Topic: move text field
with the comminf of Built with Qt 5.15.16 - x86_64 - Date : Feb 22 2025 : 10:39:25
It is no longer possible to move the text field from an element
(with every new release I only replace the exe file)
QElectroTech → EN : Help, suggestions, discussions, ... → move text field
This must be the 0.10-dev - version in which we have introduced a new function so that dynamic texts of the elements are not accidentally moved when the element as a whole shall be moved.
Since then, the dynamic texts of the elements are only moved if the Shift key is pressed at the same time!
Remark:
You should also replace "your" language-file, for the case, that new texts are introduced for example in config-page.
nice to know this new feature was introduced
I just added a PR related to this. It will show "<Shift> to move" in the mouse hover text for the texts of an element.
Generated in 0.033 seconds (16% PHP - 84% DB) with 11 queries
