Topic: SVN and QET
Hi, I'm new to QET and I want to involve me in development and testing while using, I download the svn repo, my question is, how do you use trunk and branches in this project.
Tks in advance
Marcelo
QElectroTech → EN : Help, suggestions, discussions, ... → SVN and QET
Tks in advance
Marcelo
Hi and welcome Marcelo,
We just use trunk at this time.
For example:
svn export svn://svn.tuxfamily.org/svnroot/qet/qet/trunk qelectrotech_trunkI see you join IRC #qet channel, just ask ;-)
I can open up a developer account on Qet subversion for you, if you want.
Tks for the reply
First I'll trying to compile and understand the using of the last devel version (while translate to spanish after ask actual spanish translator), just for start.
Will be a pleasure to have a developer account, ¿are there any rules to commit? ¿any simple bugs or simple features to do?
Marcelo
What your operating system?
If you use gnu/linux is very easy, Windows much less.
Ms Windows: cygwin, minGW, etc.
You use qt creator as IDE?
For compiling.
http://qelectrotech.org/wiki/es/doc/test_dev_version
Translation in Spanish is make by Alfredo in Mexico.
http://qelectrotech.org/wiki/es/doc/subversion
Marcelo
One, you do to subscribe to tuxfamily: by example just ask : I want to join QElectroTech project, after tell me in IRC channel, or send me an email, i just need your loguin (username subscription) for create your account to Qet subversion and mailing list.
You can work on what you want.
http://www.tuxfamily.org/en/subscribe
Scorpio
I using windows now, qt creator with mingw.
Only for fun, i'm trying to compile with Qt5.2, I will report the details when is finished (now the only isue is qprinter haven´t postscript capabilities, other problems could be solved without problems.
I'm installing the correct version now.
Mmiacca,
I use minGW too for make windows build under my VM seven.
cd /d %working_directory%\qelectrotech_trunk
//on lance la compilation
qmake
mingw32-make -j9 -f Makefile.Releasehttp://qelectrotech.org/forum/viewtopic … 1830#p1830
http://qelectrotech.org/wiki/doc/dev_windows
Porting Qet code to Qt 5 is a good feature for future.
Scorpio
My tuxfamily user is mmiacca
About compile, normally i compile from qtcreator, it does the same step, qmake and mingw32-make...
tks
Mmiacca
Your username is added to ML and SVN, thanks.
For Qt creator: http://qelectrotech.org/wiki/doc/qt_creator
svn+ssh://mmiacca@svn.tuxfamily.org/svnroot/qet/qet/trunkhttp://faq.tuxfamily.org/User/Sp#SSH_en_Windows
Mmiacca
If you want i can create a new branch for you.
I just delete not used branch devel and 0.4.
Scorpio, ok, a branch will be a good idea...
Other question, an small address translation of new label or messages (spanish) or code mofication, when can i merge to trunk, or only you merge to trunk?
Tks
Mmiacca
Branch devel created.
You can yourself merge your code to trunk ![]()
But is very buggy i can revert your commit :p
thx
Comment peut-on connaitre les changements apportés de chaque version svn ?
Cordialement.
Alexis
Le titre du commit n'est pas explicite pour toi?
Qu'est-ce que le "commit" ?
Cordialement.
Alexis
Cordialement.
Alexis
L'envoi d'un patch sur le subversion.
ça peux être un ajout de symboles, l'ajout de traduction, du code etc..
Voila.
Je ne comprends pas où ce trouverais le titre du "commit", dans Synaptic (outil d'installation de paquets linuxmint) il n'y a pas d'info sur les changements et rien dans Qet non plus dans A propos ou autre .... On connais juste le numéro de la mise à jour.
Cdlt
Pas dans synaptic, soit dans l' historique Web Svn[1] soit sur la ML.
Edit: le changelog d'un paquet Debian est fait pour indiquer les changements sur le paquet et non les modifications Upstream.
[1]http://svnweb.tuxfamily.org/log.php?rep … dir=1&
Ok, c'est nickel, cela me suffit.
Cordialement.
Generated in 0.035 seconds (20% PHP - 80% DB) with 11 queries
