Topic: edit element user text
situation:
I have added to an element in the shematic a user text field
I double click this field to update
with the arrow keys you can go to the place where to edit but
if you press the end key from the keyboard the application goes to the last sheet of the shematic
Re: edit element user text
the same happens if you click <HOME> to go to the beginning of the text
then you go to the first page
anyone interested in checking this out??
@LievenC
Ik heb dat probleem niet.
Erik
Me neither. Which version do you have?
The effect you observed also occurs here and unfortunately still persists as before.
It seems to have something to do with which element is defined as the ‘parent’ of the text, but I have not found out the exact details. Someone who is more familiar with Qt programming will need to look into this.
