Re: Nouveautés de la version de développement 0.9
https://www.qt.io/blog/commercial-lts-q … 9-released
Wait one year...
https://www.qt.io/blog/extended-securit … s-may-2025
Houston, we have a problem!!!!!
Standard support for Qt 5.15 will end after 26th of May 2025, as communicated earlier. After the support period, the release will be in EoS (End of Support) state and will only be supported through additional services, including Extended Security Maintenance for Qt 5.15, Extended Support, and Professional Services. Customers distributing applications and embedded devices using Qt 5.15 software should evaluate how to access technical support and maintenance patches which may include security fixes. Standard commercials terms still apply after End of Support.
https://github.com/qelectrotech/qelectr … issues/402
Qt5 is now declared deprecated in Gentoo
Hi Laurent,
I have wanted to try and spend some time contributing to the main QET program, in addition to dxf2elmt (which I need to get back and do some work on).
Are there a specific set of Issues in the Mantis tracker related to getting things working in Qt 6 I could look at or start working on? I'm not real familiar with Mantis, but doing a quick search for Qt 6 I didn't find anything.
Would I just be better off attempting to compile it with Qt6, see what breaks and go from there?
Hi Carl,
this has only been reported here on the forum and on Github issues; there doesn't seem to be any entry in Mantis.
https://qelectrotech.org/forum/viewtopi … 089#p21089
Emil have writted a new documentation for compile it under Windows with Qt6.9 if some one can try?
https://github.com/EmilOsvoll/qelectrot … d_Guide.md
As indicated by plc-user, the master and qt6-cmake branches have diverged significantly. Merging the master branch into the qt6-cmake branch causes many conflicts that must be resolved manually. I tried, but I got confused... my knowledge of GIT is limited.
plc-user wrote:
- I don't know a schedule for the switch to QT6 and am very curious myself to see how the two GitHub branches will come together, given how many changes have been made to both branches in the meantime...
On Debian sid
sudo apt install qt6-tools-dev qt6-svg-dev pkg-config
git clone --recursive https://github.com/qelectrotech/qelectrotech-source-mirror.git
cd qelectrotech-source-mirror/
git switch qt6-cmake
comment line 137 of /sources/machine_info.cpp to compile.
mkdir build && cd build
cmake .. -G Ninja -DBUILD_WITH_QT6=ON
time ninja -j48
Ignored 95 untranslated source text(s)
[318/478] Building CXX object CMakeFiles/qelectrotech.dir/sources/editor/UndoCommand/openelmtcommand.cpp.o
/media/backup6/qelectrotech-source-mirror/sources/editor/UndoCommand/openelmtcommand.cpp: In member function ‘virtual void OpenElmtCommand::redo()’:
/media/backup6/qelectrotech-source-mirror/sources/editor/UndoCommand/openelmtcommand.cpp:66:102: note: ‘#pragma message: @TODO uncommante slot_select when fixed, see itemChange function for each primitive’
   66 | #pragma message("@TODO uncommante slot_select when fixed, see itemChange function for each primitive")
[478/478] Linking CXX executable qelectrotech
real    0m36,019s
user    21m37,065s
sys     1m39,485s
QElectroTech V 0.100.0-dev
Compilation : GCC 15.2.0
Built with Qt 6.9.2 - x86_64 - Date : Sep 28 2025 : 12:58:45
Git Revision : 411fb3c4dc54b6aaea00f034d6c5396de5daa474
Run with Qt 6.9.2 using 48 thread(s)
https://download.qelectrotech.org/qet/forum_img_2/Qt6_test_build.png
https://qelectrotech.org/forum/viewtopi … 127#p22127
Thanks this gives me a place to start looking.
I'll give it a go. While I'm not a fan of Windows, unfortunately my work laptop is running Windows 11. While I haven't done any in a while, I do have it set up for Qt development, so hopefully it won't be too much trouble to get it compiling.
I'm certainly not a git expert either, but I'll start by trying to get the existing qt6-cmake branch compiling, and then see what I can do from there.
Appreciate the help, hopefully I can get something useful going.
Salut Laurent !
Hello Vadoola!
Over the last few days, I've also been wondering what exactly is missing that prevents us from switching completely to qt6 (yet) and whether anyone has a clear view ...
