE" ]; then
    echo "Destination-File '$DEST_FILE' does not exist --> use next SourceFile"
    continue
  fi
  # Wenn in der Ziel-Datei schon eine Zeile mit dem Muster existiert, dann nicht (!) einfügen
  LineInDestFile=$(grep "$SOURCE_PATTERN" "$DEST_FILE")
  if [ -n "$LineInDestFile" ]; then
      echo "Line with '$SOURCE_PATTERN' already exists in '$DEST_FILE'!"
      continue
  fi
  # Zeile(n) aus der Quelldatei extrahieren, die dem Muster entsprechen
  LINES_TO_INSERT=$(grep "$SOURCE_PATTERN" "$SOURCE_FILE")
  # Überprüfen, ob überhaupt Zeilen gefunden wurden
  if [ -z "$LINES_TO_INSERT" ]; then
    echo "Could not find '$SOURCE_PATTERN' in '$SOURCE_FILE'!"
    continue
  fi
  # die extrahierten Zeilen in die Zieldatei einfügen
  # --> sed mit der Option 'a' (append/anhängen nach der passenden Zeile)
  #     die Variable LINES_TO_INSERT kann mehrere Zeilenumbrüche enthalten: Formatieren für sed
  #     Zeilenumbrüche (\n) ersetzen durch das sed-spezifische Escaping (Backslash + tatsächlicher Zeilenumbruch)
  FORMATTED_INSERT=$(echo "$LINES_TO_INSERT" | sed 's/$/\\/')
  FORMATTED_INSERT=${FORMATTED_INSERT%\\} # letzten, unnötigen Backslash entfernen
  # sed-Befehl: Finde das Muster in der Zieldatei (/DEST_PATTERN/), hänge die formatierten Zeilen an (a\)
  # sed -i bearbeitet die Datei direkt.
  sed -i "/$DEST_PATTERN/a\\
  $FORMATTED_INSERT"
"$DEST_FILE"
  echo "Lines with '$SOURCE_PATTERN' have been inserted after '$DEST_PATTERN' in '$DEST_FILE'."
  # zum Schluss räumen wir die frisch ergänzte Datei ein wenig auf
  # und sortieren die Übersetzungen nach Länder-Kürzel:
  /usr/local/bin/QET_ElementScaler --OverwriteOriginal --OnlyCleanMeta "$DEST_FILE"
  done
I guess this script can be used in the future, if somebody creates another new language.
Gruß
  plc-user
Re: Biblioteca WEG
Add english translation and save it to https://download.qelectrotech.org/qet/s … xml_tag.sh
Thanks you plc-user! nomicons/smile
Re: Biblioteca WEG
Olá a todos, sou brasileiro e queria agradecer a contribuição de todos principalmente dos usuários brasileiros, existe uma comunidade grande adotando o Qelectrotech.
Eu contribuo com traduções ao Qelectrotech quando tenho tempo livre. Sintam-se a vontade para contribuirem. Esses blocos da weg ficaram sencacionais.
Hello everyone, I'm Brazilian and I wanted to thank everyone for their contributions, especially the Brazilian users. There's a large community adopting Qelectrotech.
I contribute translations to Qelectrotech when I have free time. Feel free to contribute as well. These WEG blocks look fantastic.
