Topic: Coming and going arrows (folio referencing)
Hi all.
I'm new in this forum.
When I try to use folio referencing arrows, they don't show label "/" as I can observe in all videos.
When I try to tie an "going" to a "come" arrow, they don't show nothing. Wires are manually identified in the "text" field.
What is wrong?
I'm usind 0.9 version on windows 10.
Thanks in advance.
Re: Coming and going arrows (folio referencing)
Hello
Can you add a screenshot of what you get?
Hi.
Some screenshots:
https://qelectrotech.org/forum/viewtopi … 579#p21579
Maybe this Topic could help you
German translation is very bad. Seems we don't talk about same thing.
Thanks.
6 (edited by LievenC 2025-10-01 15:20:35)
the flow is:
double click the element you want to link
select the item from the list
right click <link the item>
the selected item comes green
and <Apply>
the links should appear on source and destination element
(you can use the other options to select the correct item to link)
to unlink click an element and select <Unlink> and <Apply>
to avoid futher questions:
you can move the text by holding the <shift> key and dragging the text to the desired place
LievenC wrote:
the flow is:
and <Apply>
Thanks, I don't knew right click step.... but: following wire in next folio gets same number but folio referencing not appears nomicons/sad
It seems that it's still not clear, what you mean, vramos!
Why don't you just attach a minimal example-file to your next post?
In the attachment you will find a small example, I created with latest 0.100-dev.
The ref-elements in that version only show the position of the attached xref.
If you want more information to be shown, you need to create your own xrefs.
here is my example with a / in the name