Let's test it out and discuss it! However, we should change forums: it's not finished yet, so it's not ‘new’ yet. That's why the ‘Code’ section is probably the most appropriate place for this discussion.
Hi all,
Well, given the state of Qt5, I'm going to pause the terminal strip branch and focus on the transition to Qt6 and cmake. This would be an opportunity to release a new stable version (with some polish, and disabling the terminal strip manager for the release).
By the way, after several research, I downgraded the docutils packages in my Debian Sid, which new docutils packages version was breaking my Python Sphinx documentation needed to compile the Extra Cmake Modules. Like
File "/usr/lib/python3/dist-packages/sphinx/registry.py", line 544, in load_extension
        raise ExtensionError(
            __('Could not import extension %s') % extname, err
        ) from err
    sphinx.errors.ExtensionError: Could not import extension ecm (exception: No module named 'docutils.....
Thanks Freexian team to report it: https://www.freexian.com/blog/debian-co … s-10-2025/
Now I have updated my MXE cross-compilation toolchain to last Qt 5.15.18 Framework and upgrade GCC to version:14.3.0, KF5 libs no changes, for the Windows .exe cross-compilation package.
https://github.com/mxe/mxe/commits/master/
Agree the Code forum is probably the better place, I just saw Laurent's comment about Qt5 support and thought I would chime in, see what I might be able to do getting a Qt6 release completed.
I think that's a good idea. I believe getting a proper release with Qt6 should be a high priority considering both the state of Qt5, and since it has been a while since an official release was made.
234 (edited by scorpio810 2025-12-11 16:51:48)
Bonjour Laurent,
Je m'appelle Antoni Mxxxxxxxxxxxx et j'ai traduit Qelectrotech en
catalan. Je suis professeur de formation professionnelle à une
trentaine de kilomètres au nord de Barcelone, sur la côte, en Catalogne.
J'utilise Qelectrotech pour enseigner à mes élèves la réalisation de
schémas électriques, pneumatiques et hydrauliques. Je leur enseigne
également Eplan. L'apprentissage initial avec Qelectrotech est beaucoup
plus simple et me permet de leur enseigner Eplan après . Par la suite, ils
ou leurs entreprises feront le choix.
D'autre part, mes étudiants et moi avons pris une photo pour remercier la
communauté Qelectrotech de son travail. C'est un excellent outil
pédagogique pour nous.
Cordialement
Antoni
https://download.qelectrotech.org/qet/forum_img_2/2025-2026-1CSMI.jpg
Merci grandement au nom de l’ensemble de la communauté QET à toi Antoni pour ton enseignement et aussi pour ton travail de traduction, merci aussi à tes étudiants qui ont pris la pose avec toi chaleureusement, nomicons/wink ils seront nos futurs ingénieurs dans l'industrie.
L’ensemble de la communauté QET vous souhaites de passer de bonnes fêtes de fin d'année afin de vous reposer, de profiter de ces moments chaleureux avec vos familles et vos proches.
Et!, si vous en avez encore la force! de vous amusez pendant ces fêtes... pensez à faire de beaux schémas de vos futurs prototypes d'ingénieries, pendant que vous les avez encore en tête...
Q'importe le logiciel, QET ou Eplan, sans oublier FreeCad, KiCad, LibreCad, QCad, etc... dessinez, concevez et réalisez vos rêves d’ingénierie... les plus fous ... pour un monde meilleur!
Enjoy! nomicons/wink
Best regards,
FYI, I obliged to delete all qet_tb_generator binaries on server!
https://www.virustotal.com/gui/file/600 … 8f0bb4b37b
Generating a Python script into an executable .exe binary, etc. with PyInstaller and/or other tools alerts certain antivirus providers... they seem to be recognised by some as malwares and others not !.  WTF  !!! nomicons/gne
18/72 security vendors flagged this file as malicious... WTF  !!!   nomicons/gne
So please explain how we can produce the same Python binary without multiple false antivirus detections, or must we force our users to install it themselves by first installing the Python 3X framework and verifying that the user has checked the option to add the Python binaries to the Windows PATH, after which the user can use pip install qet_tb_generator in MS terminal....
Bonjour Laurent,
Lors de nos analyses de sécurité régulières, nous avons détecté la présence de fichiers malveillants (malwares) sur votre hébergement.
