Topic: px snap and grid
snap points of objects are not in corners
can we change the grid (now 10 px/ point)
can we change the position of the border?
is it possible to show the snapposition of the mouse in a small window on bottom.
shooter@home.nl
QElectroTech → FR : Aide, suggestions, discussions, ... → px snap and grid
Where?
In diagram or element editor?
In diagram, as i like all symbols according to the ISO standards (working on a elementdirectory out of the book.
Could you please turn the printing of the pages 180 degrees, This way the margin is on the other side, so i can make punches on the right side (i am making diagrams on A3 and fold them.
A4 diagrams will have all left margin on top of page, thuss same to get the holes punched on size with greater margin.
I keep a margin of 10 mm according to the ISO7200, but the program gives me a ratio smaller.
Electrical diagrams on A3 is obsolete in 2014.
Yeah i realize, however most old drawings i receive to clean are in A3 or even bigger. So yes i do use it.
However this margin story keeps the same as in A4 i like the biggest on top.
For use A3 we need to add code for titleblock rotate to right corner.. in future not for 0.4.
http://qelectrotech.org/forum/viewtopic … 1582#p1582
no need see my iso title block if you keep remaining on left side it is working fine>
although one question mine is 709 wide but in software it says 600
Is just a preview, and not change titleblock width.
Index: sources/titleblock/templateview.cpp
--- sources/titleblock/templateview.cpp (révision 3043)
+++ sources/titleblock/templateview.cpp (copie de travail)
@@ -26,7 +26,7 @@
#include "qeticons.h"
#define ROW_OFFSET 2
#define COL_OFFSET 1
-#define DEFAULT_PREVIEW_WIDTH 600
+#define DEFAULT_PREVIEW_WIDTH 709
#define DEFAULT_PREVIEW_HELPER_CELL_HEIGHT 15
#define DEFAULT_COLS_HELPER_CELLS_HEIGHT 15
#define DEFAULT_ROWS_HELPER_CELLS_WIDTH 50
Generated in 0.018 seconds (28% PHP - 72% DB) with 11 queries
