Topic: terminal generator
After reading the previous topic I did some experiments with the terminal generator
(nice work by the way)
but I found some issues:
when I change the project setting the size of the font to 8 (as example) it shows immediately in the terminal block after saving and reopening the shematic it reverts back to size 15
the same applies for all other settings in the project terminal plan
If you apply a change and close the project the application does not ask to save the project
even if you do a save nothing is stored
Also the language is not correct
I have the language set to english and some text are in french
also the settings for the terminals are in the project I cannot find them in the configuration of QET
the python terminal generator also adds terminals and hose functionalty what is the plan to implement this?