Par mesure de protection, nous avons temporairement bloqué les requêtes sortantes ainsi que l’envoi d’e-mails via les fonctions PHP. Cela signifie que vos sites installés sur cet hébergement ne peuvent plus expédier d’e-mails ni communiquer avec des services externes, le temps que la situation soit résolue.
Que dois-je faire ?
    Consultez notre guide pour stopper cette activité anormale.
    Une fois la situation résolue, connectez-vous à votre hébergement et demandez la levée des mesures de sécurité. Accéder à mon hébergement
Voici les fichiers malveillants que nous avons détectés :
   /download.qelectrotech.org/qet/builds/qet-tb-generator_macOS/qet_tb_generator
   /download.qelectrotech.org/qet/builds/nightly/qet_tb_generator/1.2.5/qet_tb_generator.exe
   /download.qelectrotech.org/qet/builds/nightly/qet_tb_generator/1.1.6/qet_tb_generator.exe
   /download.qelectrotech.org/qet/builds/nightly/qet_tb_generator/1.3.1/qet_tb_generator.exe
   /download.qelectrotech.org/qet/builds/nightly/qet_tb_generator/1.1/qet_tb_generator.exe
   /download.qelectrotech.org/qet/builds/nightly/qet_tb_generator/1.1.7/qet_tb_generator.exe
   /download.qelectrotech.org/qet/builds/nightly/qet_tb_generator/1.3.0/qet_tb_generator.exe
   /download.qelectrotech.org/qet/builds/AppImage/qet_tb_generator/1.2.5/qet_tb_generator
   /download.qelectrotech.org/qet/builds/AppImage/qet_tb_generator/1.1.6/qet_tb_generator
   /download.qelectrotech.org/qet/builds/AppImage/qet_tb_generator/1.3.1/qet_tb_generator
   /download.qelectrotech.org/qet/builds/AppImage/qet_tb_generator/1.1.7/qet_tb_generator
   /download.qelectrotech.org/qet/builds/AppImage/qet_tb_generator/qet_tb_generator
   /download.qelectrotech.org/qet/builds/AppImage/qet_tb_generator/1.3.0/qet_tb_generator
   /download.qelectrotech.org/qet/builds/qet-tb-generator_win/qet-tb-generator_32.exe
   /download.qelectrotech.org/qet/builds/qet-tb-generator_win/qet_tb_generator-1.3.1.exe
   /download.qelectrotech.org/qet/builds/qet-tb-generator_win/qet-tb-generator-1.1.4_32.exe
   /download.qelectrotech.org/qet/builds/qet-tb-generator_win/qet-tb-generator-1.1.5_32.exe
   /download.qelectrotech.org/qet/builds/qet-tb-generator_win/qet_tb_generator_1.3.0_windows.exe
   /download.qelectrotech.org/qet/builds/qet-tb-generator_win/qet_tb_generator-1.2.5.exe
   /download.qelectrotech.org/qet/builds/qet-tb-generator_linux/qet_tb_generator_1.3.0_linux
   /download.qelectrotech.org/qet/builds/qet-tb-generator_linux/qet_tb_generator_1.3.1_linux
Pour assurer la sécurité de votre site, de vos internautes et de l’infrastructure OVH, nous réalisons des analyses de sécurité automatiques sur l’ensemble des hébergements. Lorsqu’une activité anormale est détectée, des mesures de protection préventives et temporaires sont appliquées, afin de limiter tout risque.
Nous vous remercions pour la confiance que vous nous accordez.
L’équipe OVH
Hum OVH !!!! they are fasle postive warnings!
Laurent!
236 (edited by galexis 2025-12-22 16:28:14)
Laurent!
Il est bloqué depuis 2022 par mon entreprise, je te l'avais même fait remonte à l'époque. https://qelectrotech.org/forum/viewtopi … 141#p17141
Personne ne saurait finaliser le générateur intégré ? Comme Plc-User par exemple.
Why do we need to offer the plugin for download on the QET website?
GitHub has binary files for Linux and Windows in the corresponding repository:
https://github.com/raulroda/qet_tb_gene … aster/dist
There is no new version since 1.3.1 and these are available there.
@galexis:  "Do it yourself!"  nomicons/wink
